New Doepfer Envelopes A-141-4, A-140-2, A-142-2
circuitbent
Post by circuitbent » Fri Aug 03, 2018 9:21 pm
On the A-140-2, I see that each channel has an "Out 2" and an "Out 1". Are these just mults of the same output signal?
DMR
Post by DMR » Sat Aug 04, 2018 8:43 am
circuitbent wrote:On the A-140-2, I see that each channel has an "Out 2" and an "Out 1". Are these just mults of the same output signal?
Out 2 can be either the a normal or inverted envelope out (selectable via a jumper on the back of the module): http://www.doepfer.de/a1402.htm
Post by MindMachine » Fri Aug 17, 2018 8:39 pm
I see they are available at Schneidersladen but not Thomann or Analog Haven.
They are 'now available' on Doepfers site: http://www.doepfer.de/home_e.htm
poatoae
Post by poatoae » Sat Aug 18, 2018 12:07 pm
Detroit Modular has the A-140-2 and the A-132-8 now.
suthnear
Post by suthnear » Sun Aug 19, 2018 12:07 pm
Just got the a140-2: it's a lot of envelope in a small space. The CVT parameter is normalled to a voltage source so you can increase (or decrease) the exponential nature of the time-based envelope segments just by turning it, which allows you to tune the shape of the envelope. The module has a number of jumpers that allow you to set various options so it's actually rather more well specified than it appears. The small pots work well, with a much smoother and more pleasing travel than I was expecting. I bought this for my desktop satellite but I may get another one for the main cases...
One small downside is that it seems to need a fairly large gate signal to open properly. The gates from my expert-sleepers es-40 expanders do not work well with it: decay doesn't work at all (release might not have, either). It worked fine with an es3, however. I will investigate this further when I have a chance.
suthnear
Post by suthnear » Sun Aug 19, 2018 12:09 pm
Yes. There is a jumper option that inverts one of the outs if you want.
Post by MindMachine » Fri Aug 31, 2018 8:09 pm
suthnear wrote:Just got the a140-2: it's a lot of envelope in a small space. The CVT parameter is normalled to a voltage source so you can increase (or decrease) the exponential nature of the time-based envelope segments just by turning it, which allows you to tune the shape of the envelope. The module has a number of jumpers that allow you to set various options so it's actually rather more well specified than it appears. The small pots work well, with a much smoother and more pleasing travel than I was expecting. I bought this for my desktop satellite but I may get another one for the main cases...
:sb:
poatoae wrote:Detroit Modular has the A-140-2 and the A-132-8 now.
:guinness:
edit - scored the A-140-2 from Detroit. Thanks for the heads-up.
FS: SP-555 Sampler, Pedals, ASol SQ8 - CHEAP!!!
https://www.muffwiggler.com/forum/viewt ... 4&t=227738
GNSDG
Post by GNSDG » Mon Sep 10, 2018 7:06 pm
Any more experiences with these, esp. A-140-2?
WTB: Your 54HP lunchbox!
Post by MindMachine » Fri Sep 14, 2018 11:42 pm
Got mine in. Have left the jumpers as stock as frankly that is the config I will use most. I might change the second envelope to have CTG over 'all' instead of just decay. The smaller knobs still give detailed response. I think this thing is a great double envelope. Would be real good HP usage for a beginner rack. Very recommended, especially for a starter unit. Dense for 8HP.
Keltie
Post by Keltie » Sat Sep 15, 2018 4:24 pm
Of the new modules I’m most interested in the a142-2, the dual a/r vca combo. Does anyone have any further insight on when these are out? Doepfer website says July, and hasn’t been updated in a while. Any insider info?
Rigo
Chief Spam Killer
Post by Rigo » Sun Sep 16, 2018 1:56 am
Keltie wrote:Of the new modules I’m most interested in the a142-2, the dual a/r vca combo. Does anyone have any further insight on when these are out? Doepfer website says July, and hasn’t been updated in a while. Any insider info?
According to the Doepfer News page ( http://www.doepfer.de/new_e.htm ) that one should be available now.
Post by MindMachine » Sun Sep 16, 2018 2:05 am
Keltie
Post by Keltie » Sun Sep 16, 2018 5:13 am
Thanks rigo and mm. I’ll check with Juno that they’re actually in stock. I think that has come onto their page very recently, and no one else say that they have em... I d been checking at thomann who still don’t....
suthnear
Post by suthnear » Mon Oct 01, 2018 7:30 am
suthnear wrote:One small downside is that it seems to need a fairly large gate signal to open properly. The gates from my expert-sleepers es-40 expanders do not work well with it: decay doesn't work at all (release might not have, either). It worked fine with an es3, however. I will investigate this further when I have a chance.
