Kammerl Beat-Repeat Effect for Clouds
Hazza26
Post by Hazza26 » Wed Nov 13, 2019 10:23 am
cliffemu wrote:Hazza26
turn up the dry/wet (first) parameter or try hitting the freeze button?
Unless I'm being an idiot, I don't think there's a dry/wet control in Beat Repeat mode?
cliffemu
Post by cliffemu » Wed Nov 13, 2019 5:36 pm
It's called "slice probability" on the kammerl site
Hazza26
Post by Hazza26 » Wed Nov 13, 2019 7:12 pm
cliffemu wrote:It's called "slice probability" on the kammerl site
Gotcha, yep gave that a good wiggle.
I read on the Parasite page they recommend a recalibration after a firmware update. Might that fix it? Weird the other modes are all working though.
interpolate
Post by interpolate » Mon Nov 18, 2019 4:09 pm
The POSITION knob chooses how far into a slice to start the effect, so if POSITION is all the way clockwise, it shouldn't do anything but pass the audio through.
Also if FREEZE is turned on, then slice probability should do nothing.
Hazza26
Post by Hazza26 » Thu Nov 21, 2019 11:00 am
Just reloaded the firmware and tried again. Absolutely cannot get this to work. Tried changing all the sample rate options. The only control which does anything is the input gain! All other modes work great.
:despair:
lootacow
Post by lootacow » Thu Nov 21, 2019 11:07 am
Hazza26 wrote:Just reloaded the firmware and tried again. Absolutely cannot get this to work. Tried changing all the sample rate options. The only control which does anything is the input gain! All other modes work great.
:despair:
You put a clock into the trig input right?
Hazza26
Post by Hazza26 » Thu Nov 21, 2019 12:47 pm
lootacow wrote:You put a clock into the trig input right?
Oh FFS.. this is a new level of fuckwittery for me!
I did that on the first go, then forgot when I came back to it.
Getting my coat now...
lootacow
Post by lootacow » Thu Nov 21, 2019 12:55 pm
All good dude. We all make mistake sometimes.
lootacow
Post by lootacow » Thu Nov 21, 2019 1:31 pm
My favorite thing to do with the beat repeat firmware is to use it in conjunction with the Soundmachines Lightplane. I’m using the gate out to initiate the freeze function, Y out for size, and X out for texture. If I’m feeling crazy, I’ll run the Z to the density, or maybe the cutoff of the filter post Clouds. The LP1 makes it very “playable” especially when recording your finger movements.
jkammerl
Re:
Post by jkammerl » Tue Oct 27, 2020 11:07 am
Resurfacing this post (since I've been asked to)..
jkammerl wrote:I prototyped a new mode called: WavePicker. It's a wavetable-based two-voice oscillator that picks wave forms directly from Clouds recording buffer
Here's a temporary download link:
http://www.kammerl.de/audio/clouds/down ... re_v05.wav
Since its behavior is much more chaotic (depends on the input wave form), I'm not sure yet if this new mode is a good addition to the firmware. It would be great to hear your feedback before I officially add it to the release. What do you think?
This is how it works:
Select the mode: All but the first LED lit
These are the controls:
Position -> Position in recording buffer
Size -> Sample loop size
Pitch -> Pitch (can be 1V/Oct controlled)
Density -> Volume of second voice (same waveform)
Texture -> Relative pitch of second oscillator (mid position -> same pitch)
In addition of being an oscillator, it generates interesting sounds on beats/transients:
See also nectarios demo:
the bad producer
Re: Kammerl Beat-Repeat Effect for Clouds
Post by the bad producer » Tue Oct 27, 2020 11:16 am
:love: Amazing, thank you!
Is this mode built into the stock Beat Repeat file now? I should update if so!
col
Post by col » Tue Oct 27, 2020 6:02 pm
The temporary download link is not working.
LDT
The Modu-Lars
Re: Re:
Post by LDT » Tue Oct 27, 2020 7:03 pm
Wow, that is a cool glitch machine! Can we have an updated download link, please?
jkammerl
Post by jkammerl » Thu Oct 29, 2020 4:51 am
Ups, here's the download link for the firmware with wavpicker mode:
http://www.kammerl.de/audio/clouds/down ... v05_p1.wav
bemushroomed
Post by bemushroomed » Thu Oct 29, 2020 5:11 am
Really cool, wish there was a version for Monsoon.
Post by exper » Thu Oct 29, 2020 6:24 am
Or the super parasites firmware. :)
FS/T: Goike Folding Case / Intellijel Palette
Dedal
Post by Dedal » Thu Oct 29, 2020 8:00 am
Will you post hex version for mini clouds please? :)
PARATEK - aesthetics of the Soviet cyberpunk!
Grid: http://www.modulargrid.net/e/vendors/view/749
insta: http://www.instagram.com/paratekorg/
xcc
Post by xcc » Thu Oct 29, 2020 8:44 am
Indeed.
th0mas
Post by th0mas » Fri Nov 06, 2020 7:50 pm
If the code is available I can make it happen for monsoon at some point (no ETA)
bemushroomed
Post by bemushroomed » Sat Nov 07, 2020 1:51 pm
That'd be ace :yay:
pisrecords
Post by pisrecords » Sun Nov 22, 2020 1:12 pm
:guinness:
ADMIN in latin eurorack group . https://www.facebook.com/groups/906628619403191/
sorry 4 my poor English words.
NiteEagle
Post by NiteEagle » Mon Nov 23, 2020 8:08 am
Get it here. https://github.com/boourns/eurorack/rel ... rmwares_v1
Chief circuit wrangler at SDIY Chicago
bemushroomed
Post by bemushroomed » Mon Nov 23, 2020 11:37 am
Get what? Nothing updated or new there from what i can see?
