Rossum Electro-Music Assimil8or
wavejockey
Re: Rossum Electro-Music Assimil8or
Post by wavejockey » Thu Feb 27, 2020 3:58 pm
loop bug:
it is simple : if you change the end point , you're f*ckd ; you cannot loop the sample anymore
truncate & you're good to go
but that is not good for play-ability/finding loop points
can i add:
would be nice if we could slice the first 8 beats/slices of a long(er) loop to the first 8 zones on a (first) channel and then the next 8 beats (of the same original loop) to the next 8 zones of the next channel and so on ; a nice solution for slicing longer loops/beats/...
(something like re-populate ; could be a 1 click solution/algoritm)
funqpatrol
Post by funqpatrol » Fri Feb 28, 2020 3:43 pm
Hey guys, can someone confirm firm that live recording and playing is possible on the ass8? I've heard ppl swearing this is possible. True?
Zerius
Post by Zerius » Fri Feb 28, 2020 6:15 pm
Yes you can do both, check it here
witchbutter
Post by witchbutter » Fri Feb 28, 2020 9:31 pm
loop bug:
I'm having the same issue with firmware 2.01. If I touch loop start or loop stop the screen freezes although sounds still play, the only way to fix is to power off :bang:
wavejockey
Post by wavejockey » Sat Feb 29, 2020 2:01 am
aha, we might be on to something here as i never touch the (end/start) loop points, i only work with the end/start points and the looping button
so mine assimil8tor never freezes but just stops looping/playing
cafe-de-la-jungle
Post by cafe-de-la-jungle » Sat Feb 29, 2020 5:35 pm
I`m having also a weird behavior with single-cycle waveforms. Once a load them they are working fine but if press the 'Sample start' button screen hangs and I have to reboot the device. Is there any fix for that ? :bang: :bang:
Sinamsis
Post by Sinamsis » Sat Feb 29, 2020 6:35 pm
Glad i'm not the only one haha.
witchbutter
Post by witchbutter » Sun Mar 01, 2020 9:33 pm
Does anyone know where to download the previous stable firmware 1.11_190917? Download links are only for 2.01 which is very much broken for me
cafe-de-la-jungle
Post by cafe-de-la-jungle » Mon Mar 02, 2020 3:36 am
+1 on this. I have sent an email to Rossum requesting this but so far no answer. Perhaps someone is still using the old and can upload it? :hail:
cafe-de-la-jungle
Post by cafe-de-la-jungle » Mon Mar 02, 2020 4:54 am
Guys,
I have a couple of thoughts after a week of using A8 and future requests which probably you can tell me if they are considered or not possible.
1. CV for Sample Level
This would leave the Pan/Mix section for fader operation.
2. Drum/Accent Mode
An alternative to section 1, dunno if possible but worth mentioning
3. Choke groups!
Let`s say to have at least two choke groups would be awesome - could be implemented in the Channels section.
4. Naming presets
Small request to consider when you save and set up the name of the preset the new letter start not from the beginning but from the last used letter.
Sam Botstein
Post by Sam Botstein » Mon Mar 02, 2020 2:02 pm
Please check private messages on this forum and please check your spam folder and whitelist rossum-electro.com.
sine language
Post by sine language » Tue Mar 03, 2020 6:56 am
Oh dear, just bought one of these. Now I read about the current firmware issue
Edit: just read through the thread and realised how much effort Rossum have put into fixing issues and adopting feedback so I’m not concerned that they will sort this out. Will be patient from now on! I’m sure it will be amazing once the 2.0 issues are resolved
isi909
Post by isi909 » Tue Mar 03, 2020 7:00 am
Oh dear, just bought one of these. Now I read about the current firmware being broken. Oh man what have I done
du you even phasemodulate bro....!
quaidscape
Post by quaidscape » Tue Mar 03, 2020 9:23 am
You're only having the issue with start/end when using specifically single cycle waveforms?
sine language
Post by sine language » Tue Mar 03, 2020 2:03 pm
I haven’t received it yet. I was hoping to PM waveforms along with basic sample playing, Live recording and playback. Is everybody having freezing issues with the new firmware?
Tonemod
Post by Tonemod » Tue Mar 03, 2020 2:43 pm
I just rebooted my rack a bunch of times. The following causes a freeze with single cycle (AKWF) waveforms:
While looping or not:
Press "SAMPLE START"
Press "SAMPLE END"
Press "LOOP START"
Press "LOOP END LENGTH"
I can verify this has been happening for the past 2 versions of the firmware. Don't touch those buttons while playing live!
Would be great to have a 3 key combination to hard reboot the A8 :help:
wavejockey
Post by wavejockey » Wed Mar 04, 2020 1:22 am
not only with SCW, to me it happens with every sample(s)
sine language
Post by sine language » Wed Mar 04, 2020 4:24 am
Are you saying that it’s impossible to actually play or sample,? Or only if you modify loop start / end. Is the machine useable in its current state otherwise?
sine language
Post by sine language » Wed Mar 04, 2020 4:28 am
A different question: does recording work using trigger to start and stop recording? Is it accurate enough to allow sample playback instantly without having to edit start and end points?
youwe9
Post by youwe9 » Wed Mar 04, 2020 5:49 am
Hi,
a lot of bashing recently... well I like my Assimil8tor and I am sure Rossum will fix what is necessary
My Question: I am looking for a controller to "play" the A8 live in a flexible way. Right now I am using the voltage block,
but maybe someone has experience with something else or has some other ideas...?
Thanx
Sinamsis
Post by Sinamsis » Wed Mar 04, 2020 6:25 am
Hi,
Thanx
Metron/Voltera is great. Also Vector sequencer.
youwe9
Post by youwe9 » Wed Mar 04, 2020 6:52 am
By "playing" I am mean having immediate access to different parameters in the A8 like pitch, bit reduction, loop endpoints...at different channels.
As a sequncer I use ER 101/102, the Voltage Block serves just as a 8 channel cv faderbox. I am looking to an alternative for that.
Can I use the Voltera standalone?
wavejockey
Post by wavejockey » Wed Mar 04, 2020 11:38 am
i am using the SDS Digital Rhytm which has enough CV out to drive one channel & keep it interesting + hands-on (!)
8 of them would be super ofcourse
but if i just need to 'drive' 4-8 channels with a gate and maybe some CV, then my MPC X is a nice complement
-if i really need 8 (mono!) channels + 2 CV each i use MIDI and my MUC810
wavejockey
Post by wavejockey » Wed Mar 04, 2020 11:43 am
only start, which is a missed feature i think
also (below) threshold could trigger a sample stop but isn't implemented either
the start threshold is more than accurate enough
a trim (silence) feature would be great too
c0rpse
Post by c0rpse » Wed Mar 04, 2020 12:15 pm
I don't believe this is correct. As I recall a second trigger will stop the recording. I've sent the reset out of Metron to get synced loops with no issues. I did not need to edit the start and end points, but I was re-triggering the sample every time the sequencer came around.
It might start a new recording as opposed to stopping recording, I can't remember the details, but I do know I have used triggers to get perfectly synced loops.
VINO MALO | Designer and Software Developer for WMD
