Qu-Bit Bloom
versipellis
Post by versipellis » Fri Nov 08, 2019 1:49 am
The manual isn't clear, but it seems that the root note offset input is -1V to 5V. If I wanted to use a root note sequenced by another sequencer, would I turn the pot all the way to the left or keep it at 12 o'clock (such that the pot is generating 0V)?
versipellis
Post by versipellis » Tue Nov 12, 2019 5:17 am
Manual page 16:
To loop the page that is being edited press channel.
While looping a page within Tune Modes the Channel LED will pulse between the channels’
color and white.
What does looping a page mean?
Additionally, how is the Notes mode where you hold shift and click the notes encoder, any different from the default mode where you just rotate the encoders to set the trunk notes?
Fog Door
Post by Fog Door » Tue Nov 12, 2019 1:33 pm
Overjoyed to see this now available in silver panel :party:
versipellis
Post by versipellis » Sun Dec 08, 2019 6:44 am
I don't seem to recall this happening before, but entering the per-note editor for any of the functions (e.g. Slew, note time) appear to stop the sequencer. Does that happen for anyone else?
mattcolville
Re: rests?
Post by mattcolville » Sun Dec 08, 2019 5:29 pm
muddy ranks wrote:Looking into Bloom. Is there a way to introduce more rests into the sequences Bloom generates?
I've seen demos that show channels with different rests, but based on reading the manual it's unclear how you do this. Ratchets to zero maybe? Given how it does 'ratchets' that might work.
Nutritional Zero
Post by Nutritional Zero » Mon Dec 09, 2019 8:19 am
It’s actually not in the manual—which I find unfathomable—but you simply click an encoder to enable/disable a gate on that step of the pattern. The step’s LED is lit when a gate is present on that step. In this way you could, say, program a sequence that has a single note on beat one and that’s it. This is much easier to do with the clock stopped.
Of course, any mutation you apply may then do something inscrutable to your sequence so I’d say Bloom is not the sequencer if you want precision sequences. But you probably know this!
I have a show in the not-too-distant future and it’s getting to be sink or swim time for Bloom. Every time I sit with this thing I end up wrestling with it on some level and I’m sorry to say the documentation from Qu-Bit is simply not good enough.
Whether it’s the module or me, the results so far are always less musical than Marbles or René, which use less inscrutable paradigms and interfaces for “aleatoric composition.”
I’ll give it another couple of weeks. My review so far is undecided.
versipellis
Post by versipellis » Fri Dec 13, 2019 2:55 pm
Nutritional Zero wrote:It’s actually not in the manual—which I find unfathomable—but you simply click an encoder to enable/disable a gate on that step of the pattern. The step’s LED is lit when a gate is present on that step. In this way you could, say, program a sequence that has a single note on beat one and that’s it. This is much easier to do with the clock stopped.
The how to video that they just posted on YouTube yesterday is a lot better than the manual.
versipellis
Post by versipellis » Fri Dec 13, 2019 2:57 pm
versipellis wrote:I don't seem to recall this happening before, but entering the per-note editor for any of the functions (e.g. Slew, note time) appear to stop the sequencer. Does that happen for anyone else?
So er, Qubit, is there any way to (by firmware or something) keep the sequencer running when you're in a shift-editor mode? It's kinda silly that I can't change the slew on one step without stopping the whole sequence on both channels, and instead have to change the slew on everything. The current way its set up doesn't lend itself to live performance, and I've wrestled with it for 2 gigs already. This is the only thing that's holding me back now.
subLimb
Post by subLimb » Fri Dec 13, 2019 5:55 pm
I have this question as well...you can loop the current page when you're in per-step mode (press channel), but you can't have the entire sequence play while in that mode - it just pauses the sequence. Doesn't seem ideal.
versipellis
Post by versipellis » Sat Dec 14, 2019 4:59 am
It also stops the moment you enter that page. And no matter how fast you hit the channel button to loop the page, you'll be off sync. I'll even settle for it auto looping the page when you enter it..
Jericho
Post by Jericho » Tue Dec 17, 2019 12:36 pm
Does Bloom need a steady clock or does the seqence progress with each trigger?
Scott
Post by Scott » Tue Dec 17, 2019 1:25 pm
I don't know if this is the correct answer, but yes that's happened to me and I tried pushing the encoder a second time and it "corrected" the issue.
Scott
more Bloom questions
Post by Scott » Tue Dec 17, 2019 1:37 pm
As has already been stated, the manual isn't clear on some things. While I await answers to questions from Bloom tech support, I thought I would ask these of the brain trust here at Muffwiggler.
I'm reading through the manual again and under slew (page 16) the terms "Tune Modes" is used for the first time. I can't find any other reference to it prior to Page 16. What is Tune Modes? Does it refer to any operation that involves Shift and an Encoder? It's mentioned obliquely several times after Page 16.
