Doboz TSNM (Touch Sensing Note Memory)
GrimmWobble
Post by GrimmWobble » Sun Sep 23, 2018 12:22 am
JC14 wrote: Great! Thanks! .... Now I only need a response from Doboz after several weeks of trying :confused:
They are in stock @modular addict! Tot mime There as well after mailing for weeks with Doboz without a reply.
https://modularaddict.com/doboz-tsnm3u-pcp
I’m kinda new to filling up a mouser cart in that a lot of those parts are “currently not available”. I was wondering if someone has a recent project on mouser (or Farnell)?
I’d be truly greatful <3
dadacore
Post by dadacore » Tue Sep 25, 2018 9:38 am
did anyone notice pin 21 of teensy on the schematics marked PORTAMENTO POT?
Dominox
Post by Dominox » Sun Nov 04, 2018 5:07 pm
Hello,
I have a problem in my tsnm!
On every out I have a constant voltage around - 9.25 to - 9.55!
All other shows/works great, I can go to any programs
and the touch plates work too I think (the LED's light up)!
I have search really hard to find bad contacts but can't find any one!
Any ideas were I have my mistake....?
Thanks to you guy's
soggybag
Great module!
Post by soggybag » Wed Nov 07, 2018 10:25 pm
Just finished this a couple weeks ago. After playing with it for a while I have to say it’s its a really worthwhile module. It works well and provides a lot of musical options.
ARP mode with hold is really great.
NS4W
Post by NS4W » Thu Nov 08, 2018 6:27 am
Dominox wrote:Hello,
Thanks to you guy's
try a different MPR121 board? :despair:
soggybag
Post by soggybag » Thu Nov 08, 2018 10:38 am
Thanks to you guy's
I had a similar problem. Did you solder all of the pins on the Teensy. There are two parallel rows, and one pin that is on the end at a right angle to the bottom row. I missed this pin and things worked but the pads didn’t work.
shellfritsch
Post by shellfritsch » Thu Nov 08, 2018 11:56 am
Dominox
make sure the diodes are oriented correctly. i was getting high voltages on my outputs because one was facing the wrong way. i had assumed they were both oriented in the same direction.
Dominox
Post by Dominox » Fri Nov 09, 2018 6:54 pm
Shellfritsch you are the man! I have one diode in wrong position!
Now the outputs run better ;-) gate work great....
But on the cv out I have only one Voltage.....
I think the opa171 have a problem
Thanks to all of you!!!
GrimmWobble
So tiny
Post by GrimmWobble » Sun Nov 18, 2018 1:52 pm
Hey all,
I think I have all the components in to start building (even a hot air thingie) but I’m doubting the very very tiny parts.
I have 0603 parts and I was wondering if that is the correct size for this build because the pads seem way bigger.
I’m just scared to start....please sooth me
GrimmWobble
Missing 1 component
Post by GrimmWobble » Tue Nov 27, 2018 1:47 am
Dear all,
I’m nearly done with the SMD parts but I’m missing the 1206 10u Cap
It seems to be out of stock everywhere and I was wondering if there are good alternatives for this component?
Image[/img]
ntrm
Re: Missing 1 component
Post by ntrm » Tue Nov 27, 2018 7:06 am
GrimmWobble wrote: I’m nearly done with the SMD parts but I’m missing the 1206 10u Cap
Depends where you usually buy your components. The package size is important, but capacitance and voltage rating not so much. The voltage regulator (ADP150) datasheet suggest 1uF cap for output, so I think anything from 1uF should work. Also as it is a 3.3V regulator, a cap with DC voltage rating 10V or 16V or bigger, would work fine. Hope it helps.
P.S. Where did you buy the pcb and panel?
GrimmWobble
Post by GrimmWobble » Wed Nov 28, 2018 1:11 am
ntrm wrote: Depends where you usually buy your components. The package size is important, but capacitance and voltage rating not so much. The voltage regulator (ADP150) datasheet suggest 1uF cap for output, so I think anything from 1uF should work. Also as it is a 3.3V regulator, a cap with DC voltage rating 10V or 16V or bigger, would work fine. Hope it helps.
Luckily I found a replacement on Farrell that arrives today :)
So I guess I’ll be doing some more soldering tonight yay!
ntrm wrote: P.S. Where did you buy the pcb and panel?
Got it on Modular Addict a while back. Tried to get in touch with Doboz himself but never got a reply on my question if he could sell me one.
