Announcing ALM017 - Pamela's NEW Workout
apfEID
electro-vivisection
Re: Announcing ALM017 - Pamela's NEW Workout
Post by apfEID » Wed Jul 22, 2020 4:11 pm
ModusOp wrote:
Mon Jul 20, 2020 7:58 am
Can someone please tell me if the smooth random is AC or DC? I want to invert it outside of Pam’s but not sure if I need to offset it too.
AC vs DC is just a measure of how slowly a signal is changing. If it's able to stay above or below 0v for the duration required for an envelope or lfo, it's DC. AC means it's always moving.
Inputs/outputs that aren't DC coupled will drop any offset when the signal drops below a certain frequency. I don't remember the exact cut off but if you're using a signal that's slow enough for an LFO or a sequence (where it is effectively stationary during each step), those won't pass through, unless mixed into a moving AC signal as well, where it will manifest as "DC Offset" which you can see in a waveform, if for example you sum a DC 1v with a 40hz tone -2 to 2v tone, you'll see the 40hz tone is oscillating around 1v instead of 0 even if you recorded it with something that's only AC coupled. But if you stop the 40hz tone, the 1v will also disappear because it's DC and is filtered out. AC is basically high pass filtered somewhere under 20hz so you don't hear anything below the lowest bass you can hear as a tone.
so, Pam's is definitely outputting DC when slow envelopes are involved. But it's all unipolar from 0 up, so if you want bipolar movement you need to offset it and then probably scale as well.
Te Occidere Possunt Sed Te Edere Non Possunt Nefas Est
http://anthonysaunders.bandcamp.com/
ModusOp
Post by ModusOp » Wed Jul 22, 2020 6:10 pm
Interesting! So I don’t necessarily want bipolar movement, I don’t think.
I’m just looking to take two slow fluctuating random signals from Pam’s to make the ol’ Krell patch happen (going to the attack of one cycling envelope and the decay of another, then those to a third cycling envelope’s attack and decay), but then take those same two fluctuating random signals and invert them to create a second pair of cycling envelopes that would go to yet another cycling envelope that will in theory speed up when the other slows down... if that makes sense.
OHEXOH
Post by OHEXOH » Fri Jul 24, 2020 6:56 pm
OHEXOH wrote:
Wed Jul 22, 2020 3:54 pm
ALM wrote:
Wed Jul 22, 2020 5:12 am
I think its always worked like this... what firmware were you on previously and was behaviour different ?
I don't think I've ever used RUN to reset before - I've always used PAM & RUN Y with an external clock. I'm now using PAM as the clock source so out of all the options, using RUN as a RESET seems to be quite useful.
I'll try again with other channels to see if Skip seems to work as expected (ie: % random) or if it starts to predictively repeat itself when a RESET trig is received.
I tried this again today. I started by resetting the Bank so all channels are synced and running x1. On Track 1 I set to Skip to 90% and then on Track 2 I send a trig to the Run input which is set to reset. Track 2 is running at x8 so there's 'air time' before the reset trig.
So a simple set up - and yeah, it does the same thing, Track 1 seems to always send a trigger at the same beat shortly after the reset is received. It's like Loop is switched on, but it's not.
Hopefully that helps clarify it. :tu:
Gear for sale (Reverb): https://bit.ly/2Sb90oc
54731
Post by 54731 » Mon Jul 27, 2020 4:30 pm
Hey guys, I have a question: are there any black replacement faceplates for Pamela´s New Workout on sale anywhere, or do you know someone who makes them? There used to be BKM Panels, but they are not operating anymore and I missed the train. Pamela is the only silver faceplate module in my performance case and I´d love to have it all black. :help: I know there was a limited edition sale for a black-faceplate unit whit red LEDs, but I won´t be buying a new module just for the looks.
Nevertheless, Pamela´s New Workout always has a place in my rack. :love:
Haste makes waste.
