Modes: 21 eurorack cheat sheets for iOS & web
th0mas
Post by th0mas » Sat Apr 20, 2019 8:29 am
HAPPY EASTER!
I just released version 2.0, which adds a patch generator!!!
At the bottom of the module list, tap the new "Generate Patch" button. Modes will now pick a mode at random for all the multi-mode modules active in your module list (you can hide modules you don't own with the edit button from the module list). Pull to refresh to get a new idea.
It just went live to the App Store, so it should be available within the next 24 hours.
bengersfood
Post by bengersfood » Sat Apr 20, 2019 9:35 am
th0mas wrote:
FadingCanvas wrote:Bought the app, great! Little request: can the information about MI Elements mode-changes be included?
How about I release an alt firmware that makes it way easier to switch elements modes? I wrote one awhile back, and just recently bought an elements, so after testing it I'll release it! I did a similar one with Rings.
That would be excellent. Thank you in advance.
nostalghia
Post by nostalghia » Sat Apr 20, 2019 12:00 pm
th0mas wrote:(you can hide modules you don't own with the edit button from the module list).
You many have changed this in the new version, or it works differently with the "Generate Patch" function- but it seems like a better way to temporarily hide modules you don't own in the current version would be to tap the "+" button and then use the toggle switches in the "Add Modules" screen to switch off (hide) the ones you don't own.
Using the "Edit" button (rather than "+") brings up "minus" signs next to each listed module, with only the option to delete it. Didn't try it, in case I buy a module I don't own now at some point, as I was worried that once deleted, you can't just unhide it from the list later as it would not be accessible at all. Since I'm making an assumption, can you confirm what happens if you delete a module from the list, using Edit? Can you still get them back later by switching them on using "Add Modules" (+ sign)-will they appear in that list?
By the way, I love your app and use it often for reference. Very handy if it's been awhile since you last used a particular module and forgot how to access a mode or what its parameters are. Especially recommended to Disting users. So big thanks for "Modes", and all the updates.
“If you look for a meaning, you'll miss everything that happens.” - Andrei Tarkovsky
https://soundcloud.com/nostalghia70s
batch
Post by batch » Sat Apr 20, 2019 1:15 pm
Just bought the app, nice work!
Can we submit cheat sheets for inclusion?
Would love to see Mother 32, Copper Traces Seek, Metropolis get added amongst many others.
FS: Erica Synths Hi-Hats D $175, Cymbals $175, Stereo Mixer v2 $100, Intellijel 1U Pedal IO $70, MIDI $110, Rebel Tech Bit Reactor $95
batch
Post by batch » Sat Apr 20, 2019 1:16 pm
And O_C
th0mas
Post by th0mas » Sat Apr 20, 2019 1:29 pm
Oh! That's unfortunate naming on my part. If you "Delete" a module from the list it just hides it, the same as unselecting it under "+". Renamed that red button to "Hide" for the next version, thanks for the feedback :)
FadingCanvas
Post by FadingCanvas » Tue Apr 23, 2019 12:23 pm
:hihi: would be even better :hihi:
allert
Post by allert » Tue Apr 23, 2019 5:28 pm
Purchased! Nice work. Are you considering adding more in the future? Here’s my request: Prizma sequencer.
franman69
Post by franman69 » Tue Apr 23, 2019 8:13 pm
Just purchased this to try... I'd like a bit more helpful hints on the Morphagene page if possible.. Thanks!
franman69
Post by franman69 » Tue Apr 23, 2019 8:15 pm
Yes Prizma and Eloquencer would be nice... hmmm...
Tetrapad
O_C
just ideas...
th0mas
Post by th0mas » Wed Apr 24, 2019 6:27 am
franman69 wrote:Just purchased this to try... I'd like a bit more helpful hints on the Morphagene page if possible.. Thanks!
Hi, can you elaborate on what you feel is missing? Thanks!
Will add tetrapad to the queue, good idea.
insoul8
Post by insoul8 » Wed Apr 24, 2019 7:55 am
Ornament and Crime would be a fantastic one to add. I'm loving the app so far and it has been a huge help compared to when i would keep separate cheat sheets in my Dropbox and fumble through them on my phone. Thanks!
soon_come
Post by soon_come » Mon Apr 29, 2019 11:31 am
Just bought this as well (mostly for the Disting mk4). Thanks!
th0mas
Post by th0mas » Thu Jul 18, 2019 8:13 am
Just released 2.1.
Updated Disting mk4 to firmware 4.12. Added Ornament & Crime stock.
