The Hex file is in github to try it out!!
Isn't anyone experiencing the same thing on v1.1 beta ??nothing happens when I tweak the fader on ch1
Version 1.2 has been released Today! so you need to update the firmware first, as the editor only works with version 1.2
Thank you for your reply. Certainly the saved value is also visible, but it does not seem to work as it should. For example, the display shows that the assigned MIDI channels are sounding on the same MIDI channel.Paranormal Patroler wrote: ↑Thu Sep 03, 2020 9:17 amI just edited my settings, saved them to User1, and turned the case off and on again. Settings are there. Are you sure you saved? Sorry, that might sound stupid, but sometimes I forgot to save my configuration, so I have to ask.
Sinamsis wrote: ↑Sun Sep 06, 2020 12:58 pmI updated with relative ease, and got the editor working no problem. I do, however, have an issue with the poly v/oct setting, and I suspect I'm doing something wrong. The way I read the manual, a gate into the 8th block's gate input will trigger a note to be sent from all channels set to v/oct. I assumed that a note on message would also be sent, but perhaps this is not a correct assumption. Anyways, using stackable across all of these gate inputs works, but I was hoping to set up something that doesn't need this. Certainly not a deal break, but it would be nice to sequence chords progressions this way (I'm using a Sinfonion to generate the chords).
I don’t know I played with it a bit and using only the 8th input, I was only getting one note. If I wanted a chord I had to mult the gate to all the other inputs. All channels were set to poly v/oct. Did I miss something? I’ll play with it some more tomorrow.Paranormal Patroler wrote: ↑Sun Sep 06, 2020 3:22 pmSinamsis wrote: ↑Sun Sep 06, 2020 12:58 pmI updated with relative ease, and got the editor working no problem. I do, however, have an issue with the poly v/oct setting, and I suspect I'm doing something wrong. The way I read the manual, a gate into the 8th block's gate input will trigger a note to be sent from all channels set to v/oct. I assumed that a note on message would also be sent, but perhaps this is not a correct assumption. Anyways, using stackable across all of these gate inputs works, but I was hoping to set up something that doesn't need this. Certainly not a deal break, but it would be nice to sequence chords progressions this way (I'm using a Sinfonion to generate the chords).
No, a single gate at the 8th input will fire all the tracks set at Poly mode. So you only need one single gate to be fired, and all poly tracks will play at the same time.
If I understand your post correctly you've set it up wrong, but it can do what you're asking for.
If you set CV to Note it will send a Note on with a fixed length. After this fixed time it will automatically send a note off. Check v1.2 manual page 5.Bonati wrote: ↑Fri Sep 04, 2020 12:59 pm
The Harmonaig -> VCMC combo was just an idea to be able to trigger & play around with some chords. Not having much luck with this. I would test the VCMC->Synth connection by setting the CV mode to "V/oct to note" and using the the VCMC buttons to confirm a note is playing. Got that to work. Would then patch the 4 quantized outputs on the Harmonaig to CV inputs 1-4 on the VCMC and set the CV mode to "note". I have no experience setting proper midi ranges so I would experiment until I got the notes in the register I wanted (quick & dirty test). Even then all four notes sounded a bit out of tune. In addition, there was always some intermittent triggering of notes from Harmonaig (I assume). I could never get that to stop.
This seems like the right answer for SinamsisParanormal Patroler wrote: ↑Sun Sep 06, 2020 3:22 pm
Ok, this is new in firmware 1.2 and was waiting for someone to point it out!trigger303 wrote: ↑Sun Sep 06, 2020 8:17 pmUpdated to v1.2.
Overall it's working correctly, but the fader value response seems laggy.
I don't think it happened in older versions.
Befacosynth wrote: ↑Mon Sep 07, 2020 3:34 amOk, this is new in firmware 1.2 and was waiting for someone to point it out!trigger303 wrote: ↑Sun Sep 06, 2020 8:17 pmUpdated to v1.2.
Fader readings have been smoothed to increase stability and minimize fader values jumping from one to another when set to the limit of the value. Unfortunately this smoothness will lead to laggyness.
We have implemented a filter setup in factory calibration. By default filter is set to 90, while maybe a better setup would be around 60.
To enter this calibration go to global settings > Credits then hold encoder button for a couple of seconds. when you are returned to global menu, factory cal should appear in the menu.
I will edit readme.md in github to add this info.
Do a Factory reset, configuire one channel and save to one of the memories.revoltcrews wrote: ↑Tue Sep 22, 2020 9:24 amMorning, I updated to the latest firmware. couple quick things:
-getting serious ghost trigs: with each channel's block fully programmed and set to its own output from 1-8, and having only channels 1 & 2 with gate/cv patched, practically every other channel is ghost triggering.
-perhaps this is a bug, or not: my channels only function if both Gate & CV are patched.
I noticed, if I only patch a Gate in to each channel, even with the midi channels set from 1-8, they only trigger Channel 1, until I patch a CV in, then they output to each channel properly.
I'd love to be able to simply patch a Gate in and have the channel function., maybe I don't want CV for that patch. Is there a setting I'm missing?
also, do I have to recalibrate after every firmware update?
thanks