ALM_Zach
Post by ALM_Zach » Fri Jul 31, 2020 1:19 pm
Multiple people caught a mistake in our Pamela's PC Firmware Update video. When recording we forgot to change 'dfu-util' to match the 'dfu-util-static' binary file that is downloaded earlier in the video. Please make sure the file and name match! We have updated the video to point out the mistake and re-uploaded it to Youtube.
Our apologies for any confusion this may have caused. :doh:
Kattefjaes
Post by Kattefjaes » Fri Jul 31, 2020 1:21 pm
Phew, I feared it was another update, requiring me to remember where I put my mini-USB cable. Yep, caught and corrected that, but it's nice that you've updated the video for people who find the slightly fiddly process intimidating ;)
Migrigsynth
Post by Migrigsynth » Wed Aug 05, 2020 4:17 pm
Is anybody having a problem with Pamela’s not being able to sense external clock input? I just upgraded to 206 and the clock input will not function.
BaloErets
Post by BaloErets » Wed Aug 05, 2020 4:31 pm
Not on my side. Using the current firmware and had the clock input synced up just yesterday without any issues. What are you using as a clock to send to Pams?
tdallas
Post by tdallas » Thu Aug 06, 2020 2:11 am
Mine is working fine with external clock inputs on 206. Have you tried to do a global reset after the upgrade? Maybe it is waiting for an additional run signal?
Thedoge
Post by Thedoge » Thu Aug 06, 2020 5:48 pm
I'm experiencing the same, I'm sending clock signal from a westlicht performer as well as from a batumi and it says unstable all the time :bang:
edit: sorry, forgot to set PPQN to 04, it's working fine here too :yay:
honeysmack
Post by honeysmack » Thu Aug 06, 2020 8:05 pm
anyone having a problem with their website - comes up blank in Chrome and Safari on my Mac?
megarat
Post by megarat » Thu Aug 06, 2020 9:32 pm
ALM’s web site comes up fine for me with Safari on my iPad.
Migrigsynth
Post by Migrigsynth » Sun Aug 09, 2020 7:38 am
I’m using Stages as a clock input. I’m coming from logic/REM interface into Stages and then out of stages in to Pamela‘s. When I initially started trying to clock Pamela‘s externally i used logic directly into Pamela’s and I would never get a consistent tempo. It would always be very erratic so I eventually went to the intermediate step of going into Stages.
Migrigsynth
Post by Migrigsynth » Sun Aug 09, 2020 7:41 am
I have not tried that yet but I will.
Migrigsynth
Post by Migrigsynth » Sun Aug 09, 2020 8:06 am
Oops! Rookie move. I had the “run” screen set to “yes” ! 😁 thanks for the suggestions guys I appreciate it.👍
kobe
Post by kobe » Mon Aug 10, 2020 11:39 am
Just updated to 206 and all stored programs are gone. Is that normal???
EPTC
Post by EPTC » Tue Aug 11, 2020 1:38 pm
Wanted to comment that a few years into PNW, I'm still finding great new uses! I have a few modules that have gate inputs to trigger events but would love them to be perpetually on or off instead. Was looking at getting the ADDAC manual latch gates for this but also am thinking to find solutions in what I have instead of buying more gear. If it could be something I can patch, all the better. If a new module has to be made, I'd prefer it be passive and not go through power cable arrangement.
Then it hit me: A single channel of Pam's on a mult with A/B switches does this. Just set one channel to be perpetually "ON" (so no pulses) connect that to a mult to a row of A/B switches and presto, that whole row of A/B switches, easy to make, and it become ON or OFF gate latches. I have them on an ABC switch three position switch, so A sends and ON to one piece of gear, the center position is off, and C sends an ON to another piece.
Not sure how many people use the "ON" option of an output but this is a great application. Not sure what use "OFF" does other that to clean up something visually but I'm thrilled about a perpetual ON.
Pam's managed to make an entire new module out of a bunch of spare ABC switches I had lying around. I really like passive switching and this delights me. Great work, ALM!
http://www.ep.tc/spoken-word
SPOKEN WORD WITH ELECTRONICS #20: A Tribute to Anne Sexton
