Prok Drum modules
Moderators: lisa, Kent, Joe.
a773
Post by a773 » Wed May 08, 2019 7:18 am
Ok great!
I didn't want to post there, thinking it was solely related to the editor. But I'll go ahead. Thanks!
Bartelby
Post by Bartelby » Fri May 10, 2019 12:56 pm
Here's a brief showing of some new features...
a773
Post by a773 » Fri May 10, 2019 2:05 pm
Great!
Will the new firmware automatically load from SD card (if inserted at power up), or to I have to hold the button down?
MDK
Post by MDK » Sat May 11, 2019 4:35 pm
if the question is will the new firmware automatically load PATCHES from SD at power up, then yes that's an option that has been added.
You can either keep it as it is now and only check SD with button or the new option will always check SD and load any patches that are found. If there is no SD then you just have to wait a couple of seconds while it checks for SD and then boots as normal.
Also we've removed the naming requirements on SD card patches, so you can call them anything you like unless you want them assigned to a specific slot then you can use the current naming scheme, kick_0.prk etc..
a773
Post by a773 » Sat May 11, 2019 4:37 pm
Amazing, all my dreams came true!
Where can I get it? :yay:
GBRL
Post by GBRL » Wed May 15, 2019 10:05 am
Hello Community!
I've build all 4 modules and everything works perfect except of one X-Knob on one module. Both CV inputs working fine there, only upper Knob doesn't respond.
The problem should be somewhere on the back board: if I switch it to another front board, the X-Knob will not work there. Visually, I dont see anything suspicious. Can someone help to pinpoint the problem?
Thanks a lot!
Monobass
thonk.co.uk
Post by Monobass » Wed May 15, 2019 11:01 am
GBRL wrote:Hello Community!
Thanks a lot!
This is easy to test for, you should see continuity directly from the middle pin of the X pot right through to the 4th pin up on the left at the bottom of the teensy as shown (via that bottom pin on the left of the header that connects the boards). Test it on one of your working modules first.
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
MDK
Post by MDK » Thu May 16, 2019 3:46 am
atte wrote:Amazing, all my dreams came true!
Right now we're still working on the firmware and the upgrade tool. We'll post updates in all the relevant places when its ready.
If you signed up for the editor beta testing email we'll probably post there first.
GBRL
Post by GBRL » Thu May 16, 2019 11:12 am
Monobass wrote: This is easy to test for, you should see continuity directly from the middle pin of the X pot right through to the 4th pin up on the left at the bottom of the teensy as shown (via that bottom pin on the left of the header that connects the boards). Test it on one of your working modules first.
Awesome, thanks a lot! :tu:
That was the problem, connection was damaged there somehow. Now it works! :banana:
StutzJr
Post by StutzJr » Sun May 19, 2019 2:25 am
Is this new firmware version available for download yet?
I think I missed the signup for the editor beta testing I can't seem to track it down?
Bartelby
Post by Bartelby » Sun May 19, 2019 4:28 am
StutzJr wrote:Is this new firmware version available for download yet?
You should have been sent an email by Thonk for the beta testing.
TLM
Firmware Update
Post by TLM » Mon May 20, 2019 10:02 pm
I just finished the Snare module and I was wondering how to get the new Firmware. Will it auto update when using the editor? So far I didn't use the editor. thanks
MDK
Post by MDK » Tue May 21, 2019 2:14 am
The new firmware is not ready yet.
The editor is available here :
https://normalised.github.io/ProkDrumsEditor/
Circuitnoise
Post by Circuitnoise » Mon May 27, 2019 12:17 pm
Will there be a new hardware revision for the new firmware and the features seen on Superbooth19?
MDK
Post by MDK » Mon May 27, 2019 5:03 pm
No, same hardware.
Circuitnoise
Post by Circuitnoise » Tue May 28, 2019 6:40 pm
Thanks good to know.
As the software editor is release and the current hardware revision will be the same, i think i will order some prok dums :-)
snm
Post by snm » Tue May 28, 2019 9:27 pm
Anybody know what the LED situation is? Is it a lens? Square LEDs?
Bartelby
Post by Bartelby » Wed May 29, 2019 12:45 am
snm wrote:Anybody know what the LED situation is? Is it a lens? Square LEDs?
It’s 4 square LEDs.
TLM
Turn off Trigger Button for silent changes of quads?
Post by TLM » Wed May 29, 2019 12:01 pm
Hi there,
is it possible to turn off the trigger button on the module to make changing quads silent? This would be much better for live situation. Than I can move to a new quad patch while the drums are playing and don't have to worry about fire a trigger that is not in time with my rhythms
Bartelby
Re: Turn off Trigger Button for silent changes of quads?
Post by Bartelby » Wed May 29, 2019 1:23 pm
TLM wrote:Hi there,
I think that might be coming in an update...
MDK
Post by MDK » Fri Jun 07, 2019 8:34 am
You are correct, that will be coming in the next update.
Still no ETA on the update though.
But we did just release the first set of custom patches (and they're free)
https://www.thonk.co.uk/vogel/
Monobass
thonk.co.uk
Post by Monobass » Fri Jun 07, 2019 10:01 am
Treibstoff
Post by Treibstoff » Wed Jun 19, 2019 8:15 am
@Monobass
hi, i have built my first prok BD module so far. everything works great except the SD Card slot. i use a San disc ultra 128Gb at the moment and formatted it ntfs and exfat both. the editor dont see it (no SD). I have copied the Christan Vogel patches as described to the card long press the button during the booting procedure.. nothing happend and the stock patches are still there.
Maybe the SD Card is to big? the Soldering points seems to be fine and i didnt heated it up to much as far i can say.. need help thx
Regards
Monobass
thonk.co.uk
Post by Monobass » Wed Jun 19, 2019 8:20 am
Treibstoff wrote:Maybe the SD Card is to big?
Aha yes it is, sorry the maximum size is 32gb. We will update the instructions to make this obvious.
It's a shame you can't buy 1mb mini SD cards :)
Treibstoff
Post by Treibstoff » Wed Jun 19, 2019 8:23 am
ah ok!!! so iam on the way to the electronic store immediately! want to play with Cristian Vogel kicks :) thanks for the fast help.
Its a awesome module by the way and will buy and build SD and HH very soon :)
