Prok Drum modules
sqwibz
Re: Prok Drum modules
Post by sqwibz » Sun Mar 15, 2020 11:13 pm
Bought the four pack and built them. DB, SN, and HH all work, but I can't get any audio out of CP.
I narrowed the problem down to the back PCB. Output stuck on -10V on Mordax. Any ideas?
Bartelby
Post by Bartelby » Mon Mar 16, 2020 9:36 am
Can you post some high-res photos of the board?
sqwibz
Post by sqwibz » Sat Mar 21, 2020 5:05 pm
Took me a while to get some pictures up, but here they are. Front and back view of the "Back PCB".
a773
Post by a773 » Sat Mar 21, 2020 5:38 pm
Johnny wrote:
Thu Jan 23, 2020 4:08 am
no update...still waiting
WHEN?!?!
Just what I was about to ask...
Naenyn
Post by Naenyn » Sun Mar 22, 2020 12:33 am
Have you tried swapping the teensy to another module just to make sure it is okay?
Edit: also would be good to see how the soldering went beneath the teensy.
-n :ninja:
My racks on ModularGrid
Find me on MuffWiggler's Discord
suckerformimi
Post by suckerformimi » Sun Mar 22, 2020 2:41 pm
I built all four. Def check the teensy, although idk how that would pin the output to -10V.
I did forgot to solder the teensy on one of them. I don't think they actually tell you to solder the teensy in the instructions.
sqwibz
Post by sqwibz » Mon Mar 23, 2020 2:23 pm
Okay, I switched the teensy out to a working module and it's fine. I checked connectivity on the black plastic brick thing with the pins and everything is connected just fine. Looked at all the soldering and it looks okay. switched out one of the IC's and its okay. I left the other one because it doesn't look bad at all. I'm wondering if the regulator might be bad? Maybe that could explain the -10V? Not sure. Any other ideas? I might just order another pcb set if I can't get it to work.
rayultine
Post by rayultine » Wed Mar 25, 2020 1:33 pm
sounds! I have the Prok CP coming soon. Sorry to be a broken record, but the github editor can be used via usb connection to teensy to change which instrument is loaded?
Naenyn
Post by Naenyn » Fri Mar 27, 2020 12:33 am
I’d be surprised if any of the components were damaged .. unless you recall leaving your iron on any spot particularly long. The instructions do warn against that, as I recall. Only things I can think of are to go over that back board with a magnifying glass and look for shorts.. and if you don’t find any, maybe try contacting Thonk? I think they offer troubleshooting help, but not positive. Not sure how to reach prOk...
Good luck!
-n :ninja:
Naenyn
Post by Naenyn » Fri Mar 27, 2020 12:37 am
I don’t recall seeing a way to reflash the teensy to a different instrument in the software. I believe it was limited to live patch tweaking and saving/loading presets. Will double-check this weekend...
On a side note... I really hope prOk comes up with a better way to load from the sdcard. Not a fan of the “hold down a button at power-up” method.
-n :ninja:
bemushroomed
Post by bemushroomed » Fri Mar 27, 2020 12:48 am
both of those are supposed to be fixed in the upcoming(?) FW.. the "hold down button" thing is especially bad i think, if you have several in various places of the rack it's not exactly optimal either...
BartBral
Post by BartBral » Mon Mar 30, 2020 5:23 pm
I guess we have to pray to gods of Thonk?
orbita
Post by orbita » Tue Mar 31, 2020 1:10 pm
Are the prok modules identical in hardware? Can you flash the BD as a SN for example?
If only one was available to buy can you just change it into one of the others?
a773
Post by a773 » Tue Mar 31, 2020 2:03 pm
No because it's closed software...
bemushroomed
Post by bemushroomed » Tue Mar 31, 2020 2:19 pm
Again, read the thread (like 1 page back), they claim it's coming.
arechfer
Post by arechfer » Wed Apr 01, 2020 4:15 am
WHEN WILL BE OUT??
WILL BE GREAT FOR ISOLATION
STAY SAFE
Monobass
thonk.co.uk
Post by Monobass » Wed Apr 01, 2020 6:28 am
You will be able to soon.
This year hasn't really gone to plan... :eek:
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
Monobass
thonk.co.uk
Post by Monobass » Wed Apr 01, 2020 6:30 am
yep, it's coming too.
At least fully closing Thonk for Coronavirus is opening up time soon for this...
