WMD MSCL stereo compressor
gummyboy
Re: WMD MSCL stereo compressor
Post by gummyboy » Sun Mar 22, 2020 10:37 pm
ggillon wrote:
Fri Feb 21, 2020 8:40 am
leads me to believe that I'm indeed supposed to leave it to the left or center, and that the values on the site are reversed and it's really +5dBu, -4dBu, -15dBu which explains why I was so confused.
It's starting to make more sense now. I also see I was clearly sending a signal that was way too low into it initially because no attenuation would take place unless switching to the right.
I had exact same question and I got the email from WMD
"If using all eurorack modules, it is best to keep the THLD switch to the left, as that is expecting high level signals and will compress those well. If you put the switch to the middle or right, it will be easy to over compress the sounds. The point of the switch is for using MSCL with other gear such as Roland samplers that are notorious for having a low output volume, so they can still be compressed and not just smeared with input gain.
You are correct that the values should be reversed on the description where +5 dBu is on the left, meaning it will compress the least but work well with high level signals. "
Hovercraft
Post by Hovercraft » Mon Mar 23, 2020 8:18 pm
As someone who's been using MSCL since they were released, I suggest trying different Threshold settings, so you can match it to your patch and gain staging. For example, I currently have the output of my filter going into the MSCL, and then into my fx modules. It's a highly resonant patch and the input of Spin FV-1 fx are easily overloaded, so I'm compressing pre-fx. In my case, even though it's a modular level output, the Threshold is set to the far left position (Limit is also set far left). Trust your ears.
PhineasFreak
Post by PhineasFreak » Tue Mar 24, 2020 10:03 am
...Trust your ears.
this.
i'm using 4 of em for general abuse in single channels - depending whtehr theyre pre/post eq and what i'm feeding em i use near every setting going at soem point..
https://thomaswulfe.bandcamp.com/
http://www.soundcloud.com/ylem-records/
http://www.soundcloud.com/best-of-ylem/
http://www.soundcloud.com/waxcide/
http://thomaswulfe.muffwiggler.com/
http://ljunggrenaudio.com/
http://waxcide.bandcamp.com/
Just remember what Phineas would say... "eurorack can get you through times of no money better than money can get you through times of no eurorack". - bkbirge/
rafyc
Post by rafyc » Tue Mar 24, 2020 4:16 pm
Is there two version of this module ?
I cant fine the one in the first page.
The only one available on wmd website is only with frequency selector.
Where are gone the others options ??
WMDevices
Post by WMDevices » Tue Mar 24, 2020 5:54 pm
Only one version as ever been produced. Just now in black panels.
Check out the growing number of WMD Demo Videos | WMD Website
rafyc
Post by rafyc » Wed Mar 25, 2020 3:31 am
Right ! i confuse with the SSF one...
