Mutable Instruments Marbles Random Sampler
- Learning to Wiggle
Re: Mutable Instruments Marbles Random Sampler
I’m thinking about bringing Marbles into my synth family but I was curious how people were putting custom scales into it?
I have a Keystep and a Rene Mk2...is it pretty much a no-brainer or is there a degree of fiddlin’ to the whole process?
Much thanks!
Much thanks!
Quite simple. Hold a button for two seconds, then send note CV to one input and gates to another. Push the button when you are done. That’s it!
You go too high too early, man. I remixed a pop song using my piano, an 808 and a Minilogue.
That’s great! Thank you!
What's the slowest rate Marbles can go if measuring t2 in divide 4 mode? Measured in seconds between triggers?
(This is if my understanding is correct and t2 is generally a regularly-spaced trigger out except in jitter and external clock situations...)
hi everybody
im relatively new to eurorack, so i freshly got marbles and ate up the manual and also divkids video and think i do understand the module fairly well, but there is one thing which i cant seem to figure out
If there is a sequence running and locked in dejavu, wouldnt it be awsome to able to just "slightly" randomize either the t- "OR" the x-section? so you get slight variations in rhythm but not in pitch.. or the otherway arround? is there no such function?
as of now im only able to do subtle randomisation to both sections simultaneously, or lock one section while the other goes complete bonkers.. its still fun but harder to generate progressive musical variations if both are changing at the same time. i know i can use the bias and spread and jitter but this is not exactly what im looking for. hope you get the idea.. maybe im just missing the obvious or is there another firmware that can do that?
please help =) thaaaanks a ton
That is not possible.When both the t- and x-section are locked, you have only one knob to control the amount of randomisation, and that is for both sections.psy_dive wrote: ↑Wed Feb 26, 2020 9:12 amhi everybody
my rack: https://www.modulargrid.net/e/racks/view/487293
soundcloud: https://soundcloud.com/user-134176900
- starthief
- Super Deluxe Wiggler
- Contact:
You can tap one of the white buttons, let a change slip through, then tap it again to lock it back in.
Or clock externally and use another trigger source instead of the t section. I kind of like doing that anyway sometimes since it lets me loop that rhythm at a different length than I loop Marbles
Yeah, thats what i also tried. the button pressing will keep you busy though. thanks both for your replies!starthief wrote: ↑Wed Feb 26, 2020 9:50 amYou can tap one of the white buttons, let a change slip through, then tap it again to lock it back in.
Or clock externally and use another trigger source instead of the t section. I kind of like doing that anyway sometimes since it lets me loop that rhythm at a different length than I loop Marbles![]()
Ive asked the same question on MI forum and got follwing replie from émilie:
"Hmmm that could actually be implemented without too much effort and compromises in a firmware update as a kind of “super lock”: long press on the DEJA VU X or t button makes this channel unresponsive to the DEJA VU knob.
Question: should this “super lock” feature also allow the LENGTH to be tweaked for the t or X section while the length remains “super-locked” for the other? Or should the “super lock” only act on DEJA VU (this would seem to be what you need!)"
This is a super nice answer and sparkled my interest even more but unfortunately i got absolutley no experience coding
- hawkfuzz
- Contact:
They've got a lot of coders on that site. I bet if you keep going someone will do it. I like the idea so hopefully it happens. I do love my Marbles.
This module is crazy unfriendly to colourblind people, even with the colourblind mode on. I'm never sure where I am with it, hopefully more experience with it will help me get along with it.
I make sounds and games // https://www.youtube.com/c/MichaelManningMGFM
Marbles “super lock” feature
There is a new firmware for Marbles - “super lock feature"
https://forum.mutable-instruments.net/t ... re/16571/3
Super exciting! =)
Super exciting! =)
- mother misty
- Common Wiggler
Re: Marbles “super lock” feature
Sweet!psy_dive wrote: ↑Mon Mar 02, 2020 4:11 pmThere is a new firmware for Marbles - “super lock feature"
Super exciting! =)
Pretty amazing this was a question/suggestion and 5 days later we have a new firmware with the function implemented!
