Prok Drum modules
Treibstoff
Re: Prok Drum modules
Post by Treibstoff » Mon Jan 20, 2020 2:26 pm
Theses changes will transform the proks in killer machines! Cant wait for the beta test 😬
morbank
Post by morbank » Mon Jan 20, 2020 8:24 pm
Anyone know if it is possible to edit the parameters by entering specific amounts? For example, I can only select 30.00, 54.85, 79.70...etc. using the cursor for the "Sine A Base Freq" but I see presets with "49.71". Is there a way to type in exact amounts or am I limited to the screen resolution since the Prok editor window isn't resizable?
Monobass
thonk.co.uk
Post by Monobass » Tue Jan 21, 2020 5:13 am
In the new version coming soon we have "Hold down shift to fine adjust a parameter. Hold down ctrl + shift for even more fine control."
This was added specifically as there are better note/frequency input changes coming too.
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
morbank
Post by morbank » Tue Jan 21, 2020 4:43 pm
Perfect, thanks for the update!
Johnny
Post by Johnny » Thu Jan 23, 2020 4:08 am
no update...still waiting
WHEN?!?!
Monobass
thonk.co.uk
Post by Monobass » Fri Jan 24, 2020 6:47 am
WHEN?!?!
Hey Johnny, this was our update from 4 days ago - viewtopic.php?f=16&t=210807&start=198
bemushroomed
Post by bemushroomed » Fri Jan 24, 2020 9:58 am
WHEN?!?!
you better lock yer doors because somehow i dont think that's the reply he wanted..
i know the kind... calls themselves johnny.. has few posts because all work no play and talks in big letters..
Johnny
Post by Johnny » Fri Jan 24, 2020 1:01 pm
OK, want to open up more about your home life?
thanks, sorry I didn't realize it was just 4 days ago...meanwhile, I stick with old editor.
Do you need beta testers?
bemushroomed
Post by bemushroomed » Fri Jan 24, 2020 1:19 pm
aww c'mon, can't take a little joke?
i'm eagerly awaiting it as well.. and yes they need beta testers, probably why they call it a public beta test :tu:
YTNUKLR
Post by YTNUKLR » Mon Feb 10, 2020 1:45 pm
I have the Prok drums and like them.
I just got more into them and read about the expansion-is there any more info about this or it just hasn't come out yet?
bemushroomed
Post by bemushroomed » Mon Feb 10, 2020 2:21 pm
Expansion? If you mean the firmware update no one knows.
Last summer it was "a month or two away" according to one of the devs.
In early January this year it was "going live tomorrow"
Still nothing. But i'm hopeful ;)
Bartelby
Post by Bartelby » Mon Feb 10, 2020 2:40 pm
There’s a 6 pin connector, for an expander module, on the pcb.
BartBral
Post by BartBral » Mon Feb 10, 2020 2:46 pm
No, it didn't come out yet...
The 6 Pin header for expansion "(more news in 2019)" is connected to 4 unused pins on the Teensy. So a new firmware could (in theory) use these pins for more CV-inputs or gates/triggers. But thats all I know...
Johnny
Post by Johnny » Tue Feb 11, 2020 7:23 am
I remember to read somewhere that you can wire up an extra potentiometer via expander pins..
boombipbass
Post by boombipbass » Tue Feb 11, 2020 4:11 pm
Wow great to see the new software, I just finally got the succes of having to work with the editor somehow it only worked via mac and not my windows but darn , this is some hardcore synthese to study. I think that I will have to get my hopes up for nice soundbanks being available soon by lovely wizards.
I was wondering if anyone knows how I could simulate something close to a 909 OH and 909 CH on the HH Prok.
I've been dragging some faders but I get a lot of 808 like sounds and I already got the Tanzbar so it would be great to
add up some 909 bisniss with these units instead of buying a new TipTop One or using the Tiptop HATS.
Does anyone has some clue/leads?
Gringo Starr
Post by Gringo Starr » Tue Feb 11, 2020 5:20 pm
There’s a guy on Reverb.com “James Gear Outlet” that builds these modules. Does anyone have any experience with this builder or can you recommend any?
Weed only gives you the illusion that it’s enhancing your creativity.
Bartelby
Post by Bartelby » Wed Feb 12, 2020 1:36 am
In what way can't you get it to work in Windows?
Have you reported it back to Pr0k?
arechfer
Post by arechfer » Fri Feb 14, 2020 9:32 am
Is there any solution with noise in the modules??
I’ve tried the settings in the editor with no luck
Thanks in advance (I’ve BD, SN & HH...and all have strange sound while listening alone)
suckerformimi
Post by suckerformimi » Fri Feb 14, 2020 9:40 pm
What exactly is the issue?
BartBral
Post by BartBral » Wed Feb 19, 2020 6:15 pm
If you bought the parts yourself:
Check REG1117!!! It must be a 5v version? And NOT a 3.3v version.
I had loads of horrible digital noise/high pitched whining sound and PWM LED bleed thru in the audio outs.
I had bought the wrong REG1117... Now I have put in "LM 1117 MP5,0". And I replaced the 1K5 resistors with 2K7. (resistors: R11, R12, R13, R14, R15) The LEDs are a lot dimmer now, but the PWM bleed thru hum is reduced a lot when turning the pots.
It was still whining a bit too much for my taste, so:
My solutions for PROK SNARE module:
I placed a 150pF capacitor parallel to Resistor R7.
(soldered a 150pF capacitor to the back of the PCB, using the solder pads of R7)
I placed a 560pF capacitor parallel to C1.
(so I just soldered a 560pF capacitor to the back of the PCB, using the same solder pads as C1)
Experiment with the value of these capacitors. The 560pF might be a bit too high for your taste, the higher the capacitor value the lower the cutoff frequency.
My solutions for PROK HIHAT module:
I placed a 220pF capacitor parallel to Resistor R7.
(soldered a 220pF capacitor to the back of the PCB, using the solder pads of R7)
I replaced C1 (this was 150pF) with a 220pF capacitor.
Again, experiment with the value of these capacitors. The higher the capacitor value the lower the cutoff frequency.
My solutions for PROK CLAP module:
Haven't written down the values, and I put it in my rack... so experiment...
My solutions for PROK KICK module:
Still have to make that one so I can't comment on that.... yet.
Hope this helps some people out!
p.s... First check if the REG1117 is the problem. It might be that putting in another one solves the whole PWM-bleed problem without the need of changing the LED-resistors.
