According to my measurements the usable depth on all three is a little under what is specified on the 4ms site and printed sheets that come with the Pods, which is 34.2 mm. Per my measurements any module that needs 32 mm or under with the power cable attached will fit, under 33 mm might fit, 33 mm and over probably wont fit.
Here's a picture of an older Division6 Multiplicity VI mounted in a Pod26. I modified the module by removing the cascade jacks on the bottom to make it less deep. As it is now, using a power cable without a strain relief the module needs exactly 33 mm of case depth and I had to force a bit of flex to screw it down all the way. (not sure if the edges of the Pod flexed or the module's PCB did, probably a bit of both?) I think I can lose a 1/2 or more of a mm by filing down the power cable connector a bit so that the module will fit comfortably without any pressure?