Also, the global settings mode in which you may change the settings. Not that I want to but for future reference, if one turns the knob associated with the parameter to be adjusted CCW, it will decrease the effect? CW would increase the parameter? Any clarification on this will be greatly appreciated.
And someone here said that Qu-Bit posted a how to video. I've been on the website and haven't found it. There are four videos produced by different reviewers which are relatively simplistic in nature. Where's the how to?
Many thanks.
Destinova
Post by Destinova » Wed Dec 18, 2019 4:39 pm
Jericho wrote:Does Bloom need a steady clock or does the seqence progress with each trigger?
The sequence progresses with each trigger.
Nutritional Zero
Post by Nutritional Zero » Wed Dec 18, 2019 5:01 pm
Root CV input is “1V to +5V added to pot position.” So, with no CV at the input, what is the knob position that represents 0V?
versipellis
Post by versipellis » Wed Dec 18, 2019 7:22 pm
Nutritional Zero wrote:Root CV input is “1V to +5V added to pot position.” So, with no CV at the input, what is the knob position that represents 0V?
From what I can tell, all the way counter clockwise.
gonkulator
Post by gonkulator » Wed Dec 18, 2019 7:32 pm
Racks
Solaris Site
Stuff for sale
Stuff for sale shown on Modulargrid
WTB: Black panels
Unflappably nonchalant, with some exceptions
versipellis
Re: Qu-Bit Bloom
Post by versipellis » Thu Dec 26, 2019 3:41 am
Anyone have tips on having mutate or branches generate more usable and "musical" melodies? Seem to be struggling with mine - sometimes my initial 4-note steps will generate a nice melody, but other times it comes out crap :|
hugo
Re: Qu-Bit Bloom
Post by hugo » Thu Dec 26, 2019 3:01 pm
@versipellis: it may not be very clear from the manual but making any change to the original trunk re-creates all its branches.
So, a good tip to generate more musical melodies is to... try again and turn any knob until something works (turing machine like, basically).
Also, did you make sure you selected a scale? Oh, and make sure you first lock the melody (shift + pattern for ~2 seconds) you created!
A first patch that I liked with the Bloom is to use the second channel as a modifier for the first one.
Basically, you set it to a low clock division and feed the root input with it. Then you slowly evolve its mutations. Pretty cool!
If you guys need more opinions: I struggled with the Bloom for approximately 2 days before really digging it. I think it comes from the fact that it's at the crossroad of several ways to create melodies. I was first puzzled by the fact that setting mutation > 0 not only creates melodies but *writes* your current trunk. I thought it was a bug at first, because the module invites you to actually write your sequences. But the more I use it, the more I like it.
The only thing I don't get about the module is why the rate input can't be used while using an external clock, when it could be used as a divider/multiplier. I sent an email to Qu-bit so maybe they will consider it 👍
SnipeCatcher
Re: Qu-Bit Bloom
Post by SnipeCatcher » Thu Dec 26, 2019 9:17 pm
Got a Bloom about a month ago. Had to return it because of a small issue and finally got the replacement today. Really struggling with the manual, though I’m able to do fun jams very quickly, I just haven’t wrapped my head around this thing at all! Hopefully, I’ll keep learning a little every time, but it sure seems like a lot of button combos to memorize...you know, the exact opposite kinda thing that made me want to get into eurorack in the first place :)
mattcolville
Re: Qu-Bit Bloom
Post by mattcolville » Fri Dec 27, 2019 7:58 pm
Edit: I retract my question, I figured out what I was doing wrong.
mutate
Re: Qu-Bit Bloom
Post by mutate » Tue Dec 31, 2019 10:12 pm
hold down shift and turn the div/mult knob.
The biggest issue I'm having is the reset input is not working. I hope they update the firmware to fix this. This could be a deal breaker for me.
“Perfection is achieved, not when there is nothing left to add, but when there is nothing left to remove.”
Antoine de Saint-Exupéry
mutate
Re: Qu-Bit Bloom
Post by mutate » Tue Dec 31, 2019 10:21 pm
Seems like the div/mult knob is messing this up. Plus resetting on the next pulse puts it a step behind. Ugh. wish I could change this to reset on first pulse like all of my other sequencers.
versipellis
Re: Qu-Bit Bloom
Post by versipellis » Wed Jan 01, 2020 5:11 am
Can confirm reset is triggering late. Have tried with a number of sources. First time I noticed was with the reset output of the intellijel 1uMIDI, which has never given me issues before.
dumbledog
Re: Qu-Bit Bloom
Post by dumbledog » Wed Jan 01, 2020 3:08 pm
Is there a way to tamp down on the sequence's range when traveling down branches? Sometimes it octaves the same note multiple times and gets really jarring, especially with bass.
