You can toggle Loopy on and off or gate loopy. You could easily set this up to sync with a clock.
Intellijel Tetrapad
Re: Intellijel Tetrapad
I was unaware you can do voltage banks in combo mode now (I don't recallthat being a feature in the firmware version I have, but I could be wrong and just didnt RTFM good enough), so that is good newsmegarat wrote: ↑Thu Feb 11, 2021 1:19 amIf you’re using a Tête, combo mode has a “voltage banks” mode. A pad in voltage banks mode is divided into four sub-pads, each of which output two voltages. So you can have (for example) two pads in voltage mode, one pad as an LFO, and another running Euclidean rhythms.
Edit: Came back to say, yeap it's in the new firmware (guess what I'll be doing tonight), this is awesome!
edited: just read some posts from earlier in the year about dual tetrapads into single tete
Well, I will just say that I recently got the tete/tetrapad combo and I totally love it!
Made in Italy and exported to NYC
Instagram: The Analog Kid
But only with the Tete, right?nexgen23 wrote: ↑Thu Feb 18, 2021 12:41 pmI was unaware you can do voltage banks in combo mode now (I don't recallthat being a feature in the firmware version I have, but I could be wrong and just didnt RTFM good enough), so that is good newsmegarat wrote: ↑Thu Feb 11, 2021 1:19 amIf you’re using a Tête, combo mode has a “voltage banks” mode. A pad in voltage banks mode is divided into four sub-pads, each of which output two voltages. So you can have (for example) two pads in voltage mode, one pad as an LFO, and another running Euclidean rhythms.Thank you
I bought a Tetrapad, I was pleasantly surprised at how responsive the touch surface is. Very impressed so far. Need to dig into the manual and see what sort of workflow will work best for me.
- megarat
- Veteran Wiggler
I believe so, I think without the Tête you are restricted to one mode at a time, but I am not 100% certain.ronaldroy wrote: ↑Thu Feb 18, 2021 6:26 pmBut only with the Tete, right?nexgen23 wrote: ↑Thu Feb 18, 2021 12:41 pmI was unaware you can do voltage banks in combo mode now (I don't recallthat being a feature in the firmware version I have, but I could be wrong and just didnt RTFM good enough), so that is good newsmegarat wrote: ↑Thu Feb 11, 2021 1:19 amIf you’re using a Tête, combo mode has a “voltage banks” mode. A pad in voltage banks mode is divided into four sub-pads, each of which output two voltages. So you can have (for example) two pads in voltage mode, one pad as an LFO, and another running Euclidean rhythms.Thank you
