Hemisphere for Ornament and Crime
chysn
Post by chysn » Fri Aug 09, 2019 6:54 pm
Okay, okay, enough of this.
Current Rack: https://www.modulargrid.net/e/racks/view/354385
Hemisphere Suite: https://github.com/Chysn/O_C-HemisphereSuite/wiki
"Man must shape his tools lest they shape him." --Arthur Miller
insoul8
Post by insoul8 » Thu Sep 05, 2019 9:00 am
Do the envelope generators in Hemispheres allow you to adjust the curves from logarithmic to linear to exponential?
A few bits and bobs for sale here.
chysn
Post by chysn » Thu Sep 05, 2019 10:02 am
insoul8 wrote:Do the envelope generators in Hemispheres allow you to adjust the curves from logarithmic to linear to exponential?
No, the envelopes are linear only.
insoul8
Post by insoul8 » Thu Sep 05, 2019 10:31 am
Thanks. I think that might be a deal breaker for me with the way i use Piqued. Such a flexible envelope generator.
Shledge
Post by Shledge » Thu Sep 05, 2019 10:35 am
If you have a VCA with lin/exp control, it doesn't matter that much.
insoul8
Post by insoul8 » Thu Sep 05, 2019 10:49 am
Shledge wrote:If you have a VCA with lin/exp control, it doesn't matter that much.
Yea, that's a good thought. I'll give it a try with Piqued in linear mode and see how it goes.
Ebotronix
Post by Ebotronix » Wed Sep 11, 2019 10:20 pm
hi chysn!
Is it possible to extend the slow app so that you can choose between linear and exponential for both channels?
I need two equal slew limiters for 2 VCOs and the equal trending app.
what happened with the 1.8 update?
you wrote that you want to remove the 100 scales from the OC 1.3.2 Firmware
djd_oz
Post by djd_oz » Sun Sep 15, 2019 6:49 am
I've noticed for my unit that the ADSR EG only outputs up to about 1 Volt, the AD EG outputs to about 5 Volts.
Anyone seen this before?
hinterlands303
Post by hinterlands303 » Sun Sep 15, 2019 3:11 pm
djd_oz wrote:I've noticed for my unit that the ADSR EG only outputs up to about 1 Volt, the AD EG outputs to about 5 Volts.
I get a full 5 volts from the ADSR.
chysn
Post by chysn » Sat Oct 05, 2019 7:47 pm
Ebotronix wrote:what happened with the 1.8 update?
Firmware
Ah, the 1.8 update. It was going to have the Buchla updates. Problem is, without an actual Buchla system to test with, I'm totally at sea with doing Buchla compatibility. So I'll probably review the outstanding issues for things I can do, and tie up some loose ends and release the 1.8 hex file soon.
It's the other way around; I added back scales that had been removed from O_C 1.3.2.
Otherwise, 1.8 is a pretty minor update. It's mostly improvements to Buchla voltage handling (thanks to Mike Thomas), and bug fixes.
The most significant change is that there's now a global clock source, so that you can run sequencers and things without connecting an external clock. Previously, you could do this with Metronome, but the update basically involves replacing Metronome with a standalone clock.
The clock feature replaces the applet category filter, which I bet nobody even knew existed.
adh82
Post by adh82 » Wed Oct 09, 2019 7:50 pm
Is there anyway to get a morphable LFO like a dual channel version of the of the quad LFO in the original firmware?
Afturmath
Post by Afturmath » Sun Oct 20, 2019 4:24 am
@Chysn Please re-open and review issue #44 in-depth. It is not a duplicate. The fix for Tuner in v1.6 was not complete, and the Tuner was not working in 1.7B flip or 1.8RC flip without the changes I noted in the ticket.
Soundcloud || Current Eurorack
Support synths: Voyager XL, Subsequent 37 CV "Moogfest Edition", Novation Circuit Mono Station, Modal Craft Synth 2.0
Misk
Post by Misk » Tue Oct 22, 2019 12:31 am
chysn wrote: The most significant change is that there's now a global clock source, so that you can run sequencers and things without connecting an external clock. Previously, you could do this with Metronome, but the update basically involves replacing Metronome with a standalone clock.
I knew it was there! I never used it though, because it was just easier to be lazy and scroll through applets alphabetically... so... good call! :hihi:
versipellis
Post by versipellis » Wed Oct 23, 2019 3:40 pm
Is there a one-page descriptor of all the Hemisphere applets? Kinda annoying clicking through each of them on the wiki just to remember the difference between, say, all the shift registers.
tunes: https://www.soundcloud.com/dycedot
in boston? I run nights: https://www.facebook.com/4OTFEvents/
selling [Moog Sub Phatty, JU-06A, KMI K-Mix w/ MIDI expander, Erica Synths Bassline]: viewtopic.php?p=3142686
BaloErets
Post by BaloErets » Thu Oct 24, 2019 12:32 pm
versipellis wrote:Is there a one-page descriptor of all the Hemisphere applets? Kinda annoying clicking through each of them on the wiki just to remember the difference between, say, all the shift registers.
There was a PDF that someone made in multiple formats if you search through this thread.
yobink
Post by yobink » Thu Oct 24, 2019 12:45 pm
Also, Thomas Burns said at some point, that it's on the list for inclusion in his awesome Modes iOS app.
BaloErets
Post by BaloErets » Thu Oct 24, 2019 12:53 pm
You can find the PDF for 1.5 in this thread viewtopic.php?t=207526&highlight=[/url]
chysn
Post by chysn » Thu Oct 24, 2019 6:43 pm
Afturmath wrote:@Chysn Please re-open and review issue #44 in-depth. It is not a duplicate. The fix for Tuner in v1.6 was not complete, and the Tuner was not working in 1.7B flip or 1.8RC flip without the changes I noted in the ticket.
Please see my comment in the ticket. It should be corrected in the repo HEAD now. Thanks for the catch.
versipellis
Post by versipellis » Mon Oct 28, 2019 2:46 am
BaloErets wrote:You can find the PDF for 1.5 in this thread viewtopic.php?t=207526&highlight=[/url]
Thank you! Printing this one out.
uebl
Post by uebl » Tue Nov 19, 2019 9:20 am
I'd just like to say I still love Hemisphere O&C so much. Saved me from buying many utility modules. Often I think: I could really need that.. oh, wait - Hemisphere has it! :hail: :hail:
I hope 1.8 will see the light of day soon.
versipellis
Post by versipellis » Thu Nov 21, 2019 2:20 am
Is there a way to specify the root note in addition to scale for Dual Quantizer, like how you can with Quantermain?
chysn
Post by chysn » Wed Nov 27, 2019 10:53 pm
versipellis wrote:Is there a way to specify the root note in addition to scale for Dual Quantizer, like how you can with Quantermain?
This is available as of Hemisphere Suite 1.4, so upgrade to the latest version for this.
GryphonP3
Post by GryphonP3 » Thu Nov 28, 2019 1:43 am
Maybe I'm blind, but is there a manual somewhere with a description of the functions and i/o of each mode?
My cat can eat a whole watermelon ...
chysn
Post by chysn » Thu Nov 28, 2019 5:32 am
GryphonP3 wrote:Maybe I'm blind, but is there a manual somewhere with a description of the functions and i/o of each mode?
versipellis
Re: Hemisphere for Ornament and Crime
Post by versipellis » Thu Dec 26, 2019 10:20 am
Has anyone else had issues running hemisphere on 1uO_c4robots by plum audio? I'm getting constant voltage out at every output. I'm wondering if it needs a custom VOR firmware to work.
