Nerdsynth NerdSEQ - eurorack tracker/sampler
Moderators: lisa, Kent, Joe.
joskery
Re: Nerdsynth NerdSEQ - eurorack tracker/sampler
Post by joskery » Tue Jan 28, 2020 7:21 pm
Ohh, thanks. I’ll slip in one more newbie question: The manual describes the Recent Values screen, but doesn’t say how to reach it. How is it done?
ehr
Post by ehr » Tue Jan 28, 2020 7:25 pm
...the Patch button when you are on the sequencer screen
joskery
Post by joskery » Tue Jan 28, 2020 7:32 pm
Thanks :cloud: My slight confusion might be because I started this NerdSeq thing out using MIDI tracks, which don’t seem to have all the stuff in them yet. Appreciate the help!
ehr
Post by ehr » Tue Jan 28, 2020 7:59 pm
No problem. It is a super deep sequencer so there's a lot to learn. I'm still figuring things out too.
joskery
Post by joskery » Thu Jan 30, 2020 5:51 pm
anyone tried the new launchpad pro mk3 with the nerdseq?
guigui
Post by guigui » Thu Jan 30, 2020 5:59 pm
particleswillbewaves
Post by particleswillbewaves » Sat Feb 01, 2020 9:35 am
A question for the Nerdseq + expander users: is the expander module easy to build into a case (as in: get rid of the front plate and deconstruct it without destroying it?) I'm trying to keep all the I/O in the sides of my case.
gein
Post by gein » Sat Feb 01, 2020 11:28 am
I did this with my midi expander, was easy. I removed the midi jacks from the pcb, glued the pcb to the bottom of my case, drilled holes in the side and wired the midi jacks to the pcb.
firestARTer
Post by firestARTer » Sat Feb 01, 2020 11:39 am
Yeah, just release the hexnuts and you can put off the frontpanel. Shouldn't be any issue except for LOSING WARRANTY!!!
Hahah, just kidding. All should be fine and no worries about warranty. Just don't hurt yourself :mrgreen:
NerdSEQ - one of the most advanced Eurorack Sequencers
https://www.xor-electronics.com
Post by particleswillbewaves » Sat Feb 01, 2020 4:06 pm
Hah, cool thanks for that :) I'm ordering this week or the next. Can't wait, so excited for this one!!
grimleyj
Post by grimleyj » Sun Feb 02, 2020 12:12 am
I contemplated wiring up the midi io expander to the midi ports on the back of my Intellijel 7u. In the end, I realized I didn’t have the required skills. Instead, I secured the expander inside the case and attached a couple of male to female midi cables which hang out of the top right 1u section of the case, using up 1hp. Works well for now!
note!
Post by note! » Mon Feb 03, 2020 11:47 am
Wait.. this is genius actually. I might try this..
joskery
Post by joskery » Mon Feb 03, 2020 11:50 am
I wonder if it would be possible to do without disassembling the expander. Pinout needed?
firestARTer
Post by firestARTer » Mon Feb 03, 2020 11:56 am
Which pins?
joskery
Post by joskery » Mon Feb 03, 2020 1:57 pm
Which pins?
I'm in way over my head :D I was just wondering aloud if it's as simple as connecting the expander pins on the back of the module to the DIN MIDI IN/OUT jacks in the Intellijel 7U case. Might not be the case (no pun intended) at all.
firestARTer
Post by firestARTer » Mon Feb 03, 2020 2:08 pm
Which pins?
No, this has been discussed here or in the XOR Forum already. Even though the Midi expander is passive, it has the needed opto isolation and specs to work properly with midi gear. Hanging something directly to the expander port could kill the device.
joskery
Post by joskery » Mon Feb 03, 2020 2:26 pm
Okay, thanks for setting it straight! Got excited about the prospect for a minute.
Jefro
Post by Jefro » Mon Feb 03, 2020 3:54 pm
I have not, but came in here looking for an answer to this very question. I'd like to pick up a launchpad for my nerdseq, and the new one looks pretty cool.
joskery
Post by joskery » Sun Feb 09, 2020 9:34 am
How do people integrate the NerdSeq in setups with other sequencers? How do you handle, say, pattern changes? Haven’t find the optimal way to sync Elektrons with program changes. Maybe it would just need to be done manually?
jjterbeek
Post by jjterbeek » Sun Feb 09, 2020 10:38 am
I use Nerdseq incombination with Polyend Preset, WMD Sequential Switch and Acid Rain Switchblade.
Nerdseq is programmed in "Island" offcourse and with one hit on Preset button i can change 4 switch settings on WMD and Acid Rain, and 5 settings on modules.
joskery
Post by joskery » Sun Feb 09, 2020 11:47 am
Nice, sounds like a very powerful combo :) the Preset is interesting.
JoeFuture
Post by JoeFuture » Mon Feb 10, 2020 11:00 am
When using live transpose via the CV inputs, is there a way to make the transposition happen instantly? In my limited experimentation with it, transposition seems to only happen once a new 16-step bar begins.
SB-SIX
Post by SB-SIX » Mon Feb 10, 2020 3:18 pm
Manually, and that's the beauty of it! You can run a beat on the elektron, and for instance bring in 1 pattern of your next "song" on the nerdseq. Then switch the beat later or bring in another pattern. This makes transitions a breeze.
There is a chance you might like this: https://soundcloud.com/steeboo
BenA718
Post by BenA718 » Wed Feb 12, 2020 7:49 am
I am using Pam’s as my master clock and Erica Synths MIDI <-> CLK; I set the NerdSeq for external clock as well as an MC-500; one press from MIDI <-> CLK syncs both sequencers fine! The NerdSeq is receiving clock pulses and the MC-500 is receiving MIDI clock and both of those sequencers can be programmed in a way to play an entire song so I am not making changes after they are started.
Post by particleswillbewaves » Sun Feb 16, 2020 1:08 pm
I did it! I'm somewhere between very pleased, proud, smugg, happy, and so forth. A combination of those. It was easy too! I did some DIY before but it's not like I'm experienced. With some through hole soldering skills and common sense it's a very doable project. I did the same before with my Intellijel Audio I/O jacks. I have to say, it's VERY satisfying to plug whatever MIDI into the side of my case and sequence away, highly recommended.
