Westlicht PER|FORMER Sequencer (DIY)
vssp
Post by vssp » Sat Aug 24, 2019 3:44 am
sduck wrote:Do you have it in the right way? Label facing up?
Thanks for the help, but yes, there's a sort of security lock on the card slot so that you can't put the SD card "face down"... so mine is face up, as it has to be, and it's still unrecognized by the module.
Maybe I should buy another micro SD card and return back my current one...
Other ideas welcome!
forestcaver
Post by forestcaver » Sat Aug 24, 2019 3:50 am
Take a close look at your soldering of the sd card holder. The soldering is pretty fine pitch and it would be easy to create a bridge.
vssp
Post by vssp » Sat Aug 24, 2019 3:57 am
forestcaver wrote:Take a close look at your soldering of the sd card holder. The soldering is pretty fine pitch and it would be easy to create a bridge.
Ok thanks, so I'll have to check that with the builder…
forestcaver
Post by forestcaver » Sat Aug 24, 2019 4:56 am
Didnt you build it yourself ? (The licence doesnt allow for commercial sales/builds.....)
vssp
Post by vssp » Sat Aug 24, 2019 6:05 am
The builder is one of my friends, there's no commercial aspect about it (or even some beers!), no worries about that.
And to close this issue, it was a faulty micro SD card, the Samsung micro SD HC 32Go I've just bought is working fine!
Thanks for the helps, and as far as I've get into it, this sequencer is a beast!
forestcaver
Post by forestcaver » Sat Aug 24, 2019 9:27 am
vssp wrote:The builder is one of my friends, there's no commercial aspect about it (or even some beers!), no worries about that.
Good news!
iheartmodular
Post by iheartmodular » Sat Aug 24, 2019 9:41 am
commercialisation is different from building a few and selling them so even if your friend did make a beer or three its okay
"If you want to build and sell more than a handful of modules, please contact me first."
https://westlicht.github.io/performer/license/
(PLEASE NOTE - I AM JOKING, REPEAT, JOKING) :hihi:
vssp
Post by vssp » Sat Aug 24, 2019 1:05 pm
Hi guys, first try with it this afternoon and it's awesome, though I'm just scratching the surface… midi keyboard to the midi input, hardware synth on the midi output, midi recording, divisions per tracks, probability, etc, it's all I wanted. :banana:
Dogma
Post by Dogma » Sat Aug 24, 2019 2:46 pm
Are there any demos of the newest firmware or close to?
look up!
selfdestroyer
Post by selfdestroyer » Sun Aug 25, 2019 6:23 pm
Anyone know if there is a way to record/overdub off of the set grid?
I have been messing with it most of this weekend and I think thats the last feature I have been trying to get working to fit my workflow.
I am comparing this to my MPC 2000 where i usually turn off the grid/quantization for my kick drum and/or hihats or to add life to a synth bass line without constraints of time quantizing.
My DIY / Music Blog They Remain Silent
Ebotronix
Post by Ebotronix » Mon Aug 26, 2019 11:03 am
is it possible to use the cv ins for quantizer function with microtonal scales?
I like to connect one or two Doepfer A 198 Ribbon controllers.
mongrol
Post by mongrol » Mon Aug 26, 2019 10:02 pm
Ebotronix wrote:is it possible to use the cv ins for quantizer function with microtonal scales?
Can confirm CV in's from a keystep are quantised to the set scale and since you can define your own scales (in terms of voltage)....
iheartmodular
Post by iheartmodular » Tue Aug 27, 2019 1:14 pm
selfdestroyer
not something i do
so not sure
but simon added gate offset to note sequences, allowing to delay gates in v0.1.17 so there may be some hope
steviet
Post by steviet » Mon Sep 23, 2019 3:20 pm
I really love this module. I posted a build diary on my blog chronicling the build.
Hopefully it is of use to someone, or at least mildly amusing.
Soundcloud
Website - DIY/Euro/Gear Blog updated every Sunday
gpbelcher
Post by gpbelcher » Fri Oct 11, 2019 3:42 pm
I have a couple of strange things happening with my Per|former - wondering if anyone else has to troubleshoot similar issues?
On the Monitor page CV Input 2 constantly shows a voltage of +5
Also MIDI in was working until I put the panel on and now it seems unresponsive. No notes, clock, or info on the Monitor page when sending MIDI. I've tried different MIDI dongles, cables, etc. Very strange.
Any help and info is greatly appreciated - thank you!
16osc
Post by 16osc » Sun Oct 13, 2019 8:11 pm
I've made some unofficial modifications to the firmware that may be of interest:
tempo mode : pattern plus encoder adjusts swing (submitted to the firmware maintainer as I think this is helpful for all?).
random generator: random button which quickly changes the seed on each press but keeps your other settings
Beat Generator (called QuickRandom for now) that has buttons for :
- sparse, medium or nearly full gate patterns
ideal for hitting over and over to get something you like.
- "Beats" key which cycles through common rhythm motif's
- "Notes" key which generate random notes (no smarts to it yet) but keeps the notes in an approx. 3 octave span.
Open to your input and suggestions.
After I learn the code organization more I want to create a generator that randomizes notes and gates at the same time (or generators that in general take the contents of other tracks into consideration when generating their output).
Would also like to build a mini-grids that puts common beat patterns on multiple tracks with a single interface.
https://github.com/jstefani/performer/t ... l_features
The code and built setup are really easy to get started with btw if you have thought about working on it. i can share my pre-built firmware if needed.
mongrol
Post by mongrol » Sun Oct 13, 2019 10:16 pm
Nice work.
Southfork
Post by Southfork » Mon Oct 14, 2019 3:09 am
16osc wrote:I've made some unofficial modifications to the firmware that may be of interest:
Looks great!
bscooper
Which MIDI Adapter cable works?
Post by bscooper » Tue Nov 05, 2019 6:46 am
I tried to use my Keystep over Midi with the Westlicht Performer and the MIDI to jack adapter but not reaction. Which MIDI to Jack adapter works for that? Are there any differences?
Southfork
Post by Southfork » Tue Nov 05, 2019 10:02 am
Im having issues compiling this, do you have a compiled hex?
Z_U_L_U
Per|former Song Mode
Post by Z_U_L_U » Sun Nov 10, 2019 5:33 am
Can anyone help and tell me how to get the song mode to start from the sequencer of the Octatrack, I.E, send start/stop msg from OT and song mode starts on Performer, as opposed to song mode just starts and doesnt care.
Manual does not state how to do this. Only how to run songs from within the sequencer itself.
Many thanks
sutekina bipu-on
Post by sutekina bipu-on » Sun Nov 10, 2019 7:30 pm
I want to revise the pcb to fit cherry mx switches :hmm:
SkoPe
Post by SkoPe » Mon Nov 11, 2019 5:56 am
Would love to try this, can you share a pre-compiled hex? Thanks
MikeLeeBirds
Post by MikeLeeBirds » Tue Nov 12, 2019 5:32 am
The feature list states „Sequence generators“, but I cannot find anything further in the manual.
Can anyone point me to more information about that?
16osc
Post by 16osc » Thu Nov 14, 2019 8:47 pm
no docs on them but see my screen shots above for a general idea. screen shot #2 (minus the rightmost "random") is the random generator.
in the online demo :
https://westlicht.github.io/performer/testdrive/
press
alt + s1
then
shift + alt
you'll see the screen show "gen" in the right-most "tab", press the key below and you'll get the generators.
