Trouble is, I've used up all of my hp, and have no more room. I didn't realise the Doepfer ribbon needed a module to support it, be grateful for any other takes on this...
It doesn't ... you can have it with an external control box.mousegarden wrote: I didn't realise the Doepfer ribbon needed a module to support it, be grateful for any other takes on this...
Really?Rigo wrote:It doesn't ... you can have it with an external control box.mousegarden wrote: I didn't realise the Doepfer ribbon needed a module to support it, be grateful for any other takes on this...
I've got to have it, on looks alone....Hanz wrote:Walking Stick, right there.
Easily the best looking and very true-to-form. However, a bit barebones / hardcore, functionally.
So it doesn't *require* any other modules. But it greatly helps though.
http://psionicsoundworks.com/
Walking Stick doesn't hold the position voltage on release. So if that's important to you (it is for me) you'd need to patch that up separately. Hold on the Doepfer ribbon is switchable on the breakout module and/or the midi unit. Eowave Ribbon always holds.mousegarden wrote:
Umcorps wrote:I thought you were just pleased to see me.scottmoon wrote:Ribbon will fit in a pant leg.
What does this actually mean in real terms? Does it mean that if I take my finger off and then touch it again anywhere, it triggers the last note I played?Umcorps wrote:Walking Stick doesn't hold the position voltage on release. So if that's important to you (it is for me) you'd need to patch that up separately. Hold on the Doepfer ribbon is switchable on the breakout module and/or the midi unit. Eowave Ribbon always holds.
It means that when you touch the patched up Walking Stick you get a note voltage related to your finger position but when you take your finger off, the note voltage falls back down to zero.mousegarden wrote: What does this actually mean in real terms? Does it mean that if I take my finger off and then touch it again anywhere, it triggers the last note I played?
Thanks, I'll have to check one out, probably at London modular, I seem to remember he had some things there.Umcorps wrote:It means that when you touch the patched up Walking Stick you get a note voltage related to your finger position but when you take your finger off, the note voltage falls back down to zero.mousegarden wrote: What does this actually mean in real terms? Does it mean that if I take my finger off and then touch it again anywhere, it triggers the last note I played?
On the Eowave, when you take your finger off, the note voltage holds at whatever it was until you touch it again.
So the Walking Stick behaves more like a string instrument - you get the note your choose for as long as you hold down the string but let go and you're back to the open string. The Eowave and Doepfer in hold mode behave more like a keyboard - hit a key and the note value remains until you hit another key.
If you can, find someone with the Doepfer ribbon so you can try out both options and see what works best for you. The Walking Stick is very nice but if you really want the note hold behaviour its going to be an expensive source of frustration.
Shipping as of today.okkoto wrote:I think I noticed on instagram that Synthrotek is working on a ribbon based thingy
