modules with 3.5mm TRS MIDI jacks
kay_k
Post by kay_k » Tue Oct 31, 2017 7:09 am
Paranormal Patroler wrote:The SDS VCO can be soldered either way, so it's not Arturia.
ok!
kay_k
Post by kay_k » Tue Jan 23, 2018 3:21 pm
I've added Twisted Electron to the list. Has anyone an idea what pin config they are using?
kay_k
Post by kay_k » Wed Mar 14, 2018 8:27 am
I contacted Twisted Electron .. no reply :(
kay_k
Post by kay_k » Wed Mar 14, 2018 8:28 am
Regarding MFB here some useful info in this thread:
viewtopic.php?p=2781397#2781397
kay_k
Post by kay_k » Thu Apr 19, 2018 2:28 pm
Added the Pittsburgh Sequence Designer 128
kay_k
Post by kay_k » Mon May 07, 2018 6:34 am
I have worked my own table on the Superbooth18 and haven't had the time to walk around looking for new modules with MIDI.
So if you have seen new modules please reply so I can add them.
I went to twisted electrons and asked them about their polarity but forgot his reply.
brandonlogic
Post by brandonlogic » Mon May 07, 2018 7:08 am
Zetaohm - FLXS1 Voltage Sequencer (Korg pole)
kay_k
Post by kay_k » Mon May 07, 2018 8:19 am
brandonlogic wrote:Zetaohm - FLXS1 Voltage Sequencer (Korg pole)
oh, I've seen that around before and forgot to add it. Thanks.
Paranormal Patroler
Post by Paranormal Patroler » Mon May 07, 2018 2:56 pm
New Pittsburgh sequencer is Arturia. According to them MIDI association decided that they're standardizing the Arturia mapping.
Korg is too busy fighting with the manufacturers who don't appreciate TRS MIDI to begin with :hihi: Weird choice if you ask me.
kay_k
Post by kay_k » Tue May 08, 2018 7:32 am
Paranormal Patroler wrote:New Pittsburgh sequencer is Arturia. According to them MIDI association decided that they're standardizing the Arturia mapping.
tbh I am surprised to see that many "polyphony" modules nowadays that don't offer at least a rudimentary midi support.
It would really mean less cables in the system, while it would only take a jack.
If I were to make a multi VCO or ENV I'd add this and maybe even a thru port for daisy chaining.
av500
Post by av500 » Wed May 09, 2018 3:44 pm
trig31: Arturia
kay_k
Post by kay_k » Wed May 09, 2018 3:46 pm
av500 wrote:trig31: Arturia
top!
euromorcego
Re: modules with 3.5mm TRS MIDI jacks
Post by euromorcego » Fri May 11, 2018 3:44 am
kay_k wrote: - Faderfox SC4 (I/O; Arturia?)
it is tip = pin 4, ring = pin 5, the Arturia adapter works.
Paranormal Patroler
Post by Paranormal Patroler » Fri May 11, 2018 4:08 am
kay, are you gonna make adaptors ?
Morphology
Post by Morphology » Fri May 11, 2018 7:10 am
The new Dreadbox Lil' Erebus has a 3.5mm MIDI In.
I've bought a kit, but haven't built it yet, so I don't know the polarity of the MIDI Jack.
Looking at screenshots of the PCB, it looks like it's Mono (Tip-Sleeve) Style, rather than TRS?
When I get a moment I'll check.
Edit: I Checked:
T: 5
R: 4
S: N/C
Morph
There are only 10 different types of people: Those who understand binary, and those who don't
kay_k
Post by kay_k » Mon May 14, 2018 7:38 am
Paranormal Patroler wrote:kay, are you gonna make adaptors ?
those little gender changer ones? dunno if it is worth the work, I can't see to make money with them.
kay_k
Post by kay_k » Mon May 14, 2018 7:52 am
Morphology wrote:The new Dreadbox Lil' Erebus has a 3.5mm MIDI In.
Edit: I Checked:
T: 5
R: 4
S: N/C
Morph
thanks..
I think that makes it Korg standard but my brain doesn't cope with the heat so well.
strangegravity
A Big Knob
Post by strangegravity » Mon Jun 04, 2018 1:11 pm
Is this correct? I'm going to slap a full sized jack on the side of my case and solder it to the bottom of an Arturia style 3.5mm MIDI. Which pins do I need to connect? I could put my cable on the meter and find out but if anyone knows ..........
strangegravity
A Big Knob
Post by strangegravity » Tue Jun 05, 2018 3:34 pm
MIDI.org says Arturia goes like this:
cathmart
Post by cathmart » Thu Jul 12, 2018 3:20 am
so i'm having trouble connecting my Beatstep pro MIDI cable to the MFB Nanozwerg Pro MIDI.
I see from this thread its an issue of
Polarity TRS Arturia:
and
Polarity non-TRS (a.k.a. MFB):
so what can I do to connect these two?
Seaweed Sound
Post by Seaweed Sound » Thu Jul 12, 2018 3:31 am
Look for a TRS polarity reversing adapter or make a custom TRS cable with the polarity (pins) swapped.
A better solution is perhaps to get a MIDI to TRS adapter for each device and then connect with a standard MIDI cable. That way if you decide to use alternate MIDI setup in the future you can always connect anything you want or you can easily get MIDI cable of desired length should the physical layout change.
kay_k
Post by kay_k » Thu Jul 12, 2018 4:22 am
cathmart wrote:so i'm having trouble connecting my Beatstep pro MIDI cable to the MFB Nanozwerg Pro MIDI.
and
you can just use the arturia TRS-DIN adapter and the MFB TS-DIN adapter and standard DIN MIDI cable between them.
Or you make your own adapter cable (connect as said above, measure with a diode tester which pin goes where, make custom cable to this measurement)
strangegravity
A Big Knob
Post by strangegravity » Thu Jul 12, 2018 3:43 pm
strangegravity wrote:MIDI.org says Arturia goes like this:
If I add a through jack next to this would I just jumper the same pins?
SOPiiAC
Post by SOPiiAC » Tue Mar 05, 2019 10:21 am
The new OP-Z oplab module has trs midi in and out.
kay_k
Post by kay_k » Wed Mar 06, 2019 4:46 am
Yes and no - It might work when split passively or maybe not, depending on your MIDI inputs. Some require more current then others. Usually a thru is actively buffered post optocoupler.
You could just buy our WK3 thru module ;)
