1010 music synthbox
- Jumbuktu
- Super Deluxe Wiggler
1010 music synthbox
https://www.modulargrid.net/e/1010-music-synthbox
Just saw this on modulargrid. Has it been around for a while and I just missed it?
Re: 1010 music synthbox
Not available until 2nd October 2017, the 1010 web site says. But yeah, it looks very tasty indeed.Jumbuktu wrote:https://www.modulargrid.net/e/1010-music-synthbox
Synthbox
It really sounds great!
"C’est l’histoire d’un homme qui tombe d’un immeuble de cinquante étages. Le mec, au fur et à mesure de sa chute il se répète sans cesse pour se rassurer : jusqu’ici tout va bien, jusqu’ici tout va bien, jusqu’ici tout va bien.
Mais l'important n’est pas la chute, c’est l’atterrissage."
The three options of sample, fx, or synth look great.
Apart from the front panel, what else is different between the hardwares?
Im thinking for example of SD card contents, display colour ecc.
Check my links - videos and tracks:
My Instagram
Videos on Vimeo
Soundcloud Playlist - Materiale Elettrico
My Instagram
Videos on Vimeo
The hardware on each of these is the same. The included firmware and content are different. So is the quick start guide. You can download all of this from our forums upon registering.Anechoic wrote:The three options of sample, fx, or synth look great.
Thank you.
The current version has AC coupled inputs, so an oscilloscope is impractical. We will keep your suggestion in mind for next time. Thanks for making it.rayultine wrote:1010: are the converters and display on the xyzbox fast enough to act as an oscilloscope? Are inputs DC coupled? Cause that would be an amazing alt firmware
- Learning to Wiggle
- 2disbetter
- Ultra Wiggler
As of right now it takes around 2-5 seconds for a sound change. The GUI will say it is still loading but if you start hitting keys the sound is already there usually a second or two after hitting load.
I don't believe because of all of the various components of each sound (filter, envelopes, lfos, effects, modulation, etc.) that quick loading like braids or plonk is really all that practical/possible.
It really is much more like a full synth than a mere oscillator.
2d
2d
Yes, it has to load all 4 voices separately, and there's 12 oscillators in total, plus all of the other stuff, like you say... That's why it takes a few seconds, I think.2disbetter wrote:As of right now it takes around 2-5 seconds for a sound change. The GUI will say it is still loading but if you start hitting keys the sound is already there usually a second or two after hitting load.
- 2disbetter
- Ultra Wiggler
Absolutely! I just plugged in gate, cv, velocity, and aftertouch into the synthbox and out of the box (inconjunction with a expert sleeper fh-1) was getting full MPE based expression out of it. Was very nice and surprisingly convenient to have all of the components (filter, envelopes, etc.) within one module.DruidTek wrote:So far my favourite feature of synthbox is how things can be modulated in both positive and negative values by 3 different sources at once. Using this in conjunction with the dual filters/envelopes leads to some really deep and expressive sounds!
2d
Hippasus,hippasus wrote:This module sounds very interesting, could somebody tell me if audio rate modulation at the cv inputs is possible. I am thinking on fm.
I am sorry to report that the CV inputs are at a slower rate suitable for LFOs and envelopes. You'll have to find another way to do FM.
Thanks for the question,
Aaron
Flipped UI mode for synthbox is now available for registered users.
https://forum.1010music.com/forum/produ ... 1-0-5-beta
I'm surprised there is almost no discussion here about this module - or am I overlooking something?
Anyway, here are my first impressions. I am normally running a bitbox firmware on my series 1 module, but wanted to give synthbox a try.
Synthbox is not as self-explanatory as bitbox, IMO, especially the 4 voices architecture. Almost impossible to understand without reading the manual. I mean, no problem with manuals, just saying.
You can choose input routing between
- "Global", ie 1 set of cv inputs in common for all 4 voices. Only makes sense, at least to me, when using MIDI inputs, because then you have 4x polyphony, whereas with cv/gate inputs you end up with 4 copies of exactly the same single monophone voice (really?)
- "Per Voice", ie 4 sets of cv inputs for 4 voices, 1 set for each voice. Mostly makes sense, at least to me, when using cv/gate inputs, because with MIDI inputs you still have 4x polyphony but the flow of notes then "cycles" through 4 different sets of cv modulation - quite unusual.
In either mode, all 4 voices share the same identical sound configuration: the selection of 2 wavetables plus 1 osc, base note, mix levels, even the mapping of the 2 universal lfo's and 2 eg's as well as 3 ext cv mod inputs. You cannot configure a single voice separately. This is probably the biggest surprise, and also a bit disappointing.
So, in "Per Voice" mode, you could play chords using different note cv's (from Triad, for example) and mult the single gate.
Or you could map one of the mod cv input columns 1-3 to pitch (you would have to do this separately for each wavetable and the osc btw) and use a different cv in each row to get a hover or drone sound. You'd also need to physically mult to all note and gate cv ins. You cannot detune or FM the individual voices directly.
Apart from that, I found the built-in lfo's a bit restrictive: the frequency range is specified as 0.1hz - 12hz, and it cannot be modulated. I found most presets to be rather experimental for my taste. And because of the general concept of menu diving and context sensitive knobs, it was all in all a bit difficult for me to get where I wanted, although I wouldn't really call this a complex module either.
Having said all that, I still think this firmware has a lot of potential and sounds quite nice. And comes free of charge for bitbox users.
Really? I asked a question about this on the 1010 forum (I don't have a v1 xyzbox yet - so close to saving the $ though!) and I interpreted Aaron's answer as the synthbox could behave like the Korg Mono/Poly where each successive note would cycle through the four voices.dbeats wrote:you cannot configure a single voice separately. This is probably the biggest surprise, and also a bit disappointing.
... You cannot detune or FM the individual voices directly.
Thats sort of accurate. It does cycle through the four voices, and each voice can have different mod sources connected - so if you had four different (external) envelopes controlling the cutoff frequency of the filter, you would be able to cycle through and hear each voice responding differently to the external modulation. But... it isn't multitimbral. So you can't have a different patch using different oscillators etc... on each voice. (Would be awesome if you could).rayultine wrote:Really? I asked a question about this on the 1010 forum (I don't have a v1 xyzbox yet - so close to saving the $ though!) and I interpreted Aaron's answer as the synthbox could behave like the Korg Mono/Poly where each successive note would cycle through the four voices.dbeats wrote:you cannot configure a single voice separately. This is probably the biggest surprise, and also a bit disappointing.
I was really not expecting much from synthbox, it took me a long time to even bother trying the firmware. I have a lot of "real" synths
and didn't see what synthbox would bring to the table. That being said - I was pleasantly surprised. I think that Aaron and co. made a good decision to use wavetables as the oscillators, as it kind of sets it apart from the other "all in one" semi modular synths available in euro. In some ways it reminds me a lot of an esq-1 in a tiny box, in my rack! (Which is awesome btw... I LOVE the Esq-1). The editing is a bit like the elektrons, 1 screen for each subsection, and if you know synths it's pretty fast and intuitive. There is definitely still stuff to improve, and tbh I'm not sure that I would buy synthbox in it's current state if you didn't get bitbox included for the price. But overall I think it's a really nice addition to the line, and I hope that they continue to work on it, it has alot of potential.
- 2disbetter
- Ultra Wiggler
One thing I think that should be mentioned is that the synthbox works intuitively with mpe control either via cv (5 inputs per voice) or via midi through a proprietary TRS to DIN cable. You can map the inputs to essentially anything
It is a synth completely contained in the module that just happens to exist in the eurorack format. Pretty great.
2d
2d
