Meng Qi Lines - manual avialable?
bommelito
Post by bommelito » Sat Aug 18, 2018 11:55 am
Hi,
today I received my Meng Qi Lines module. Does anybody know of a manual for this module? The website doesn't seem to provide one (I'm only guessing, because the website does not show properly, tried with several browsers, but all I can see is the photo).
Also, for those interested in the module specs, I measured it with my Joranalogue Test3, and found the following power specs:
+12V 18 mA
-12V 20 mA
+5V 0 mA
I have updated the MG module page accordingly.
autodafe
Post by autodafe » Thu Feb 14, 2019 9:38 am
same question, I bought one used and now I am like... "WTF"???
motorhead412
Post by motorhead412 » Thu Feb 14, 2019 10:49 pm
chiming in because i'm interested in Lines, wanted to learn more about how i could use it but was baffled by the lack of a manual
muhimnested
Post by muhimnested » Sat Feb 16, 2019 1:12 am
You could try reach out to Mengqi. He's active here, on his Facebook page and Instagram. I've gotten responses through his Etsy sales page.
reppiks
Obscure Intergalactic Destroyers!
Post by reppiks » Sat Feb 16, 2019 8:45 am
Top 4 jacks are inputs.
Lower 4 jacks are outputs.
You can route the ins to the outs in any combination(s) by pressing down the springs to complete the circuit.
The shapes of the copper squares under the springs show which are the common outputs for each channel (eg the top left square is missing the top left corner, as are the 3 other squares going diagonally down. Thus these 4 squares connect the corresponding 1-4 input signals to the first output. Note the symbol by the channel 1 output: it shows those 4 diagonal squares).
That’s all there is to it. The trick to understanding the connections is in the shapes and symbols on the module itself, which are clear and intuitive.
distancing
Post by distancing » Sat Feb 16, 2019 12:47 pm
are they latching connections or momentary?
coolshirtdotjpg
Post by coolshirtdotjpg » Sat Feb 16, 2019 3:28 pm
reppiks wrote:Top 4 jacks are inputs.
That and if you don't plug anything into the top there is still a normalled connection that gives you voltage. Haven't measured what that is yet.
Semi related, I used this normalled voltage in Lines as well as the Teleplexer to produce an atypical version of Rings into Clouds:
New video for my track
Opening The Portal
reppiks
Post by reppiks » Sun Feb 17, 2019 1:42 am
distancing wrote:are they latching connections or momentary?
Momentary: the circuit is only completed by the spring
f33d
Post by f33d » Wed Feb 27, 2019 2:13 pm
is Lines somehow "touch sensitive", I mean can I decide with my finger-force how wide the vca opens? or is it just "spring touches metal = vca fully open"?
thanks!
coolshirtdotjpg
Post by coolshirtdotjpg » Wed Feb 27, 2019 3:22 pm
f33d wrote:is Lines somehow "touch sensitive", I mean can I decide with my finger-force how wide the vca opens? or is it just "spring touches metal = vca fully open"?
thanks!
It's touch sensitive if you ignore the spring and push your finger on the contact.
Opening The Portal
adaris
Re:
Post by adaris » Fri May 22, 2020 8:21 pm
thanks!
I got one of these today and on mine at least that is not the case. Ignoring the spring and pushing my finger on the contact doesn't generate any voltage at all.
coolshirtdotjpg
Re: Re:
Post by coolshirtdotjpg » Fri May 22, 2020 8:35 pm
thanks!
Are you touching multiple contact points?
Opening The Portal
adaris
Re: Re:
Post by adaris » Fri May 22, 2020 8:40 pm
thanks!
Nope.
coolshirtdotjpg
Re: Re:
Post by coolshirtdotjpg » Sat May 23, 2020 5:10 am
thanks!
Nope.
Well then it won't work, obviously because the module is about bridging voltage between multiple points.
Opening The Portal
adaris
Re: Meng Qi Lines - manual avialable?
Post by adaris » Sat May 23, 2020 5:53 am
Thanks, I figured that out, was just posting so that nobody would be misled by your previous, incorrect, assertion.