This was a PEBMAC: smoothing was turned on for that channel in silent way and it obviously just slowed down the slope enough that it didn't trigger the envelope properly. When I set it to 0, the envelopes trigger normally
Shledge
Post by Shledge » Mon Dec 10, 2018 6:16 am
I noticed the A140-2 won't trigger properly with my nerdseq. It seems it's really picky about finding an "edge" in order to trigger rather than just a voltage level. Checked on the oscilloscope and found that the nerdseq's trigger outs have a very slight soft edge to them - works fine for everything else, but not for picky modules like the A-140-2. Amplifying the trigger outs works, but I'm wondering if it can be modded to be made more sensitive.
Other than that, it's a great little module. I like how I can CV control decay/release.
amalthea
Post by amalthea » Mon Dec 10, 2018 4:57 pm
Does anyone know if the A140-2 is pretty much the same as the original A140 x2? In other words, does it have the same shape/slope for the A+D stages, and the same range time ranges?
Shledge
Post by Shledge » Mon Dec 10, 2018 5:02 pm
Erm, being analogue modules, they will always be a bit different.
The A140-2 is pretty snappy, but the time ranges are variable by the CVT pots/CV inputs unlike the A140. This means not only you can fine tune your time range, but control it by CV.
Although it's more accurate to say that it's not really changing time range, but the curve of the envelope, which gives the same effect (along with making it snappier).
cg_funk
Post by cg_funk » Mon Dec 10, 2018 6:29 pm
Have to say I have really been enjoying the A-142-2. The simplicity of having a couple envelopes pre-patched to VCAs is really nice. There are really a lot of pin-options on the back, and I haven't explored that yet.
I am however already seriously considering making a breakout plate with a couple jacks for envelope-outputs. I feel I'd rather have envelope out than ducking-in, personally.
boxxgrooved
Post by boxxgrooved » Mon Dec 10, 2018 9:48 pm
cg_funk wrote:Have to say I have really been enjoying the A-142-2. The simplicity of having a couple envelopes pre-patched to VCAs is really nice. There are really a lot of pin-options on the back, and I haven't explored that yet.
I have been enjoying the ease of patching with the A-142-2 also and agree that envelope out jacks would be more useful. Although I use the A-142-2 a lot I still keep a regular A-140 around for the extremely snappy envelope in the low range setting. I have not been able to achieve such a response from the A-142-2.
I have used the ducking input combined with an A-119 as a useful limiter/compressor on patches that get a bit out of control. Useful on feedback patches that could otherwise slam your recording inputs.
Steve Richards
Post by Steve Richards » Sun Feb 10, 2019 8:22 am
Shledge wrote:I noticed the A140-2 won't trigger properly with my nerdseq. It seems it's really picky about finding an "edge" in order to trigger rather than just a voltage level. Checked on the oscilloscope and found that the nerdseq's trigger outs have a very slight soft edge to them
Hi Folks,
Has anyone tried an A140-2 with a Mother 32? Does it trigger OK from the M32?
Thanks in advance.
Steve
ckwjr
Post by ckwjr » Sun Feb 10, 2019 8:44 am
I just got the 105-4 to go with my 141-4. It's a great combo, but I'm thinking of switching out the 141-4 for the Noise Engineering quad envelope. I've also used the Qu-bit Contour, which has a lot of great features. Something like the Pons Asinorum seems a bit more flexible than both those others, but for now the 141-4 is great to have.
Yodhan
Post by Yodhan » Sun Feb 10, 2019 9:45 am
I got a A-142-2 about a week ago. Haven’t had a whole lot of time with it because I am building a new case and using the rails from my HEK for it, so the rig has been down. That being said, it is a great utility and space saver. I got it because I frequently have a voice that is a pretty basic oscillator to filter to envelope to vca for bass notes and this did the double duty of combing the last two parts, plus giving me two of them. Really couldn’t argue.
My rig: https://www.modulargrid.net/e/racks/view/376480
Behringer Neutron, Behringer Model D, Arturia Microbrute
Tascam 424mkii
Reason for effects and recording
lionelfischer
Post by lionelfischer » Mon Feb 11, 2019 9:45 am
What do u guys think of the comparison between NE since iter and the doeofer 142-2
Not sure what to get
lionelfischer
Post by lionelfischer » Mon Feb 11, 2019 2:38 pm
Yodhan wrote:I got a A-142-2 about a week ago. Haven’t had a whole lot of time with it because I am building a new case and using the rails from my HEK for it, so the rig has been down. That being said, it is a great utility and space saver. I got it because I frequently have a voice that is a pretty basic oscillator to filter to envelope to vca for bass notes and this did the double duty of combing the last two parts, plus giving me two of them. Really couldn’t argue.
does it add any gain
cg_funk
Post by cg_funk » Tue Feb 12, 2019 1:40 pm
lionelfischer wrote: does it add any gain
No, not that I can tell. It has an attenuator to lower the audio-in signal, but that's all. Actually this module really likes a really hot audio-in, and with snappy envelopes you may need to boost the output a bit.
It has a ton of pin switches on the back, so there are a number of different ways to configure the A-142-2.
