ACL Sinfonion
- zengomi
- Wiggling with Experience
- Contact:
Re: ACL Sinfonion
Honestly, I've yet to hear anything employing the Sinfonion that I'd care to listen to again. [Harsh? Yah. So?] The issue is it's either utterly derivative conceptually or sonically weak. Mostly the former. I have a Sinfonion. Have yet dig into it. Ground zero is still ground zero.
Full speech set to music.
Re: ACL Sinfonion
Want.
Does anyone happen to know when Perfect Circuit will be restocked?
Re: ACL Sinfonion
I read every posts about VCMC on this thread...and I'm not that sure if it's the right choice (if there is any) for sending midi information (chords) to my polysynths...what did you use for doing this? Is VCMC an "ok but not perfect solution"?
"Those aren't your daddy's waveforms " Cynthia Webster
Re: ACL Sinfonion
We used two Doepfer A-192-2 Dual CV/Gate to Midi Interfaces but accuracy and precision were difficult to obtain. Doepfer have a bunch of great modules, the A-192-2 is not their best. Then we tested the ADDAC 222, the most clever and direct control of parameters. People at ADDAC helped us to find the best ways to fix many bugs and we were not far from the top when we discovered the Expert Sleepers General CV module. This one with its MIDI breakout expander is the most precise of all the tested modules. The only difficulty is to set the parameters with an ultratiny screen and many menus. The last we are checking now is the CVThing from Befaco. Better screen but software difficulties. Like people at ADDAC, Doepfer and Expert Sleepers, people at Befaco are always here to help and I'm sure in 2021 we'll reach the top with all these brands.
This experiment with a Sinfonion, the General CV and the CVThing. Not perfect but it's in progress :
- SirSickSik
- Learning to Wiggle
Re: ACL Sinfonion
Might it be an idea to add a "semi-random" root progression generator, tonnetz style, that would generate a song sequence for the sinfonion?
Read as, calculating a "sound" progression that returns to the starting key after a set amount of steps with some randomisation of certain parameters of the calculation. (Eg. which and how many transformations may be used within the set amount of steps and how far the progression may move from the starting key.)
Re: ACL Sinfonion
I have the Befaco VCMC as well as the ADDAC221, imho the ADDAC221 is a better choice.
its tracking of CC to MIDI is very accurate. Its much easier to use and the switches allow you to make octave changes on the fly.
The VCMC on the other hand is quite complicated , just a lot of fiddling to get it right didn't like it so much. Especially the tiny little screen that you can't read anything. The design is not very good, felt like they tried to put too much inside something that should be much simpler. Not inspiring.
Re: ACL Sinfonion
You send notes, CV and gates, with the ADDAC221 ?cloudswim wrote: ↑Sat Feb 13, 2021 7:31 amI have the Befaco VCMC as well as the ADDAC221, imho the ADDAC221 is a better choice.
Re: ACL Sinfonion
I have the expert sleeper midi breakout I don’t think it’s more accurate than the ADDAC 221. Mode C on the ADDAC is a dream to use, I highly recommend it for someone looking to convert CC / gate to MIDI. 222 is different unit though. They are built really well also.tokidoki wrote: ↑Wed Dec 30, 2020 11:46 pmWe used two Doepfer A-192-2 Dual CV/Gate to Midi Interfaces but accuracy and precision were difficult to obtain. Doepfer have a bunch of great modules, the A-192-2 is not their best. Then we tested the ADDAC 222, the most clever and direct control of parameters. People at ADDAC helped us to find the best ways to fix many bugs and we were not far from the top when we discovered the Expert Sleepers General CV module. This one with its MIDI breakout expander is the most precise of all the tested modules. The only difficulty is to set the parameters with an ultratiny screen and many menus. The last we are checking now is the CVThing from Befaco. Better screen but software difficulties. Like people at ADDAC, Doepfer and Expert Sleepers, people at Befaco are always here to help and I'm sure in 2021 we'll reach the top with all these brands.
