Xaoc Devices Sarajewo: Syncable Analog Delay Line SHIPPING NOW!
Re: Xaoc Devices Sarajewo: Syncable Analog Delay Line SHIPPING NOW!
I think you have to watch the out of range led or things get messy.
- Wiggling with Experience
I get some background noise if I have the input gain too high. I find it best to have it around 3/4 full, and then I get a really low noise floor for a BBD delay. With euro modules it's always good to try a different psu if you're having some problems, the cheap psu's can be quite problematic at times. A module can work really nice with one PSU, and have really nasty artefacts with another.
Please, let's not pollute this discussion about the beautiful Sarajewo with endless noise floor discussions... if you want that sort of thing you'll find it over in the Mimeophon thread
- Learning to Wiggle
Just ordered mine. Now the long weekend wait.
First Eurorack effect for me....
- black_label
- Common Wiggler
I don’t get any noise coming from mine but unity gain seems to be with the input cranked all the way up.ookrsia wrote: ↑Wed Dec 02, 2020 9:49 amI get some background noise if I have the input gain too high. I find it best to have it around 3/4 full, and then I get a really low noise floor for a BBD delay. With euro modules it's always good to try a different psu if you're having some problems, the cheap psu's can be quite problematic at times. A module can work really nice with one PSU, and have really nasty artefacts with another.
FWIW I was getting a randomized whine sound dancing around 3kHz when I had the Sarajewo in my MakeNoise case (similar to the Metropolis noise I'm familiar with). I just put it in my L1 linear case and it is amazingly clean even at super long delay times—and with the input gain all the way up, with a hot signal.black_label wrote: ↑Thu Dec 03, 2020 1:10 amI don’t get any noise coming from mine but unity gain seems to be with the input cranked all the way up.ookrsia wrote: ↑Wed Dec 02, 2020 9:49 amI get some background noise if I have the input gain too high. I find it best to have it around 3/4 full, and then I get a really low noise floor for a BBD delay. With euro modules it's always good to try a different psu if you're having some problems, the cheap psu's can be quite problematic at times. A module can work really nice with one PSU, and have really nasty artefacts with another.
Also confirming that the input at 10 seems to be unity.
Sounds so good!
- Common Wiggler
that's bizarre, i seem to have best results around noon. From noon to 3/4 it starts colouring more, past 3/4 it will seriously overdrive
It does sound great! very coloured but so musical and lush. My favourite thing has been using a planar joystick to affect both the source material and the delay time when synced, such glitchy lushness!
Going to try and cacade it into mimeophon now, i think the freeze function could be magical for capturing those mid-glitch beauties
- Electro Something
- Common Wiggler
Looooving my Sarajewo. So warm and clean and lush. Sounds even better than the BBD in my Matriarch. Gives me that "80s sound" I always crave.
What other creative ways have you been patching the three taps and external feedback? I've tried panning the taps left and right and patching them into the Mimephon, for some amazing results.
- Electro Something
- Common Wiggler
How of you been patching it with the Katowice?natureclubcassettes wrote: ↑Thu Nov 26, 2020 12:17 pm
Goes even better next to the Katowice!! Amazing combo.
Not who you asked, but right now I'm patching some drums into the Sarajewo and then taking each tap out into their own channel of the Instruo Tanh for feedback limiting and then into a mixer with some pan automation, I then run this mix into the Katowice and play with the various bands in the Katowice from there.
- Electro Something
- Common Wiggler
Oh very cool I haven’t tired patching drums in yet.NoLegs wrote: ↑Sun Dec 13, 2020 8:01 pmNot who you asked, but right now I'm patching some drums into the Sarajewo and then taking each tap out into their own channel of the Instruo Tanh for feedback limiting and then into a mixer with some pan automation, I then run this mix into the Katowice and play with the various bands in the Katowice from there.
I don't have the Katowice, but have the LR4 which is sorta a mono version - I love patching a single BIA through LR4... with 1 or 2 of the 3 LR4 outs going to Sarawejo (and 1 or 2 of the outs going elsewhere). I've repeated this patch several times (except with Mimeophon instead of Sarajewo) and it's a lot of fun and pretty crazy how full you can get a single BIA (or drum track) to sound.
I have two of these and I love them. I've paired each with a little Malekko mixer to control the feedback on each tap and do some ping-pong style stereo cross patching. Using all three taps turns this into something between a reverb and a delay. It can be super lush. Also pairs well with a couple of heavily attenuated LFOs to make the delay drift ever-so-slightly.
