BumpParanormal Patroler wrote: ↑Fri Nov 01, 2019 4:03 amDid the Summing option which was planned for 2018 ever see the light of day?![]()
SSSR Labs SM010 Matrixarchate
- Common Wiggler
Re: SSSR Labs SM010 Matrixarchate
How does this module handle audio distribution? Do you get clicks when sequencing through presets?
@rpocc: voltage protection would be very welcome! For such a low price, it's a no brainer.
- Common Wiggler
hello! hello! bumping this thread
- Common Wiggler
Question to owners. Is it possible to set the module to behave, for example, like this too:
I have two sources connected to ports 1 & 2;
I have a destination connected on port A;
I activate routing pressing 1A;
then, when I activate 2A, 1A gets deactivated.
So essentially I would like to exclusively route two sources to a single destination, without having to necessarily rely on presets for this and instead using the interface itself.
Thank you
Thank you
- Learning to Wiggle
I believe this is the supposed future integration of "summing" which it currently cannot do IIRC.musicaespressiva wrote: ↑Wed Apr 08, 2020 12:15 pmQuestion to owners. Is it possible to set the module to behave, for example, like this too:
Thank you
I built a DIY one, everything works, but the bottom LED array is just always lit on every LED. Triple-checked every solder joint and IC orientation. Is it just a bad part? Before I rip it out and try to find a replacement..both of which difficult.
any news? I can't find any alternative for this excellent module.
- deftinwulf
- Veteran Wiggler
I certainly hope this module comes back into production at some point. Really a beautiful thing.
I am in need of one of these, and waiting patiently for kits to come available. I (sadly) see others bumping this thread to no response over some time now. I'll be waiting, and looking
great module , world needs more
FYI- a few kits came to SynthCube, I grabbed one and it sure is nice!
- Buttons ARE toys
- Wiggling with Experience
How do you find out what the output impedance of your modules are? The manual says to make sure you don't use any sources with output impedance under 100 Ohms but I can't find that spec for any of the modules I was hoping to use with this. Is that some sort of extreme low for output impedance that you won't find with professionally manufactured modules or will I just have to e-mail them all and ask?
Astronomical Dusk - a web radio show of synthetic delights and collected oddities. Airs monthly at astronomical dusk.
