New Erica Synths drum sequencer
ggillon
Post by ggillon » Sat Apr 06, 2019 4:35 am
First time I tried to use patterns to build a song instead of just playing with mutes and it turns out nice:
https://soundcloud.com/gautier-gillon/adam
qwertyuiop
euclidean rhythms
Post by qwertyuiop » Wed Apr 10, 2019 1:46 pm
I've been eyeing one of these. Is it possible to get euclidean patterns out of this sequencer? I see that you can adjust individual track step count, but wasn't sure about the timing.
akavalve
Post by akavalve » Wed Apr 10, 2019 4:00 pm
ggillon wrote:First time I tried to use patterns to build a song instead of just playing with mutes and it turns out nice:
I dig that! Your other tracks as well.
How you are making you kicks in general?
They're nice.
ggillon
Post by ggillon » Wed Apr 10, 2019 4:21 pm
They're nice.
Thank you! Kicks are usually either the Basimilus Iteritas Alter, either the Erica Synths Bass Drum. In the track above I start with the BIA and end with the bass drum
kodek
Post by kodek » Thu Apr 11, 2019 9:48 am
Hey,
Thanks to everyone for the good and also the bad feedback.
We are working hard to make the unit work as tight as possible in every setup!
So here is a new update for it >>
Drum Sequencer firmware 1.054
FIXES / IMPROVEMENTS:
- Improved MIDI sync
- Improved overall stability of the sequencer
- Fixed losing note on CV track when editing other CV track bars
- Fixed CV Tap Screen
- Minor bug fixes
FEATURES:
NEW CLOCK OUT SETTINGS
12PPQ, 24PPQ and 48PPQ clock out settings added.
COPY PATTERN TO A NEW LOCATION WHILE PLAYING
In pattern play mode press & hold the COPY key and choose the destination pattern with STEP KEYS.
Copy of the current playing pattern will be saved to chosen destination. A [COPIED!] splash screen will appear.
STEP COPY
In STEP EVENTS page hold COPY and then select the step you want to copy with STEP KEYS.
Then press and hold the desired slot where you want to paste the copied step and press PASTE.
"OCTAVE" AND "ROOT NOTE" SETTINGS
These can now be accessed from the CV track SCALE screen and also the CV TAP mode
KEYBOARD TRANSPOSE IN CV TAP MODE
Press COPY to decrease keyboard by -1 octave, press PASTE to increase keyboard by +1 octave.
Download SysEx for update via MIDI HERE
Download HEX for update via AVR programmer HERE
And as always if you're having trouble with updating or have any other questions regarding the unit please don't hesitate to contact me directly.
:drums:
Mal uns
Post by Mal uns » Sun Apr 14, 2019 12:12 pm
checked the new update. midi sync is waaayyy more stable then before here. i had to readjust timing after every stop.. thats not an issue anymore! :yay:
resynthesize
Post by resynthesize » Sun Apr 14, 2019 1:56 pm
kodek wrote:Hey,
- Minor bug fixes
FEATURES:
STEP COPY
:drums:
you guys are crushing it! thanks for your continuing support of my favorite trigger sequencer.
Nait
Post by Nait » Wed Apr 17, 2019 2:19 am
Thanks Kodek!
batch
Post by batch » Fri Apr 19, 2019 8:47 am
Holy shit that’s a big update! Nice work Kodek!
FS: Erica Synths Hi-Hats D $175, Cymbals $175, Stereo Mixer v2 $100, Intellijel 1U Pedal IO $70, MIDI $110, Rebel Tech Bit Reactor $95
Carmelo_P82
Post by Carmelo_P82 » Fri Apr 19, 2019 4:17 pm
Wow, didn't see it. Will check it out, thank you Kodek ! :yay:
Carmelo_P82
Post by Carmelo_P82 » Mon Apr 22, 2019 11:52 am
Did someones change the clock out ?
I didn't find the settings : 12PPQ, 24PPQ and 48PPQ clock out settings added.
Thank you
Tumulishroomaroom
Post by Tumulishroomaroom » Mon Apr 22, 2019 4:42 pm
It's on the master page under CLK. Just scroll with the right encoder.
freerider197
Post by freerider197 » Tue Apr 23, 2019 4:12 am
Thanks Kodek for such an amazing update.
I love to have some fresh new features every now and then. I have the feeling this Sequencer can store so much power in it that we are just scratching the surface.. copy/paste features over pattern/steps is a good start.
Let me tell it here, what would be crazy and amazing would be to be able and record CV over the cv track via the encore. Very much like you can do on Voltage Block/Mimetic Digitalis... thought?
Keep up the good work :)
Jack
Carmelo_P82
Post by Carmelo_P82 » Tue Apr 23, 2019 3:59 pm
Tumulishroomaroom wrote:It's on the master page under CLK. Just scroll with the right encoder.