- Squarewave Fellowship
Amazing!mother misty wrote: ↑Mon Mar 02, 2020 5:50 pmSweet!psy_dive wrote: ↑Mon Mar 02, 2020 4:11 pmThere is a new firmware for Marbles - “super lock feature"
Super exciting! =)
Pretty amazing this was a question/suggestion and 5 days later we have a new firmware with the function implemented!Émilie
Every time I used it, I was thinking "why can't I choose where the random goes?!?!"... then this. ideal.
Émilie is cool like that.
I gave up on Marbles recently. Just couldn’t gel with it. I make very simple music but I need control and random based music just doesn’t seem to be my thing.
It’s also a bit of a hassle to have to record the scale for each patch before I could use Marbles.
- Dark Barn
- Wiggling with Experience
- Contact:
I just use a quantizer after Marbles, I’ve never taught myself how to record a scale on Marbles, maybe some day.lisa wrote: ↑Thu Mar 05, 2020 1:40 pmÉmilie is cool like that.
I gave up on Marbles recently. Just couldn’t gel with it. I make very simple music but I need control and random based music just doesn’t seem to be my thing.It’s also a bit of a hassle to have to record the scale for each patch before I could use Marbles.
- starthief
- Contact:
I can't remember the last time I programmed a scale into it... I pretty much pick one of the scale selections at random, use Deja Vu to grab something I like and the knobs to tweak it, and run with it. Or else I set up a sequence as a starting point, and use the capture input.
Short loops, but with sequenced variations via Bias/Spread, work pretty well for me. A couple times I've wound up going down to length 2 with a slow clock
I've also done re-quantizing in Teletype a couple times.
- bemushroomed
I've never used that function. My sequencer is multed so that it also goes into one of my Marbles. Super easy setup... If marbles is in that mode it stays in it too, so there's no need to mess holding down buttons or something, just need to do it 1 time.
- mother misty
- Common Wiggler
I've installed the new firmware with the superlock feature, but now my Marbles doesn't seem to remember it last settings when powered off.
When I power on, the super lock feature on 't' is always on, even when it wasn't when I powered it off.
Anyone else has this behaviour?
EDIT: nevermind, already solved
Settings (including the state of the t/X pushbuttons) are saved whenever you change one of the ranges or modes (small buttons).
Settings are NOT saved whenever you press the t/X pushbuttons since saving them to flash memory can freeze the module for a few hundred ms (and you don’t want this to happen while you just want to lock/unlock a loop).
One more simple ambient composition I've just made with my small system to help all of us relax a bit during these hard times.
Main melody is by Marbles plus Rings. All delay magic is by Happy Nerding FM Aid plus Clouds.
Take care of each other, be safe and stay home whenever possible.
- starthief
- Contact:
Nice recording
- aragorn23
- Contact:
Hey all, apologies if this has been answered already but I have a question about sampling external CV.
I've got a little eight step sequence going into Spread with the external processing button set to on, and Marbles is working well at generating variations of this sampled input on x2, but x1 and x3 have a really wide octave spread (like, a full 4 octaves) regardless of Spread, Bias and other settings. The input sequence doesn't even span a full octave, so the issue isn't there. Any idea what's going on?
- erstlaub
- Contact:
Do you have the x side set to the green mode range?
green = Unipolar 0-2v
orange = unipolar 0-5v
red = bipolar -5 to +5v
- aragorn23
- Contact:
When I toggle to processing external CV, the range LED goes off. I'm not sure if that's normal behaviour. I have tried setting it to green before toggling the external cv and it doesn't seem to make a difference.
Sounds strange. I am away from my modular at the moment, but I am quite sure transposition of the incoming CV is controlled only by Bias and Spread.aragorn23 wrote: ↑Tue Apr 14, 2020 9:17 amHey all, apologies if this has been answered already but I have a question about sampling external CV.
As I recall, Transposition is zero when Bias is set to 12 o'clock and Spread is set to zero. In this position you should only hear the same notes as the sequence (quantised with Steps)
Do you have the clock from the sequence going into the X clock in (to make sure you only sample when the sequence change)?
