[/quote]
Hi, thanks for the answer ! I should have mention that i tried to have only this module power up in the case with not result... Anyway i'm way below the max power draw of my power suplly with all the modules installed
I’d still get a Marbles for thatgnometicsynthesis wrote: ↑Tue Feb 16, 2021 4:43 pmHi folks. I wanted to get a 2nd Marbles, but decided that I'd rather get 2 new modules instead. So I got a Grids to duplicate and expand on the "t" side of Marbles. Now I'm looking for a random sequencer/quantizer module to duplicate and possibly expand on the "x" side of Marbles. Any suggestions?
Maybe grab a used Antimatter Brainseed (4hp) to record from one of the X outputs of your Marbles, and drive its playback order with another X output (or whatever else). You'd get a related (Marbles-derived, but temporally different) pitch sequence from that, in the same scale that Marbles is using.gnometicsynthesis wrote: ↑Tue Feb 16, 2021 4:43 pmHi folks. I wanted to get a 2nd Marbles, but decided that I'd rather get 2 new modules instead. So I got a Grids to duplicate and expand on the "t" side of Marbles. Now I'm looking for a random sequencer/quantizer module to duplicate and possibly expand on the "x" side of Marbles. Any suggestions?
You might be in a boot mode. Try to reload the firmware following the instructions on the site and see if your problems go away.Eiymet wrote: ↑Tue Feb 16, 2021 11:31 amNever happened to me... make sure you are not using too much draw from the case, if you're almost hitting max you can get issues.
Hi, thanks for the answer ! I should have mention that i tried to have only this module power up in the case with not result... Anyway i'm way below the max power draw of my power suplly with all the modules installed![]()
Possibly by applying a CV to the Spread / Bias controls, possibly via a sequential switch? That would be my initial approach.peachesandbacon wrote: ↑Fri Feb 19, 2021 5:00 amDoes anyone know if there's anyway to get a longer pattern length than 16 steps out of Marbles?
An alternative firmware perhaps, or using another module to somehow workaround it?
Any ideas?
Yeah, I thought about using my sequential switch, but that would require getting a second pattern of 16 steps from one of the other outputs right?Lux A Turner wrote: ↑Fri Feb 19, 2021 5:17 amPossibly by applying a CV to the Spread / Bias controls, possibly via a sequential switch? That would be my initial approach.peachesandbacon wrote: ↑Fri Feb 19, 2021 5:00 amDoes anyone know if there's anyway to get a longer pattern length than 16 steps out of Marbles?
Any ideas?
Edit: You might have trouble doing sequences with a prime-numbered number of steps, though![]()
Not necessarily. Thinking off the top of my head here, but what I would do for 32 steps is send the CV via the sequential switch (set to 2 I/O's) to Spread or Bias and trigger it using the t2 out, going through a 1/16 clock division.peachesandbacon wrote: ↑Fri Feb 19, 2021 6:28 amYeah, I thought about using my sequential switch, but that would require getting a second pattern of 16 steps from one of the other outputs right?Lux A Turner wrote: ↑Fri Feb 19, 2021 5:17 amPossibly by applying a CV to the Spread / Bias controls, possibly via a sequential switch? That would be my initial approach.peachesandbacon wrote: ↑Fri Feb 19, 2021 5:00 amDoes anyone know if there's anyway to get a longer pattern length than 16 steps out of Marbles?
Any ideas?
(Assuming I wanted 32 steps for example)
Yes.hawkfuzz wrote: ↑Fri Feb 19, 2021 7:30 am...You can transpose the sequence with two steps, one 0v and the other whatever you’d like and have it start after one loop. Yes its going to require another source. A gate would be fine for this.
If you wanted the second set of 16 to be entirely different you’ll need to experiment with bias and spread but they’ll be related slightly.
seems to be a quite simple fw hack...peachesandbacon wrote: ↑Fri Feb 19, 2021 5:00 amDoes anyone know if there's anyway to get a longer pattern length than 16 steps out of Marbles?
Any ideas?
Maybe a Mimetic Digitalis?gnometicsynthesis wrote: ↑Tue Feb 16, 2021 4:43 pmHi folks. I wanted to get a 2nd Marbles, but decided that I'd rather get 2 new modules instead. So I got a Grids to duplicate and expand on the "t" side of Marbles. Now I'm looking for a random sequencer/quantizer module to duplicate and possibly expand on the "x" side of Marbles. Any suggestions?
Well there you are! Goes well beyond 32.recliq wrote: ↑Fri Feb 19, 2021 12:49 pmseems to be a quite simple fw hack...peachesandbacon wrote: ↑Fri Feb 19, 2021 5:00 amDoes anyone know if there's anyway to get a longer pattern length than 16 steps out of Marbles?
Any ideas?
https://forum.mutable-instruments.net/t ... ty/16248/4
Assuming you're locking the pattern, send negative CV to Deja vu every other 16 notes to get different random notes, or positive CV to rearrange the same notes in the pattern.peachesandbacon wrote: ↑Fri Feb 19, 2021 5:00 amDoes anyone know if there's anyway to get a longer pattern length than 16 steps out of Marbles?
Any ideas?
Go here...BlackBearDiner wrote: ↑Sat Feb 20, 2021 7:22 pmIs there any info somewhere on how to chose the added lengths?
Have you tried it? What do you think?peachesandbacon wrote: ↑Sat Feb 20, 2021 6:18 pmThanks for the answers everyone.
Looks like some smart cookie already made it, and it now goes to 128 steps.
Here's a direct link to the firmware.
https://www.dropbox.com/s/uty5z028dyotq ... 2.wav?dl=0
Credit to Jthrw over on the Mutable forum for this.![]()
I haven’t tried it yet, but I believe it just gives the length knob a wider range. So it goes to 128 instead of 16BlackBearDiner wrote: ↑Sat Feb 20, 2021 7:22 pmIs there any info somewhere on how to chose the added lengths?
For sure. I feel 128 is a little too long, but 32and 64 are perfect lengths.auditorycanvas wrote: ↑Sat Feb 20, 2021 11:35 pmI loaded it up last night and had a play. It's pretty awesome. Can't see me using 128 steps, but 32 and 64 are super useful. Can be a bit tricky setting lower values, but 16 upward is surprisingly easy.
+1. As with much in Euro, less is often more with Marbles - although I can see there might be fun to be had, with a firmware version that had loop lengths based on things like prime numbers or the Fibonacci sequence.
Buyakasoundman wrote: ↑Sat Feb 20, 2021 7:40 pmGo here...
Although (of course) if you have Deja Vu turned even a little CCW, the notes in the loop will evolve, so you won't always get the same three notes each time. Marbles also subdivides some steps into halves, quarters and eighths - especially when T is in the orange mode - so even a three step loop can contain many more than three notes; although loop evolution in that mode means that you can gain / lose a whole chunk of notes with the evolution of a single step (I love the orange modepeachesandbacon wrote: ↑Mon Feb 22, 2021 1:21 amWow. Interesting. I hardly ever have it that low. But I'm using it mostly to generate melodies not modulation I guess.