Added Mannequins W/, TipTop Audio ONE and TG ONE (by contributors, thank you!).
Let me know if there's any errors!
Tom
insoul8
Post by insoul8 » Fri Jul 19, 2019 1:38 pm
This program has been great! Thanks.
It might be kind of useful to add a section that has all the logic truth tables too.
SmartBits
Post by SmartBits » Wed Jul 24, 2019 2:27 am
Maybe an idea to add MN René's scales cheatsheet (by user hyperdriver)? I use that quite a lot...:
http://www.hyperexmachina.co.uk/uploads ... _v0_91.pdf
th0mas
Post by th0mas » Sat Oct 19, 2019 1:57 pm
Just released a new version, with updated Disting firmware to 4.13.
BogartDestructo
Post by BogartDestructo » Sun Oct 27, 2019 10:26 am
Just picked this up...great work sir!
Only have a Morphagene and a couple of Disting MK4’s off the list off modules. Would be nice to see Marbles on there, and also Tetrapads many modes!
carlfunkenn
Re: Modes: 21 eurorack cheat sheets for iOS & web
Post by carlfunkenn » Sat Nov 02, 2019 12:50 pm
th0mas wrote:Hi
Modes is an unofficial phone-friendly cheat sheet for iOS and web.
It currently supports 22 modules/firmwares:
Expert Sleepers:
- Disting mk3
- Disting mk4
Make Noise:
- Morphagene
- Tempi
Mannequins:
- Just Friends
- W/
Mutable Instruments:
- Braids (stock and Renaissance firmware)
- Clouds (stock and Parasites firmware)
- Frames (stock and Parasites)
- Peaks (stock and Dead Man's Catch)
- Plaits
- Streams
- Rings
- Warps (stock and Parasites)
Erica Synths:
- Blackhole DSP 2
- Pico Logic
- Pico Seq
TipTop Audio
- ONE
- TG ONE
Ornament & Crime
- Stock
Search by text or mode type to quickly get the most out of your module. Favorite pages for quicker reference.
Get rid of your binder of printed PDFs, SynthModes is faster and easier to use.
Modes for iOS is not officially endorsed or supported by any modular manufacturer.
Modes lets you see the input/output and parameters of all module modes, and sort them either by order or where applicable, by their module type.
I made this app after being frustrated with the lack of phone friendly manuals for my disting mk4.
It is available on the iOS app store here:
https://itunes.apple.com/ca/app/modes/id1445358435?mt=8
A web version is available at https://synthmodes.com
The cheat sheets are now open source to promote reuse and contribution. You can find them at https://github.com/boourns/synthmodes
Please use this thread for feedback and feature requests on the application. Thanks!
:nana:
Franktree
Post by Franktree » Tue Dec 31, 2019 8:26 pm
Love this app! It's a fairly new module, but the three new Tiptop effects modules--Z5000, Echoz, and whatever the reverb unit is called, could definitely use to be covered in this app!
Franktree
Post by Franktree » Thu Jan 09, 2020 12:07 am
Also, no big deal, but I think there's a mix up in app for the Dead Man's Catch version of Peaks. The light symbols that designate the randomized drums and the randomized high hat are reversed, I believe.
ToddOMG
Post by ToddOMG » Thu Jan 09, 2020 2:22 am
Please add modes for Pico DSP and OC Hemisphere! I’d buy immediately.
loydb
Post by loydb » Thu Jan 09, 2020 9:41 am
Thanks so much for O+C, this has made it incredibly useful for me.
15U 168hp Zebrawood case Build Log [FINISHED]: https://www.muffwiggler.com/forum/viewt ... p?t=134540
MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/view ... 797#308797
MFOS Mini-Controller Build Log [FINISHED!]: http://www.electro-music.com/forum/view ... hp?t=42968
th0mas
Post by th0mas » Tue Mar 24, 2020 10:51 pm
Hello!
I've added Moog Mother32 to the synthmodes website here: https://synthmodes.com/modules/mother32/
Could someone check it and let me know if it makes sense? The sequencer on the mother32 is.. much more complex than I would have thought. And aside from a few doodles in the music store I've never really spent time with it. If you're comfortable with the mother32 sequencer and have some time, please DM me after reading that link.
Will be added to the app once I have a few more modules to add, and it's been sanity checked
Naenyn
Post by Naenyn » Fri Mar 27, 2020 12:42 am
I’ll take a look at the Mother-32 this weekend.
Any chance you could add the 4ms SWN?
Edit: Arbhar would be a nice addition too.
-n :ninja:
My racks on ModularGrid
Find me on MuffWiggler's Discord