Re: ACL Sinfonion
We use the ADDAC 222 to send chords, notes, pitch-CVs and gates to MIDI. Can you send chords, notes to MIDI with the ADDAC 221 ?cloudswim wrote: ↑Thu Feb 18, 2021 7:47 amI have the expert sleeper midi breakout I don’t think it’s more accurate than the ADDAC 221. Mode C on the ADDAC is a dream to use, I highly recommend it for someone looking to convert CC / gate to MIDI. 222 is different unit though. They are built really well also.tokidoki wrote: ↑Wed Dec 30, 2020 11:46 pmWe used two Doepfer A-192-2 Dual CV/Gate to Midi Interfaces but accuracy and precision were difficult to obtain. Doepfer have a bunch of great modules, the A-192-2 is not their best. Then we tested the ADDAC 222, the most clever and direct control of parameters. People at ADDAC helped us to find the best ways to fix many bugs and we were not far from the top when we discovered the Expert Sleepers General CV module. This one with its MIDI breakout expander is the most precise of all the tested modules. The only difficulty is to set the parameters with an ultratiny screen and many menus. The last we are checking now is the CVThing from Befaco. Better screen but software difficulties. Like people at ADDAC, Doepfer and Expert Sleepers, people at Befaco are always here to help and I'm sure in 2021 we'll reach the top with all these brands.
Re: ACL Sinfonion
Yeh sorry my bad it’s the 222 that sends cctokidoki wrote: ↑Fri Feb 19, 2021 11:06 amWe use the ADDAC 222 to send chords, notes, pitch-CVs and gates to MIDI. Can you send chords, notes to MIDI with the ADDAC 221 ?cloudswim wrote: ↑Thu Feb 18, 2021 7:47 amI have the expert sleeper midi breakout I don’t think it’s more accurate than the ADDAC 221. Mode C on the ADDAC is a dream to use, I highly recommend it for someone looking to convert CC / gate to MIDI. 222 is different unit though. They are built really well also.tokidoki wrote: ↑Wed Dec 30, 2020 11:46 pmWe used two Doepfer A-192-2 Dual CV/Gate to Midi Interfaces but accuracy and precision were difficult to obtain. Doepfer have a bunch of great modules, the A-192-2 is not their best. Then we tested the ADDAC 222, the most clever and direct control of parameters. People at ADDAC helped us to find the best ways to fix many bugs and we were not far from the top when we discovered the Expert Sleepers General CV module. This one with its MIDI breakout expander is the most precise of all the tested modules. The only difficulty is to set the parameters with an ultratiny screen and many menus. The last we are checking now is the CVThing from Befaco. Better screen but software difficulties. Like people at ADDAC, Doepfer and Expert Sleepers, people at Befaco are always here to help and I'm sure in 2021 we'll reach the top with all these brands.
- mdoudoroff
- Super Deluxe Wiggler
Re: ACL Sinfonion
The ADDAC221 is the 10X9 Channel CV to CC MIDI System
The ADDAC222 is the Multiphonic CV-to-MIDI Notes module
The current options for CV-to-MIDI notes seem to be:
ADDAC222
Analogue Solutions RS-300 (maybe)
Befaco VCMC
Befaco CV Thing
Doepfer A-192-2
Expert Sleepers General CV (with MIDI expander)
Expert Sleepers Disting (with MIDI expander)
SDS Accord Melisma
Tubbutec uTune
CV to MIDI is clearly a relatively straightforward problem.
Fabricating MIDI notes from CV is evidently not a straightforward problem.
ADDAC222
Befaco VCMC
Befaco CV Thing
Doepfer A-192-2
SDS Accord Melisma
Tubbutec uTune
Re: ACL Sinfonion
Great overview. If introducing a DAW is not a problem, Expert Sleepers ES6 (with ES3) combined with Silent Way is another option.
Re: ACL Sinfonion
Time for proper comparison?mdoudoroff wrote: ↑Sun Feb 21, 2021 8:24 amThe ADDAC221 is the 10X9 Channel CV to CC MIDI System
ADDAC222
Befaco VCMC
Befaco CV Thing
Doepfer A-192-2
SDS Accord Melisma
Tubbutec uTune
Thank you for listing them!