:bang: I think I was tired, how can I miss it.
Thank you !
denuir
Post by denuir » Sat Apr 27, 2019 6:24 pm
+----EDIT----+
I got it to work: For anyone using Bome SendSX you can drag the throttling slider all the way down to 313 bytes and be sure to uncheck "Split long messages when sending (work around faulty MIDI drivers)"
Hope that helps someone!
+----EndEDIT----+
Late the the party, but has anyone updated the firmware on the Drum Sequencer using Windows?
I have attempted updating via MIDI-OX, the buffer size of which I can set to 64 bytes but seems to send the information too quickly anyway. Only the first 3 rows of step trigger lights finish lighting up.
I've also used Bome SendSX but it will only allow me to reduce the buffer size to 313 bytes. Hope I can get this working, as the drum sequencer is bricked until I can : :confused: :waah:
hru
Post by hru » Sat Apr 27, 2019 6:59 pm
--- Edit -----
Sry I m to late
Maybe it works with the Elektron C6 Tool (No Erica Synths drum sequencer here but also problems before with Firmware update - Bome SendSX and Midipal)
https://www.elektron.se/wp-content/uploads/2016/05/Elektron_C6_MAC_AND_WIN_1.51.zip
https://mutable-instruments.net/archive/midipal/firmware/
denuir
Post by denuir » Sat Apr 27, 2019 7:20 pm
This is still helpful @hru
I'll gladly add another Sysex manager to my arsenal. Thank you!
resynthesize
Post by resynthesize » Wed May 01, 2019 12:24 am
I am trying to figure out how song mode works. The manual is a bit cryptic, but from my reading, it sounds like you can chain together patterns in an arbitrary order and loop each pattern an arbitrary number of times before proceeding to the next pattern, but I'm not having any luck getting it to work.
Here is what I did to set up my song:
* Create two patterns in slots A1 and A2 with some trigger data
* Enter song write mode by pressing shift+bank
* I left the "SNG" and "LEN" paramaters at the default (1)
* For POS 1, i choose pattern A1
* For POS 2, I choose pattern A2
* I enter song play mode by pressing shift+bank again and press play to start the song.
* It looks like the song play display shows the current position and pattern, but it never changes, and I just hear the pattern at position 1.
Anyone know what I'm doing wrong? (or maybe nothing, and this is a bug?)
Tumulishroomaroom
Post by Tumulishroomaroom » Wed May 01, 2019 6:44 am
The Clock setting doesn't seem to save with the latest firmware. I have to set it up to 48pp ever time I turn on my synth. Not a crazy problem, but it would be perfect if it were ready to go :)
batch
Post by batch » Wed May 01, 2019 8:31 am
resynthesize wrote:I am trying to figure out how song mode works. The manual is a bit cryptic, but from my reading, it sounds like you can chain together patterns in an arbitrary order and loop each pattern an arbitrary number of times before proceeding to the next pattern, but I'm not having any luck getting it to work.
It’s counter intuitive, but works as follow.
SNG = the song number
LEN = total number of positions in the song (for your example you need this to be at least 2)
POS = the position itself
PAT = what plays
So to assuming you have patterns that are each a bar long and you want to create an 8 bar song, you set LEN=8, then choose the pattern you want in POS=1 (ie bar 1), POS=2, etc.
Personally have asked (a long way back in this thread) to change the implementation to be
SNG=Song number
POS=position/ part
PAT=the pattern to play
RPT=number of times the pattern repeats in that position
I think this would be more intuitive and have better workflow
resynthesize
Post by resynthesize » Wed May 01, 2019 8:14 pm
PAT = what plays
SNG=Song number
POS=position/ part
Thanks! Yeah, a dedicated repeat parameter would be much more easy and intuitive than duplicating song positions when you want to repeat a pattern.
Yloopz
Post by Yloopz » Thu May 09, 2019 8:59 am
So... search is broken, I didnt read the whole thread and I scanned the manual... but is there a choke function?
My imagination is my inspiration...
Instagram: @jungleofwires
batch
Post by batch » Thu May 09, 2019 9:20 am
What’s a choke function?
If you mean muting then yes. The muting capabilities are awesome.
batch
Post by batch » Thu May 09, 2019 9:24 am
Kodek - I’ve noticed two things on 1.054.
#1 - clock doesn’t save setting. I like using the 24ppqn setting to sync Pam’s but find that I have to set it each time. The setting isn’t saved despite hitting the record button
#2 - have had a bug where I couldn’t get back into the settings menu. Had to power cycle the module to resolve. This is the first bug I’ve seen in a long time.
Hope this helps.
Tumulishroomaroom
Post by Tumulishroomaroom » Thu May 09, 2019 10:19 am
I have #1 too.
