A-199 Spring Reverb Crackling noise
ian:o
Post by ian:o » Tue Apr 03, 2018 9:11 am
Hi guys. I have a new A-199 Spring Reverb module all happily installed and working...apart from a crackling noise across the OP. I've sited the spring tank behind the module, as far away from the PSU as I can and have a pair of standard HiFi phonos running between between that and the module. It's not constant and it's relatively narrow bandwidth, and 'crackling' is perhaps the only way I can describe it - perhaps a little akin to a dirty pot sound, but much higher in frequency and although it's constant, there's no pattern or repetition to it - it's completely random. i can't seem to nail it down. I've attached a clip of it as it comes out of the unit.
Any ideas?
Summa
Post by Summa » Tue Apr 03, 2018 1:20 pm
Remove the tank from the case and report back
Pighood
Post by Pighood » Tue Apr 03, 2018 3:23 pm
I’ve always had my tank outside the case...was unaware it was even feasible to store it inside
*phnert*
ian:o
Post by ian:o » Tue Apr 03, 2018 6:05 pm
Thanks guys - it didn't occur to me to put the tank outside - I'm more used to working with guitar cabs. I'll let you know how it goes.
Drilldoughzer
Post by Drilldoughzer » Tue Apr 03, 2018 6:25 pm
I built a Befaco spring and it came with his tank.
I have put it on the top of my case, not screwed to it and I can hit it, scratch the springs and abuse it... Marvellous!
ian:o
Post by ian:o » Wed Apr 04, 2018 10:52 am
Thanks very much chaps. Tank removed. I made a nice little isolation foam surround for it, but keeping the springs exposed for those moments when i really want to wake people up. Cracking has, as suspected, vanished.
Thanks you. :tu:
Summa
Post by Summa » Wed Apr 04, 2018 2:12 pm
ian:o wrote:Thanks very much chaps. Tank removed. I made a nice little isolation foam surround for it, but keeping the springs exposed for those moments when i really want to wake people up. Cracking has, as suspected, vanished.
Thanks you. :tu:
:tu: good, now go lock for that thread here about different tanks for the A-199, they really change the sound drastically. I use a modded tank from a Fender Twin and it sounds brilliant.
ian:o
Post by ian:o » Wed Apr 04, 2018 5:26 pm
:tu: good, now go lock for that thread here about different tanks for the A-199, they really change the sound drastically. I use a modded tank from a Fender Twin and it sounds brilliant.[/quote]
Holy S***t! I have one of those - or something very similar in a UK built all valve guitar amp..its huge...I'm gonna give it a whirl!!
