Klavis - Quadigy - Quad Envelope Generator
guigui
Re: Bargain?
Post by guigui » Tue Aug 27, 2019 4:14 pm
I hope that price is perfectly correct.
vizor81
Re: Bargain?
Post by vizor81 » Wed Aug 28, 2019 2:48 am
Don‘t count on it...
But at least it seems to be close to release once listed in the shops.
I‘ve been waiting for this one since Superbooth 18, but got fed up by the delays.
vizor81
Post by vizor81 » Thu Sep 12, 2019 7:53 am
guigui
Post by guigui » Thu Sep 12, 2019 11:17 am
YESSS! :fap:
Zentek
Post by Zentek » Thu Sep 12, 2019 11:36 am
I've put the user manual on the product page.
Eric
Klavis
Fine Modular Designs
mdoudoroff
Post by mdoudoroff » Thu Sep 12, 2019 12:06 pm
:yay:
A great deal of interesting thinking in this module, particularly with the global time scaling and the preset morphing. Both suggest unexpected possibilities to me. I’m particularly curious about the overall timbral shifts that morphing might lead to in a patch.
However, my primary interest in Quadigy remains kind of rudimentary: four ADSRs in a small space that I can animate a bit with CV. I’m looking forward to a solid video demo so I can see whether the workflow/gestalt will work for me. (I normally avoid modules with sliders/pots that get overloaded/“disconnected”, so that aspect of this module is the stretch for me.)
Zentek
Post by Zentek » Thu Sep 12, 2019 12:22 pm
mdoudoroff wrote::yay:
A lot of interesting thinking in this module, particularly with the global time scaling and the preset morphing. Both suggest unexpected possibilities to me. I’m particularly curious about the overall timbral shifts that morphing might lead to in a patch.
However, my primary interest in Quadigy remains kind of rudimentary: four ADSRs in a small space that I can animate a bit with CV. I’m looking forward to a solid video demo so I can tell whether the workflow/gestalt will work for me. (I normally avoid modules with sliders/pots that get “disconnected”, so that aspect of this module is a stretch for me.)
Thank you for the kind words.
As soon as a set of faders act on more than one set of data there will be a visual disconnect, for sure. We tried keeping it to the best as follows:
- The data is (newly) edited only once the fader crosses the current value. No risk of sudden jump.
- When touching the fader, an animation in the display tells if you should go up or down to grab the value.
- Once the fader and the value are matching the fader LED goes on.
- A current setting of zero is indicated by double visual blips (either positive or negative, depending on the previous point). This is useful as there are several settings with a zero at mid-path.
- The zero at mid-path is wider so that you can land on easily.
A video is ongoing.
Eric
Klavis
sir stony
Post by sir stony » Tue Sep 17, 2019 2:10 pm
:goo: I just ordered one! :goo:
vibralux
Post by vibralux » Tue Sep 17, 2019 2:52 pm
You want regret it. Fantastic module. I just did a video review. Will post really soon.
MY YT CHANNEL WITH MODULES REVIEWS:
https://www.youtube.com/channel/UC3IgU2 ... hKH8ou7YTQ
MODULARS, ABLETON, MIXING. Stop reading manuals. Start making music.
http://www.colormysound.com/
mdoudoroff
Post by mdoudoroff » Tue Sep 17, 2019 2:53 pm
vibralux wrote:You want regret it. Fantastic module. I just did a video review. Will post really soon.
I WANNA SEE THAT VIDEO!
vibralux
Post by vibralux » Tue Sep 17, 2019 3:02 pm
Hopefully tomorrow. Stay tuned :nana:
Dogma
Post by Dogma » Tue Sep 17, 2019 4:41 pm
vibralux wrote:Hopefully tomorrow. Stay tuned :nana:
I’m dying to see this as it’s right in the space of what I’m looking for
look up!
Buyakasoundman
Post by Buyakasoundman » Tue Sep 17, 2019 8:09 pm
If I warn’t so inept, I’d put this up on Modular Grid.
...hint hint hint...
mdoudoroff
Post by mdoudoroff » Tue Sep 17, 2019 10:19 pm
Buyakasoundman
Post by Buyakasoundman » Wed Sep 18, 2019 5:08 am
WooHooo!!!! Thanks!!!
vibralux
Post by vibralux » Wed Sep 18, 2019 5:52 am
Boom!
Carl Licroy
Post by Carl Licroy » Wed Sep 18, 2019 7:51 pm
Very good video thanks. This module is brilliant, very deep :tu:
matttech
Post by matttech » Thu Sep 19, 2019 8:05 am
Just opened preorders if anyone is looking for one? 8-)
sir stony
Post by sir stony » Thu Sep 19, 2019 4:17 pm
First impression: :nana: :mrgreen:
mamonu
90s ambient miscreant!!
Post by mamonu » Sat Sep 21, 2019 5:20 am
my only problem is the +5V requirement.
Otherwise its perfect
sir stony i see you have the dreadbox case94.
I have the case168 which is great. The utilities are :goo:
Which +5v adaptor have you got.??
(I had some problems with Logica and had to return it since as soon as I put the 5v adaptor the case would not power.)
Zentek
Post by Zentek » Sat Sep 21, 2019 5:33 am
mamonu wrote:my only problem is the +5V requirement.
You could try a NoDrain 5V adapter. It takes its current from the 12V negative rail!
Klavis
sir stony
Post by sir stony » Sat Sep 21, 2019 4:28 pm
I made my own and got no problems with it. I plan to make that into a regular product eventually, so far I just made two functional prototypes for myself that work in a different way than any other I could find in the eurorack market.. As my own did the trick I never tried any other adaptors, so I can't tell which ones will or won't work. :despair:
Bigwerm
Post by Bigwerm » Thu Sep 26, 2019 10:00 am
Do you think there’s the possibility of adding a screensaver in a future firmware update. Maybe blank the screen after a specified amount of time?
Zentek
Post by Zentek » Sat Sep 28, 2019 1:02 am
Bigwerm wrote:Do you think there’s the possibility of adding a screensaver in a future firmware update. Maybe blank the screen after a specified amount of time?
Good idea! :tu:
Now added in the todo list.
Thank you :zen:
Klavis
sir stony
Post by sir stony » Sat Sep 28, 2019 2:16 am
A way to dim the LEDs would be highly appreciated, same with the Twin Waves... while the brightness is fine in the lights of a stage or a brightly lit room, it is plain too bright in dim light conditions, as are often given at ambient sessions.
On my foto above the Quadigy appears much less bright than the other modules there, but that is due to the fact that the other modules have diffused leds that shine all around, while Klavis uses clear leds with a more focused beam which is much harder on the eye looking straight at them...
