Schlappi Engineering - Angle Grinder
ablearcher
Post by ablearcher » Mon Nov 19, 2018 10:02 am
bommelito wrote:How deep / skiff-friendly is this beast?
about 27mm behind the panel with a cable plugged in. Single PCB horizontal to the panel, very skiffable! 8-)
bommelito
Post by bommelito » Mon Nov 19, 2018 10:08 am
Thanks! I'm gonna get me one for sure!
electrik noize
Post by electrik noize » Mon Nov 19, 2018 11:17 am
Well I thought I was done with my rack, but I guess not :lol: This VCO sounds amazing.
breadman
Post by breadman » Mon Nov 19, 2018 1:35 pm
Not a lot of new modules to get excited about lately. This one is an exception!
email: jschnvr@gmail.com
IG: @jackssynthbazaar
Cybananna
Funniest Guy
Post by Cybananna » Mon Nov 19, 2018 1:38 pm
I ordered one yesterday.
gummyboy
Post by gummyboy » Mon Nov 19, 2018 7:08 pm
received it!!!
bcomnes
benjolin => Angle Grinder
Post by bcomnes » Sun Dec 23, 2018 11:10 pm
OK FWIW here is that Benjolin feeding into an Angle Grinder...with a touch of H9 ambience .....enjoy....http://soundcloud.com/baghead/randoml-lights
Too Loud?
Too Bad
Hyberus
Post by Hyberus » Wed Dec 26, 2018 2:42 pm
Just when I thought that I didn't need/want another oscillator. You know what this means? Serious rack re-arrangement, and something has to go into temporary retirement.
Random is the new maRnod
gummyboy
Post by gummyboy » Thu Dec 27, 2018 6:14 am
Hi.
Can anyone explain a bit more about the "damping"?
I get so far...
1. For output of clean signal(like sine) from 4 spin outputs, it needs to be CCW.
2. It's used as resonance when AG is used as filter.
However, it changes sound somehow when I get output from "grind" out.
Big Thanks!!!!
ablearcher
Post by ablearcher » Thu Dec 27, 2018 9:51 am
hi gummyboy
Hi.
I get so far...
Big Thanks!!!!
The grind section will compare whatever is coming out of the four spin outputs with the grind input and subtract those compared signals from the input signal.
If the DAMPING and GRIND->SPIN knobs are CCW then the spin section is an oscillator and the grind section will be comparing a sine wave against an unrelated input signal. This effect is in the ball park of ring mod or sync effects.
If DAMPING and GRIND->SPIN knobs are CW then the spin section is filtering the input signal and the outputs are filtered versions of the input, this means when you compare them against the input you are comparing and subtracting the signal against itself and creating a feedback path. This effect is tends to be somewhere between that of distortion and self resonating filters.
If you the controls are somewhere between those two modes you get a mixture of both types of effects.
Does that help?
ablearcher
Post by ablearcher » Thu Dec 27, 2018 10:37 am
I have been receiving requests to show some of what the Angle Grinder can do with a drum machine as the input, here is a video with the Tom Cat :hihi:
radin
Post by radin » Thu Dec 27, 2018 12:54 pm
:deadbanana: jeezuz...filthy
gummyboy
Post by gummyboy » Fri Dec 28, 2018 3:12 am
ablearcher wrote:
Does that help?
Yes. It helps. However still confused.
With the setting in the pic, sound disappears if "damping" knob goes after 9 o'clock toward CW.
Nothing comes out of grind out or spin out. And all the LEDs around spin knob is gone.
Is it normal?
ablearcher
Post by ablearcher » Fri Dec 28, 2018 10:08 am
gummyboy wrote:
ablearcher wrote:
Does that help?
Is it normal?
Yep! With no external input turning up the damping (CW) will stop it from oscillating, when using it as a standalone oscillator i would always keep damping fully CCW. It is there for when you are processing external signals and and want it to behave more like a filter.
Hyberus
Post by Hyberus » Mon Jan 07, 2019 3:53 pm
OK, got mine now. Not had much time to play with it yet, but it's a beast. The manual leaves a little to be desired, in my opinion, but luckily I'm more of a stick some cables in and see what happens sort of guy
Outsider Sound Design
Post by Outsider Sound Design » Fri Jan 11, 2019 12:06 pm
Sound design experiments. Schlappi Angle Grinder processing / destroying 2 Noise Engineering Basimilus Iteritas.
Sound Design / Sample Packs
www.outsidersounddesign.com
Test Series Sound Design Blog
www.outsidersounddesign.com/blogs/news
Experimental Music
www.adarkplotofland.bandcamp.com
matttech
Post by matttech » Fri Jan 11, 2019 6:39 pm
That was INTENSE! :zombie: :zombie:
Hyberus
Post by Hyberus » Sat Jan 12, 2019 8:51 am
Sadly family circumstances have meant that I've barely had time to do anyhing with my Angle Grinder other than screw it into the rack and check that it works. Look forward to Monday afternoon, when I have the day off work and can give it a proper going over.
spinalbeatz
Post by spinalbeatz » Thu Jan 17, 2019 12:58 pm
Now in Black :twisted:
motorhead412
Post by motorhead412 » Thu Jan 17, 2019 1:17 pm
spinalbeatz wrote:Now in Black :twisted:
shit yeah!
reppiks
Obscure Intergalactic Destroyers!
Post by reppiks » Thu Jan 17, 2019 5:32 pm
Yeah! I ordered a black one yesterday. So excited to mangle stuff through this module!!
droningspaghettimonster
Post by droningspaghettimonster » Fri Mar 08, 2019 5:27 pm
Just received two of there
Ive only scrathed the surface, and I can confirm that:
- perfect built
- amazing as a modulator... just look at all the cv inputs... very organic and evolving shapes to be discovered with other modulators
- amazing as a vco (very subtle but beautiful linear fm, exponential fm is more interesting to me, metallic and pronounced but able to track reasonably too on subtle settings) with many beautiful and harsh waveforms and tracks perfectly
- literally insane as a vcf/distortion
- super fun. very open ended design, still no obvious quirks even though its analog and at least 3 super powerful functions that leave some standalone modules that do only one thing out in the rain
- very reasonable price
go support that guy :nana:
Oldstench
Post by Oldstench » Fri Mar 08, 2019 11:35 pm
Exceptional work.
Humanity has doomed itself.
reppiks
Post by reppiks » Sat Mar 09, 2019 12:12 am
+1 to all these comments. This is an absolute beast of a module and a total delight to mess around with! Very very very satisfied!
droningsphagettimonster wrote:Just received two of there
- perfect built
Post by droningspaghettimonster » Sat Mar 09, 2019 9:16 am
Very friendly guy, too!
