Announcing ALM017 - Pamela's NEW Workout
jwise
Re: Announcing ALM017 - Pamela's NEW Workout
Post by jwise » Wed Jun 03, 2020 2:51 pm
Matthew while on a talk on Knob Twiddlers Hangout #6 from Stoor (Speedy J) just said that there's a new firmware for PNW in the works!
apcuddling
Post by apcuddling » Wed Jun 03, 2020 3:01 pm
Already? They just released an update like a week ago.
synkrotron
Post by synkrotron » Wed Jun 03, 2020 3:08 pm
Bit strange that, unless some issues need fixing with the one we got last month.
jwise
Post by jwise » Wed Jun 03, 2020 3:16 pm
New functionality actually.
synkrotron
Post by synkrotron » Wed Jun 03, 2020 3:33 pm
Interesting, thanks. I'll check out video for that :tu:
yellowecho
Post by yellowecho » Wed Jun 03, 2020 8:30 pm
:sb: I'm still loving the last beta release... can't wait to checkout the newest firmware!
sjbucks
Post by sjbucks » Thu Jun 11, 2020 6:39 am
Ok I seem to have found the solution. I just set the PPQN to 1 in Pam's. That allows me to do exactly what I was intending - using the t-section of Marbles to drive Pams. This means I can use the bias knob to increase/decrease the regularity by which Pam's moves forward.
rd45
Post by rd45 » Sat Jun 13, 2020 1:30 pm
this is just a reminder for future-me when i'm doing the next firmware upgrade...
hey, remember that if you're updating from a Linux machine and you get "dfu-util: Cannot open DFU device 0483:df11" - you need to use sudo!
tigersi
Post by tigersi » Sat Jun 13, 2020 1:34 pm
Haha I love it :hihi: :yay:
viewtopic.php?f=74&t=234159 My eurorack yard sale
Education is the kindling of a flame, not the filling of a vessel.
We don't make mistakes, we just have happy accidents. (Bob Ross)
muffdiver
Post by muffdiver » Sat Jun 13, 2020 1:50 pm
Anybody know if there is a black panel available for PNW?
r05c03
Post by r05c03 » Wed Jun 17, 2020 3:24 pm
So. Say I wanted to set up 6 channels on PNW to to gate mode but have each gate trigger one step (time interval) later than the previous. So that track 1 goes high, then gate 2 then gate 3 and so on. How would I do that?
Gear List: Elektron Octatrack, Elektron A4,Microbrute, Bass Station, Rings Braids, Pitts Ring Mod, Pitts Osc, Echophon, Intillegel uFold / uMIDI, PNW2, Doepfer 138-c, 119, Tiptop Z4000, Maleko Fade / 8NU8R
benofbrown
Post by benofbrown » Wed Jun 17, 2020 3:27 pm
Play with the Phase setting, that should get you there.
ronnieb
Post by ronnieb » Wed Jun 17, 2020 5:24 pm
When I heard about the new firmware for pam I thought it would be super cool if they could figure out how to incorporate E-Trigs in a similar way to the Squid (sends a trig at the end of a sample) so that you could chain modulations. Pretty sure that is what you looking for here?
Another thought could be to use Euclid and set it to 6 steps then rotate each channel? Haven't tried in practice but it kinda makes sense in my head :drunkbanana:
apcuddling
Post by apcuddling » Wed Jun 17, 2020 11:49 pm
That concept is a bit redundant here considering the functionality of the module is to work as a clock and not a one-shot sampler, it's already doing this when you think about it - with the end of the cycle of a channel being the same as the start its next cycle. With Squid it makes sense because the length of the samples are not constrained to the tempo and stay the same no matter what, unless you trim them or re-trig before a sample reached its end. If what you are saying is to have one channel fire off at the end of another's cycle - then that can be done just by offsetting the phase and getting the timing matched up because, again, the core of this module is to function as a clock, meaning a loop unless programmed otherwise.
erstlaub
Post by erstlaub » Thu Jun 18, 2020 6:01 am
The phase thing is a bit trickier as you need to divide the phase by the number of steps but you can only express that as a 2 digit percentage. A more elegant way is to set EStep to 6 and Etrig to 1 on all 6 channels so that each channel only fires once in every 6 ticks and then set each channels Erot 1 higher than the next.
nb. I've just come across a slightly weird issue with this though where channel 2 isn't really behaving as it should so I need to investigate what's going in with it (unless it's a fw bug, can anyone else check and verify?)
Edit: Yep, I'm not really sure what the deal with it is, it works slightly differently from how I'd expect but for some reason if I set channel 1's Erot to 6 and -1 for each subsequent channel I get 6 channels to fire off one at a time.
Step 1: Estep 06, Etrig 01, Erot 06
Step 2: Estep 06, Etrig 01, Erot 05
Step 3: Estep 06, Etrig 01, Erot 04
Step 4: Estep 06, Etrig 01, Erot 03
Step 5: Estep 06, Etrig 01, Erot 02
Step 6: Estep 06, Etrig 01, Erot 01
r05c03
Post by r05c03 » Thu Jun 18, 2020 8:16 am
Nice! Thanks!
studioutopia
Post by studioutopia » Thu Jun 18, 2020 9:04 am
BKM Panels had a black panel with the MN Black and gold shared system look - but Brian shut his company down a few months ago.
I have the LXd black panel from him and it's truly unfortunate that he has shut down operations - the quality is excellent.
circuitburst
Post by circuitburst » Fri Jun 19, 2020 11:53 am
Just noticed on Modulargrid there is a limited edition black panel version, but it's already SOLD OUT unfortunately:
https://busycircuits.com/product/black- ... w-workout/
"make the events occur that you want to occur" - the black dog
https://soundcloud.com/circuitburst
https://www.modulargrid.net/e/racks/view/295055
:boat: World Map of Eurorack Module Manufacturers: https://www.google.com/maps/d/u/0/viewe ... 9IMDP34-ao
World Map of Eurorack Module Physical Shops: https://www.google.com/maps/d/u/0/viewe ... gfSeJ6wVIG
mdoudoroff
Post by mdoudoroff » Fri Jun 19, 2020 11:55 am
Since I was one of the people bugging ALM for a display as bright as Squid Salmple, I snagged one on principle. He probably should make more. Perhaps he shall?
If you want more, wouldn’t hurt to tell them: info@busycircuits.com
trickness
Post by trickness » Fri Jun 19, 2020 12:11 pm
I got one too, only 60 units, all proceeds going to charity. Awesome
studioutopia
Post by studioutopia » Fri Jun 19, 2020 12:55 pm
Oh wow. That is gorgeous. I would love a real ALM black panel for my PNW. I'm not fond of the MN look... this is so clean. He should sell replacement black panels for the charity donation too!!
tigersi
Post by tigersi » Fri Jun 19, 2020 1:36 pm
I really like that black panel. I wish they would do more
muffdiver
Post by muffdiver » Fri Jun 19, 2020 3:34 pm
Yeah, hope they do another run of black panels. Looks great!
blaythe.steuer
Post by blaythe.steuer » Fri Jun 19, 2020 3:44 pm
I missed the black panel by 3 minutes this morning :( really hoping for another run. it looks incredible in black
morrison23usa
Post by morrison23usa » Fri Jun 19, 2020 9:38 pm
Emailed info@busycircuits.com to beg for more!
