Supercell: expanded version of Clouds + Superparasites firmware
drikbreit
Re: Supercell: expanded version of Clouds + Superparasites firmware
Post by drikbreit » Wed Sep 30, 2020 9:03 am
Yes Powder wrote:
Wed Sep 30, 2020 8:47 am
The red stripe on your cable goes down with the stripe under the power header that says -12v red.
Thank you !
jones
Post by jones » Wed Feb 10, 2021 3:17 pm
Hi all - created this cheatsheet manual for my own use - but thought it may be of use to some of you lucky Supercell owners...
djdiscord
Post by djdiscord » Wed Feb 10, 2021 3:46 pm
Fantastic! Thank you so much for sharing.
Ivo Ivanov
Sausage Wiggler
Post by Ivo Ivanov » Wed Feb 10, 2021 4:44 pm
Nice one! Thanks for this!
studio460
Post by studio460 » Wed Feb 10, 2021 6:21 pm
Very nice! Thank you! I will definitely be using this!
Photosinferno
Post by Photosinferno » Sat Feb 13, 2021 6:30 pm
Very cool, and just what I was looking for, thank you 👍
Craig Z
Post by Craig Z » Sat Feb 13, 2021 10:32 pm
@sempervirent So I picked up one of these recently, upgraded from a Monsoon, and I am loving it - great work! However, it's seems that the random CV fluctuation feature for unpatched inputs may not be working on my unit. I installed the Parasites firmware and did the re-calibration as specified in the manual (probably not relevant, but I don't want to leave out any background info). Can't seem to get any randomness out of unpatched inputs. I've created a video showing the (non)behaviour... apologies for the shaky-cam. It's entirely possible I'm missing something obvious, so wanted to check before initiating a return:
(video is unlisted, so won't show up on youtube searches. I'll remove it once you've viewed it)
djdiscord
Post by djdiscord » Sun Feb 14, 2021 12:23 am
Try holding the mutes for a longer period of time, it takes a bit.
Craig Z
Post by Craig Z » Sun Feb 14, 2021 1:33 am
Thanks for the advice, but I've tried many times, with more than two seconds, which is what is specified in the manual. Does it take a longer period than 2 seconds on yours to change states?
djdiscord
Post by djdiscord » Sun Feb 14, 2021 1:43 am
I'd say a solid five, definitely more than 2.
ModdyG
Post by ModdyG » Sun Feb 14, 2021 3:07 am
Thanks so much. Now to upgrade the firmware.
jones
Post by jones » Sun Feb 14, 2021 6:41 am
Just make sure you have a good 1 and 3 volt source to re-calibrate after the update - I used my Ornament and Crime
flies
Post by flies » Sun Feb 14, 2021 6:50 am
Awesome, thanks for this!
my rig https://www.modulargrid.net/e/racks/view/622777 (not shown: VCV rack, MOTO 828 mk2, outboard effects)
Craig Z
Post by Craig Z » Sun Feb 14, 2021 8:19 pm
You're right... I tried it again holding it for 5 or 6 seconds and it worked.
@Sempervirent, you might want to update the manual, as it says 2seconds in there.
ModdyG
Post by ModdyG » Sun Feb 14, 2021 8:27 pm
Thank you for that suggestion; I’m going to look for one of the 1U ones.
studio460
Post by studio460 » Tue Feb 16, 2021 11:06 pm
Is there any reason to hang on to our Supercells now that Beads is out?
Matt_L
Post by Matt_L » Tue Feb 16, 2021 11:07 pm
Two granular synthesizers is better than 1
studio460
Post by studio460 » Tue Feb 16, 2021 11:35 pm
Ha! I just listened to the Beads' demo, and the fidelity of the live-granular processing sounds much higher. Am I imagining this?
nectarios
Post by nectarios » Wed Feb 17, 2021 2:39 am
It's not your imagination.
Yes Powder
Powder that makes you say "Yes"
Post by Yes Powder » Wed Feb 17, 2021 7:10 am
Depends how much you use the extra CV inputs, I suppose?
dooj88
Post by dooj88 » Wed Feb 17, 2021 7:19 pm
beads doesn't have cv over wet/dry or reverb amount, so that alone makes it worth keeping one of the pervious versions
cinnatoastg
Post by cinnatoastg » Wed Feb 17, 2021 7:28 pm
From the manual, it’s one input that can be sent to the three parameters simultaneously.
“J. Feedback, that is to say the amount of output signal mixed with the input signal and fed back into the processing chain. Each quality setting employs a different feedback amplitude limiting scheme typical of the medium it emulates – from clean brickwall-limiting to grungy tape saturation.
K. Dry/wet balance.
L. Amount of reverb. Modeled on the acoustics of Thoreau’s cabin, or of a strip-mall spa.
The LED under each of these knobs indicates the amount of modulation they receive from the assignable CV input (7).
Press the button [M] to select to which of these 3 destinations the CV input (7) is assigned. Or hold this button and turn the knobs [J], [K] and [L] to individually adjust the amount of CV modulation.“
WTB - Piston Honda MK3, Bionic Lester MK3
studio460
Post by studio460 » Wed Feb 17, 2021 8:31 pm
Haha! Thanks! Fellow member nios wrote a pretty detailed technical description comparing the two in the Beads thread. My thanks, since that settled most of my questions. I'm sure I can find something for my Supercell to do once I receive my Beads.
Sure! It can be my "Beads' CV-machine!"
Awesome! A bit thin, but I'll take it! Thanks!
Craig Z
Post by Craig Z » Thu Feb 18, 2021 12:45 am
If you're a bit forgetful, like me, having the quality / banks UIs separated out, as Supercell does, is worth something too. It used to drive me nuts on the Monsoon. The output level right there on the panel is worth something also (to some at least).
jones
Post by jones » Thu Feb 18, 2021 4:56 pm
What he said...