- canopychasesounds
Re: ACL Sinfonion
We tested the two channels Doepfer A-192-2, the four channels ADDAC 222, the four channels General CV with Breakout MIDI expander and the four channels Befaco CV Thing. We have one more that is not Eurorack, the Kenton mono pro CV to MIDI box.Jaypee wrote: ↑Tue Feb 23, 2021 3:50 pmTime for proper comparison?mdoudoroff wrote: ↑Sun Feb 21, 2021 8:24 amThe ADDAC221 is the 10X9 Channel CV to CC MIDI System
ADDAC222
Befaco VCMC
Befaco CV Thing
Doepfer A-192-2
SDS Accord Melisma
Tubbutec uTune
Fabricating MIDI notes from CV is evidently not a straightforward problem.![]()
The one we use actually is the General CV. The ADDAC and the Befaco are waiting updates and the Kenton is waiting to be tested.
Re: ACL Sinfonion
Thank you. We will upload other experiments during the month of March.canopychasesounds wrote: ↑Tue Feb 23, 2021 6:56 pmThis is really beautiful. I'd love to hear this at about 80% its current tempo.
- Common Wiggler
Re: ACL Sinfonion
<Ooops, ignore>
Re: ACL Sinfonion
I think this refers to that famous Zen koan “What is the sound of one quantizer quantizing?”LunaticSound wrote: ↑Thu Feb 25, 2021 6:22 am
Err, am i misunderstanding you here? Are you saying, you don´t like the sound of the sinfonion?
- Der Mann mit der Maschine
- Common Wiggler
- Contact:
Re: ACL Sinfonion
Hi,
I am thinking about support MIDI in/out with the DROID.
Part of that would be a CV to MIDI gateway. It would support up to eight CV/Gate input pairs, would have
very precise AD converters and low latency. And would allow flexible mapping of everything.
Could you say what would be the most important features for this apart from that? Where are the usual pain points or deficiencies in the
existing solutions? What would be a reason e.g. for you to check out such a new solution?
Mathias
Mathias
tokidoki wrote: ↑Tue Feb 23, 2021 8:11 pmWe tested the two channels Doepfer A-192-2, the four channels ADDAC 222, the four channels General CV with Breakout MIDI expander and the four channels Befaco CV Thing. We have one more that is not Eurorack, the Kenton mono pro CV to MIDI box.Jaypee wrote: ↑Tue Feb 23, 2021 3:50 pmTime for proper comparison?mdoudoroff wrote: ↑Sun Feb 21, 2021 8:24 amThe ADDAC221 is the 10X9 Channel CV to CC MIDI System
ADDAC222
Befaco VCMC
Befaco CV Thing
Doepfer A-192-2
SDS Accord Melisma
Tubbutec uTune
Re: ACL Sinfonion
When a tree falls in the woods, and no one is there to record a sample, is it still great material for the next banger?ModusOp wrote: ↑Thu Feb 25, 2021 6:35 amI think this refers to that famous Zen koan “What is the sound of one quantizer quantizing?”LunaticSound wrote: ↑Thu Feb 25, 2021 6:22 am
Err, am i misunderstanding you here? Are you saying, you don´t like the sound of the sinfonion?![]()
Re: ACL Sinfonion
Der Mann mit der Maschine wrote: ↑Thu Feb 25, 2021 6:37 amHi,
Mathias
Hello,
Actually, according to our experiments, the General CV is the most accurate to translate notes and velocity to MIDI, but only for 4 voices. What we use are three channels for the Sinfonion quantizers, one for the arpeggiator and a global velocity channel. And we try to use the Befaco CVThing for chords. This Befaco module has a good screen but actually needs some update for precision of translation at high tempo.
What we would like to find in another solution would be constant precision with conversions and to be able to easily change the configuration of the 8 MIDI channels parameters, perhaps with 8 or 16 memories for global configurations. Ok, 8 memories would be enough. We like the options on the ADDAC 222 to directly modify parameters with switches and potentiometers, so to find such possibilities with 8 channels would be fine too. Ah, and a mute switch fonction for each 8 channels. Actually we use an Happy Nerding mute module for 4 channels and one gate out from the Sinfonion to control a 4ms SCM Breakout module mute fonction for the Befaco.
We hope our english doesn't need too many updates...
Thank you again for the Sinfonion, great module.
Jean