This is by far the best analog delay module I own, for delay purposes. (Other modules like the A-188 are great as skrokulators, not so much as standard delays.) The tap tempo input is a killer feature. I don't know of any other analog delay module that has a tap tempo input.
Gripes:
Activating the alternate time modulation mode, where the CV is added to the tap tempo without jumping to quantized values, requires powering up the module while holding the tap tempo button every time. It'd be nice if this mode was remembered between power cycles.
It would be great if the tone control had a CV input as well.
Gripes:
Curious how this sounds?NoLegs wrote: ↑Sun Dec 13, 2020 8:01 pmNot who you asked, but right now I'm patching some drums into the Sarajewo and then taking each tap out into their own channel of the Instruo Tanh for feedback limiting and then into a mixer with some pan automation, I then run this mix into the Katowice and play with the various bands in the Katowice from there.
- mysteryredinferno
I ordered a Sarajewo in November. Had the unit for a few days and the delay section stopped working: still passed and attenuated audio and the rate LED was still working, but nothing but silence from the delay outputs. The shop where I bought it replaced it and it worked great for a month. Turned the case on today and now I'm having the same problem with the new unit.
Anyone else had issues like this? Could it be a PSU compatibility issue? I have a Trogo 420 (30a) case.
What say ye, people?
Oh no. Don’t tell me that. I’ve had enough bad luck with a 1010 Bitbox micro recently. So far I haven’t had any power issues. I’ve had it in an Intellijel 7u and and Intellijel palette.
FS/T: Goike 12u/104hp Bamboo/Aluminum Folding Case
I had/have the exact same issue. I put it in a different case and it still wasn’t working properly. Then the next day a put it back in the original case and made sure all my connections were good and haven’t had any issues for a couple of weeks. Sorry I couldn’t be more helpful.
- mysteryredinferno
No worries, thanks for your response! Glad to hear you got your unit working again. I'm not sure what the issue with mine is. I'm really hoping I can get this to work for me because I love analog BBD's and the Sarajewo sounds incredible. Someone from Xaoc reached out and we're discussing now.
Just reading about this issue. I rearranged my case a couple of weeks ago, and after power up, everything but Sarajewo was working. It lit up as though it was working, but didn't pass any audio. I checked everything on that power supply, and all the connections looked good. I pulled everything out, and put everything back pretty much the way it was, and Sarajewo worked just fine. No issues since, and I have no explanation why it did what it did.mysteryredinferno wrote: ↑Mon Dec 28, 2020 1:54 pmNo worries, thanks for your response! Glad to hear you got your unit working again. I'm not sure what the issue with mine is. I'm really hoping I can get this to work for me because I love analog BBD's and the Sarajewo sounds incredible. Someone from Xaoc reached out and we're discussing now.
If you find an answer to this problem, please post it. Maybe Sarajewo is just really finicky about power?
- Veteran Wiggler
Just wanted to add that I've had mine in both my cases (Doepfer low cost 6U 84 hp and Monorocket base 6U 104 hp) with zeros issues thus far. I hope everyone else's power issues are resolved quickly, though! Would be a shame to not be able to use this awesome module.
Got mine as soon as released, use every day, zero issues.
Still in total love with it. Here's a piece showcasing it. Just Rene into STO into Math's (using Ch1 & 4 as frequency dividers) into Sarajewo with its T1 and T3 panned wide and T2 down the middle. No filters or effects - just added some limiting in DAW.
- Back Down the Path
- Common Wiggler
I need a Euro delay (all I have is a Prism!).
Anyone with experience with this vs. a Mimeophon?
I understand Mimeophon is more than just a delay (which is good!) and I already have a Morpagene to sit next to it, but something about the demos of this is calling my name from the "pretty sounds that make you zone out and drool" department.
I sold my Mimeophon and got the Sarajewo. On paper, there are some similar features, but they are really different modules. For my use of Mimeophon, I just couldn't decide what it was supposed to be. It has reverb, but you don't have too much control over it. It does freezy and smeary sounds, but other modules do that much better (Arbhar, Nebulae, Morphagene). It's a very interesting tempo synced delay, but I didn't like the darkish sonic character. There's also the noise issue, and that bugged me when I tried to use it seriously.Back Down the Path wrote: ↑Mon Jan 11, 2021 3:09 pmI need a Euro delay (all I have is a Prism!).
Sarajewo is much more straight forward. It's a gorgeous, really thoughtfully engineered BBD delay with tempo sync and a feedback loop. If you're into the general BBD delay sound, then this module will likely blow your mind.
