First look at the Instruo Harmonàig harmony quantizer
behndy
Re: Re:
Post by behndy » Fri Feb 07, 2020 4:00 pm
davidjames wrote:
Fri Jan 31, 2020 9:50 pm
behndy, thanks for reminding me I have this idea to try. Maze looks pretty great and it would offer a different spin on dcbb's patch. You wouldn't be able to have more than 4 inputs, but with mixing and routing there's tons of possible variation. And a quantizer after maze would be good to keep things in scale, if thats your bag. Also, Maze just looks super useful for all sorts of other patches. My wallet hates you right now.
i'm HELPING!
music, noise, in progress silliness - http://www.youtube.com/c/behndy
hel1
Re: First look at the Instruo Harmonàig harmony quantizer
Post by hel1 » Sun Feb 09, 2020 5:24 am
Mannstrane wrote:
Fri Feb 07, 2020 12:44 pm
Had a noobie question to ask for anyone who owns a Harmonaig.
I am looking to take a CV sequence from an Eloquencer into the Harmonaig that then goes out multiple CV voice inputs to Chainsaw. The Harmonaig seems to have a very hard time tracking and holding the quanitzed CV signal. Even when adjusting the bias knob on the Harmonaig.
Example would be: Sequence Eloquencer for C1 C2 C3 C4. Harmonaig will randomly skip C1 and go C1# or B1. Seems to have a much harder time tracking at lower voltages.
I will try to reproduce this for you when I'm back next week, but I don't remember having this problem at all
Catchthehare
Post by Catchthehare » Mon Feb 10, 2020 5:33 am
I can send a quantized CV (Eloquencer) to Uscale II without it drifting.
Unquantized CV from Pressurepoints, o_C (Sequin) work with Harmonaig.
Is this something that everyone just lives with? Is this normal behavior for the Harmonaig?
Thank you
I have this issue when using sequencers, that the notes would flicker between each other and it is tricky to get Harmonaig to track accurately. If I turn up the CV attenuator all the way up then Harmonaig tracks accurately, and then I can pitch down octaves as needed. I don't know if something is amiss with my unit of if this is typical behaviour? Seems a little extreme that Harmonaig will only track accurately if the attenuator is all the way +
Mannstrane
Post by Mannstrane » Mon Feb 10, 2020 12:51 pm
Yes. Sounds exactly the same behavior as mine. I guess the only way to sequence with it would be unquantized sequence such as Pressure Points. Kind of a bit more work when you already have a mono sequence playing from a quantized source and just want chords to go with it. Even though I can't stand uScale II for the menu's being a pain. The uScale II can take a quantized cv input without loosing tracking.
I wonder if a firmware update from Instruo could have it work better with quantized CV input. Has anyone contacted Instruo about this?
pelang
Post by pelang » Mon Feb 10, 2020 3:07 pm
Just checked with a ER-101 sequencer and harmonaig tracks fine here. Maybe a "scratchy" potentiometer? Did you try to wiggle it 30-40 times back and fort ?
Arneb
Post by Arneb » Mon Feb 10, 2020 3:43 pm
Unless you're having something interposed between the Eloquencer and Harmonaig, having Eloquencer transpose the whole sequence a couple cents up or down might fix it.
(I don't know Eloquencer, but I guess your average feature monster sequencer can do this.)
Naenyn
Post by Naenyn » Mon Feb 10, 2020 3:59 pm
A patch question regarding the Harmonàig. I recently got mine .. and was thinking it'd be neat to patch the four quantized outputs to one oscillator via a sequential switch. I am using a MTM Turing Machine to create a melody, which is then quantized by the Harmonàig. What I'm stuck on though is how to trigger quickly playing back the four notes via the switch then stop after the four notes have been played. I feel like I need some kind of toggle that switches off a gate after 4 triggers .. but not sure how I could accomplish that. Any thoughts? :hmm:
-n :ninja:
My for sale thread
My generative / synth eurorack on Modulargrid
1U Tile Rack | 60hp Overflow Pod
You can also find me on MuffWiggler's Discord
davidjames
Post by davidjames » Mon Feb 10, 2020 11:45 pm
One way would be a burst generator (see the notes above in the thread re: the strum patch). I use the Noise Engineering Variatic Erumption which allows you to set the length of the burst. It also has preset burst rhythms which you can choose from, syncs to a clock, is two channels, and has an end-of-burst gate out, which I use to reset my switch. :party:
FS: DSI Pro 2, Mutable, more!
viewtopic.php?p=3062675
Naenyn
Post by Naenyn » Tue Feb 11, 2020 2:57 pm
Thanks for the tip! I will check it out.
When I was originally working on the problem, I had resetting figured out.. but now I can't remember how I was going to handle that.. never mind how I'd handle start/stop and loop length. It seems like a sequential switch would be perfect for routing the pitch CV, but my brain is failing on the logic. :bang:
-n :ninja:
My for sale thread
Mannstrane
Post by Mannstrane » Wed Feb 12, 2020 1:10 pm
I haven't tried rocking it back and forth 30-40 times. Will have to try that. So if you have 16 steps with 4 notes C0 C1 C2 C3 with the ER-101 and all Harmonaig notes selected, you don't have any tracking issues?
If I turn the bias knob counter clockwise its pretty unstable. If I turn it clockwise, then it does better but I'm transposed higher. I have an ER-101 on order. Problem is, when I get the ER-101, I will be out of my 30 days for returning the unit back to Perfect Circuit. All quantized CV sequencers I have exhibit the same issue. (Eloquencer, FLXS-1)
pelang
Post by pelang » Wed Feb 12, 2020 2:09 pm
yes, C's on a few octaves. However, as I used the attenuator I hade to "find" the C's with the ER-101. After that it was stable.
My point is if your potentiometer is "scratchy" it would mess up the incoming CV. Wiggle the poti can help sometimes.
hel1
Post by hel1 » Mon Feb 17, 2020 2:48 pm
no, sorry, mine behaves very well
Mannstrane
Post by Mannstrane » Mon Feb 17, 2020 7:01 pm
Here is a video:
C0-C3. I go to match output octave of Eloquencer and Harmonaig can't hold the notes. Works at higher octave offset but not lower.
Naenyn
Post by Naenyn » Tue Feb 18, 2020 2:00 am
I wouldn’t worry too much about this. Jason @ Instruo is pretty amazing. I bet he can help.
-n :ninja:
My for sale thread
pelang
Post by pelang » Tue Feb 18, 2020 6:06 am
Here is a video:
I don't think Harmonaig is calibrated by nature to a 1V/Oct. You may need to dial in from your sequencer the right voltage to get the C's from Harmonaig.
BTW: you can as well double tap on the buttom to have fine-tune and course.
Mannstrane
Post by Mannstrane » Wed Feb 19, 2020 1:58 am
Got quantize to work! Jason had me clear the offsets by holding transpose and pressing C twice. I don't remember ever storing offsets originally. Thanks for everyone's help!
