is there any reaso why i cant house modules in a setup using the following:
https://www.ebay.co.uk/itm/NEW-Startech ... 0005.m1851
£45 x1 = £45
https://synthracks.com/shop/eurorack-19-rack £40 x3 or 4 = £120
http://tiptopaudio.com/uzeus/ £70 x2 = £140
45 + 120 + 140 = £305 for 12U x 84HP with power...
cheap case now rast is no more?
- PhineasFreak
RYO DIY is back, exclusively available from Synthcube!
https://www.waxcide.com
http://waxcide.bandcamp.com/
https://www.youtube.com/channel/UCjpm-6 ... 5YVm6_jg_w
- windspirit
Re: cheap case now rast is no more?
You're definitely better off investing in a larger power system.PhineasFreak wrote: http://tiptopaudio.com/uzeus/ £70 x2 = £140
DC converters like the uZues are great for small systems (the HEK is the perfect example) where it's just a few modules and noise isn't a concern. Once people start pushing the amount of modules they're powering they start reporting problems, multiple strained supplies will only make those problems worse.
I'd rather mount the rails in an ABS Instrument case (pelican or generic brand), a suitcase, or save a little more for an ABS flight case for 9-12ru of gear. If you're going to be travelling then the case is an investment
Check out the DIY cases's thread in the DIY section, lots of cheap solutions to portable systems in there
For a more robust option, if a bit pricier:
https://www.thomann.de/gb/thomann_pop_u ... k_case.htm
actually...
https://www.thomann.de/gb/thon_19_koffer_12he.htm
i myself use a couple of those. currently on brackets on my wall above my setup. Solid, cheap and practical, also played live with it a few time, threw it at the back of vans and so on. couple of uzeus per box. synthrack's frames and off you go. yes , a tiny weeny bit more expensive, but come on.... the price difference is like a passive attenuator or something....
edit: ah, DJ_JITTER was on a close equivalent already