Royalston
Post by Royalston » Wed Dec 05, 2018 11:55 pm
Can someone tell me if this is normal behaviour:
In Arp mode, with hold off (so H! is not visible)
I hold a pad and turn the encoder to change the pad note, but the display does not update the note name - unless I release the pad and press it again.
Same with the transpose pads, but they never show any visual feedback...
GrimmWobble
Post by GrimmWobble » Sun Dec 23, 2018 3:31 am
Morning all!
I just finished building my TSNM and everything seems to be working.
I have a question though, how does one start playing a sequence?
I figured out how to set the sequence or record the steps but the clock in of the varigate doesn’t trigger anything.
Do I need to do something more to get it to work or do I start trouble shooting my build?
Thanks all
a773
Post by a773 » Sun Dec 23, 2018 6:24 am
Did you check the manual?
GrimmWobble
Post by GrimmWobble » Sun Dec 23, 2018 11:01 am
atte wrote:Did you check the manual?
Yes I did but it seems I’m either missing something or I made some mistakes during the build.
I must say, yesterday was late and perhaps when trying tonight I’ll be more lucky.
NS4W
Post by NS4W » Sun Dec 23, 2018 11:34 am
After you have input your sequence by pushing the pads, you push the encoder once to get back to the sequence menu. Then you start the sequence by inputting a clock to the c-input. Thats how it works for me
GrimmWobble
Post by GrimmWobble » Sun Dec 23, 2018 1:41 pm
NS4W wrote: After you have input your sequence by pushing the pads, you push the encoder once to get back to the sequence menu. Then you start the sequence by inputting a clock to the c-input. Thats how it works for me
Yeah, I figured out that it should work like that.
Tried different clocks (varigate 4+, Dixie II+ in lfo mode, ears and a clock from er-301) as well as input but no luck.
So here’s what I do.
Hold down de encoder for 1 second, set to “se” press again and select s• and then tap in the sequence. Press the the encoder again to back out to s• and then nothing happens :(
Hopefully you’ll price me wrong and I’m just missing a step. I’m glad I’m finished this module but hope I don’t have to start troubleshooting...
GrimmWobble
Post by GrimmWobble » Sun Dec 23, 2018 2:00 pm
Checked the 100k (r25) and 1m (r26) resistors and they seem to be ok.
Not sure how to check the transistor on Q1 but what I’m not getting “beep” when I check the right leg with the center one. Left leg does do something however I can’t say with certainty that it’s reading the way it should.
Other then that I think my touch thingy might also be faulty :(was
NS4W
Post by NS4W » Sun Dec 23, 2018 5:36 pm
GrimmWobble wrote: Hopefully you’ll price me wrong and I’m just missing a step. I’m glad I’m finished this module but hope I don’t have to start troubleshooting...
:hmm: seems like you do it right and it is a hardware issue :ripbanana:
GrimmWobble
Post by GrimmWobble » Mon Dec 24, 2018 2:08 am
Alrighty, ordered a new transistor and a (blue) mpr121.
Hopefully that’ll fix it.
Troubleshooting a build isn’t fun... then I get reminded how little I know about electronics:/
a773
Post by a773 » Wed Jan 23, 2019 3:43 am
I accidently hit the TSNM3U with +12V on the +5V and it smelled like it didn't like it :doh: It was on like 5 seconds.
After fixing the 5V problem (and hitting myself hard) I tried powering it up again, and it booted but started smelling again. It was on for about 3 seconds.
So, my question is, how do I proceed from here? I could just power it on and either be fine or have it burn out completely. Byt I'd rather not burn something hard to replace, that could have been avoided by replacing something easy to replace.
From visual inspection everything looks fine, but I might be missing something, cause I don't know what to look for...
Suggestions?
EDIT: On closer inspection IC7 (voltage regulator) seems to have taken a hit), I'm gonna replace that first.
Other thoughts/suggestions?Image[/img]
NS4W
Post by NS4W » Wed Jan 23, 2019 10:14 am
atte wrote: EDIT: On closer inspection IC7 (voltage regulator) seems to have taken a hit), I'm gonna replace that first.
logical that this part blew with wrong voltage - hopefully replacing it does the trick!
airfrankenstein
Post by airfrankenstein » Thu Feb 28, 2019 4:13 am
shellfritsch wrote:Dominox
Hi
from what i read the diodes on the pcb are correctly placed (see image below) but gates and triggers are not working.
DJ Tap Water
Post by DJ Tap Water » Thu Feb 28, 2019 6:18 pm
Can anyone in London make me one of these pls? Or anyone anywhere I guess
