4ms & Matthias Puech — Tapographic Delay
williamjturkel
Post by williamjturkel » Sun Feb 11, 2018 3:40 pm
I hope 4MS sends some of these to Moog Audio soon. I bought one at the beginning of December and I am still waiting for it :sadbanana:
Hovercraft
Post by Hovercraft » Tue Feb 13, 2018 9:44 pm
Nervously tapping (in unquantized fashion), waiting for the firmware update. :lock:
LostForWords
Post by LostForWords » Wed Feb 14, 2018 8:20 am
The Tapo is a great module. Looking forward to the update.
This is an evolving piece using the Tapo that I made recently. Two thirds in I flip the repeat and let it build and layer before cutting the Tapo feed, then bring it back in with some subtle modulation.
SynthEnergy
Post by SynthEnergy » Thu Feb 15, 2018 12:43 am
LostForWords wrote:The Tapo is a great module. Looking forward to the update.
Yeah that was amazing! Well constructed with a great progression through various themes and moods. A piece that evolves over time is gold!
LostForWords
Post by LostForWords » Thu Feb 15, 2018 6:51 am
SynthEnergy wrote:Yeah that was amazing! Well constructed with a great progression through various themes and moods. A piece that evolves over time is gold!
Thank you! I agree about evolving music, makes a piece interesting even if the melody doesn't change.
L.C.O.
Post by L.C.O. » Sun Feb 18, 2018 6:42 pm
mqtthiqs wrote:Hey all,
L.C.O., the update is ready, it just needs a bit more testing and NAMM arrived a bit too fast. In the meantime, I can maybe recommend to watch your gain staging: the loud noise is not louder than the maximum output volume of the Tapo; if you experience such a contrast between your input sound and the noise, maybe your input sound was so low that you had to crank your monitoring up? By amplifying your source and not your output you generally get better SNR, and in this case less contrast between loud and normal volumes...
Ptbarnum AFAIK volume drops cannot be attributed to power supply. Maybe your taps have too low velocity? Try adjusting the velocity parameter.
playthefivetones have you tried to unplug all other modules from your case, and see if it persists? If it does and if it's an inconvenience, 4ms will be help you troubleshoot.
resynthesize the "warble" effect from turning Time is inherent to the processing algorithm. I don't consider it an artifact, but the "natural" way a Time knob functions (similar to tape delays). The DLD solves this by cross-fading between discrete time values... which is exactly what happens when you morph between two tapographies. You could record a few tapographies of the same pattern at different speed, and use a short Morph time to get the same effect. That said, it can also be a lot of fun to e.g. modulate Time with a very slow random CV; with lots of feedback you can get interesting "paradoxical tones" effects out of simple drones :party:
Hope it helps!
Any chance we can see the update soon?
Thank you!
p.
mqtthiqs
Post by mqtthiqs » Mon Feb 19, 2018 5:34 am
L.C.O. wrote:Any chance we can see the update soon?
Expect it any day (it's in the hands of 4ms now).
L.C.O.
Post by L.C.O. » Mon Feb 19, 2018 9:35 am
Wonderful news!
Thank you!
Ptbarnum
Post by Ptbarnum » Mon Feb 19, 2018 10:30 am
:yay:
Kingnimrod
Post by Kingnimrod » Sat Feb 24, 2018 9:25 pm
Looking forward to it myself.
Any news?
4mspedals
Tapographic Delay Firmware v1.1
Post by 4mspedals » Wed Feb 28, 2018 6:48 pm
It's here!
Tapographic Delay firmware v1.1 is ready!
Here's the firmware wav file (right-click to download, don't blast your speakers by playing this!):
http://4mspedals.com/TAPO/firmware/tapo ... e-v1_1.wav
The change log:
http://4mscompany.com/TAPO/firmware/tap ... -v1_1.html
A video showing how to update:
and a video showing off one of the coolest new features: Quantization!
Ptbarnum
Post by Ptbarnum » Wed Feb 28, 2018 9:10 pm
Sweeet :nana:
L.C.O.
Post by L.C.O. » Wed Feb 28, 2018 10:29 pm
Fantastic!
Thank you!
Hovercraft
Post by Hovercraft » Wed Feb 28, 2018 11:36 pm
Thank you! The upgrade adds some great features. Did some testing this evening, and I find the Tapo much easier to control—the output is crisper tighter.
nihilicious
Post by nihilicious » Thu Mar 01, 2018 12:47 am
Very pleased with this, works great so far! Thanks for your hard work and listening to feedback.
Kingnimrod
Post by Kingnimrod » Thu Mar 01, 2018 1:16 am
thanks! great update!
resynthesize
Post by resynthesize » Thu Mar 01, 2018 3:19 pm
updated the firmware this morning - new features sound great but I scared the living shit out of myself when I switched presets and a blast of noise came out that was waaaaay louder than the input signal. It doesn't happen for every preset, I'm not sure what is different about the one that is causing problems. Here's a quick vid to demonstrate the issue (watch your volume). The morph knob affects how long the blast lasts for.
Cortega
Post by Cortega » Fri Mar 02, 2018 1:34 pm
Edit : Solved
loorenz
Post by loorenz » Fri Mar 02, 2018 7:18 pm
Cortega wrote:all the preset sounds a bit different due to new Gainstaging i think, and sadly not in a good way, and morphing through the presets gets more clicks then before the update, thinking of downgrading
Same problem here… is there a way to download the 1.0 firmware wave file ?
I can't find it.
Ivan Sokol
Post by Ivan Sokol » Sat Mar 03, 2018 7:10 am
Same here, some presets just give out extreme distortion, please upload Firmware 1.0.
Wiresandones
Post by Wiresandones » Sat Mar 03, 2018 1:40 pm
This is disheartening... hope they can fix it.
Also bumping so 1.0 will be made available.
SynthEnergy
Post by SynthEnergy » Sat Mar 03, 2018 6:10 pm
Just deleted all the presets partially for this reason. What they could do is remake the presets to better reflect the new firmware. That would be ideal.
mqtthiqs
Post by mqtthiqs » Sat Mar 03, 2018 7:54 pm
:eek:
Ok.
1/ No need to jump on the tables. Everything is reversible, and of course we will do all we can to fix anything we might have missed. I've played with the Tapo on v1.1 for almost a month and did not notice anything like you describe.
2/ The tapographies don't sound any different in v1.1 than on v1.0 simply because they were not modified. Just to make sure I just A/B'ed all tapographies from Bank A on a simple source in both versions, at 0 and 50% feedback. I spent quite some time listening to the Tapo, and I cannot distinguish them.
3/ Yes, the output has been made a bit louder; because of soft clipping, this can lead to a bit more saturation with a loud input, but nothing that could qualify as "extreme distortion". For instance with my loudest VCO, inputting a sine at full blast I get about -50dB harmonic distortion. If you want v1.0 behavior, just turn down Level or attenuate the input, it is strictly the same.
4/ That said, there might be something we oversaw! Can you guys SynthEnergy Wiresandones Ivan Sokol loorenz
Cortega send me an email to 4ms, possibly with a recording showing the problem on a simple input and steps to reproduce? We'll look into it as soon as we can.
FrogStar
Post by FrogStar » Sat Mar 03, 2018 11:58 pm
For what it’s worth, I just spent over an hour with the new firmware and a variety of clean sine sound sources. I was very happy with the results. Any noise, pops or clicking I experienced was removed by reducing the level.
wanne
Post by wanne » Sun Mar 04, 2018 11:42 am
:deadbanana:
for me the wet / dry is not working anymore after the update !?
i dont get a dry signal anymore !
