Intellijel Shifty
Mr. Aloud
Re: Intellijel Shifty
Post by Mr. Aloud » Wed Jun 10, 2020 7:39 am
Sounds like a plan. More research ongoing ;)
It would seem that still, after all these years, perception is essentially thought to be a passive process.
peachesandbacon
Post by peachesandbacon » Sun Oct 25, 2020 4:07 am
Quick question on the Shifty.
Does this replace the functionality of my A-151 v2?
helix
Post by helix » Sun Oct 25, 2020 5:21 am
Nope, totally different thing! Thats just a sequential switch. You might be able to use it for that.... but you'd be massively under-utlizing it and paying a hefty price for a simple switch
FOR SALE: M.N DPO. X0X HEART, CHORD V2, SENSIBLE OFFERS! UK
https://michaeldow.bandcamp.com/album/m ... light-side
https://soundcloud.com/obleomusic
peachesandbacon
Post by peachesandbacon » Sun Oct 25, 2020 5:29 am
Sorry, I didn't explain that well.
Yes, I'm aware they're different.
I already have an A-151, and have a shifty on the way for shift register reasons.
But it will also work as a simple sequential switch of sorts... correct?
Dark Barn
Post by Dark Barn » Sun Oct 25, 2020 5:31 am
As @cptnal said a few posts back the Shifty isn’t bi-directional.
I’ve been searchin’ for the dolphins in the sea
The Weak in Review - podcast in ((poetic_stere0)) Spotify YouTube
Genox
Post by Genox » Mon Nov 30, 2020 6:28 pm
I didn't even knew I needed one until I stumbled upon this thread :D
G.A.S. activated
neuehufte
Post by neuehufte » Tue Dec 01, 2020 10:08 am
This sold it for me. Last few videos from Jeremy have been expensive
helix
Post by helix » Tue Dec 01, 2020 10:11 am
It's really fun guys. I actually have been using mine alongside a mutable instruments branches, which can make it super fun to have two random ouputs active at once.
moo_lefty
Post by moo_lefty » Sat Dec 26, 2020 4:43 pm
Could shifty be used to send an envelope or LFO to four destinations in sequence? The examples I've seen seem to concentrate solely on using it for melodies
Parnelli
Post by Parnelli » Sat Dec 26, 2020 4:52 pm
Shifty takes a gate input and divides it 4 ways sending it to one of the outputs at a time depending upon how they are set up. If there is a CV input then that value is sampled at the time of the gate input and the corresponding value sent to the same one of four outputs as the gate. You can set the output pattern 1-4, 4-1, 1-4-4-1, and random, and you can set the sampling for track or hold. I just started messing with the track feature and the CV output stays with the CV input changes, so yes, one might be able to pass envelopes through it, albeit only one per destination at a time.
It comes in real handy for hocketing, and with a nice delay set up you can get chord sounds of sorts, that's what I've been using it for the most.
moo_lefty
Post by moo_lefty » Sat Dec 26, 2020 6:27 pm
Thanks, so if I understand correctly, as long as there is a gate as long as the envelope (eg rise and fall gates combined from an ad envelope) it could then distribute the full envelope out in sequence?
OHEXOH
Post by OHEXOH » Sun Dec 27, 2020 1:56 am
If you want to send the LFO/envelope to different outs 1 at a time, then yes. You can use it as a 4 way switch and it will send continuous cv. Page 12 in the manual.
Gear for sale (Reverb): https://bit.ly/2Sb90oc
muffdiver
Post by muffdiver » Tue Jan 12, 2021 4:07 pm
Following re: comparison to copier machine in ornaments & crime. I was curious what the range is for Shifty?
Love the ASR in O_C but not the limited 3.3V range. Modulation signals often get truncated if not scaled and offset. Can anyone who has used both comment on this?
megarat
Post by megarat » Tue Jan 12, 2021 5:39 pm
I haven’t measured it myself, but according to the manual, the pitch/CV input (and thus outputs) are in the 0-10V range. It’s primarily designed for pitch, so the CV outputs very closely reproduce what is seen at the input, with no perceptible scaling or offset.
Dcramer
Post by Dcramer » Fri Jan 15, 2021 9:56 am
Been putting this one off for two long 🙃
Parnelli
Post by Parnelli » Fri Jan 15, 2021 5:31 pm
It doesn't disappoint...
peachesandbacon
Post by peachesandbacon » Fri Jan 15, 2021 8:52 pm
Just came here to give another shout out to Shifty.
Great utility module. One of those modules you really don't think you need, until you have one.
I wouldn't let it leave my case now.
I often take gate and pitch from a channel of Marbles and use shifty to fire notes and to 4 different oscillators and 4 different gates to envelopes and vcas.
Back Down the Path
Post by Back Down the Path » Fri Jan 15, 2021 9:15 pm
The only issue with Shifty is you want to use it in every patch while ignoring your brand new 4 channel sequencer (this may be a personal issue).
rens
Post by rens » Sat Jan 16, 2021 5:58 am
Exactly this.
sonicjosh
Post by sonicjosh » Mon Feb 08, 2021 5:39 pm
Thats too funny because i also got a Stillson Hammer Mk2 the same week i got shifty lol.
Josh Korody- Engineer/Producer/Artist
Candle Recording
Toronto, On
Phitar
Post by Phitar » Mon Feb 08, 2021 10:39 pm
Exactly this.
Yes! Exactly! :oops:
In adddition to "More Cowbell!" everything should have more REVERB! :tu:
Xtheunknown
Post by Xtheunknown » Mon Feb 22, 2021 8:19 pm
Is there any way, perhaps with a firmware update, to recognize -10V to +10V - the same as Scales? If not, could we get an option for +/- 5V so that it's compatible with things like the Mother-32?
kisielk
Post by kisielk » Mon Feb 22, 2021 8:25 pm
Unfortunately not, it's a hardware limitation.
Intellijel R&D
Xtheunknown
Post by Xtheunknown » Tue Feb 23, 2021 6:54 am
Thanks for the response. Have you run across any viable workarounds?
