Joranalogue GENERATE 3 - Through-Zero Multiphonic Signal Generator
Moderators: lisa, Kent, Joe.
maltemark
Post by maltemark » Mon May 20, 2019 9:42 am
On most other PM/FM oscillators, an output conditioned into a sinewave usually exists... do I undertand it correctly that's not the case on this monstrosity of insanely powerful super-oscillator? It sounds and looks like a very nice oscillator for massaging waves as you see fit, overall
joranalogue
Post by joranalogue » Mon May 20, 2019 10:52 am
peripatitis wrote:I'd be curious to see whether by modulating at slower rates the three "stems" you get an evolving sound or 3 different sounds.
That depends on your perspective and how much the timbral channels are 'blended' together using modulation, ie. you could simply switch between them for different notes in a sequence or slowly sweep through them using a multi-phase LFO such as Filter 8.
maltemark wrote:On most other PM/FM oscillators, an output conditioned into a sinewave usually exists... do I undertand it correctly that's not the case on this monstrosity of insanely powerful super-oscillator? It sounds and looks like a very nice oscillator for massaging waves as you see fit, overall
Yes there is, the fundamental output is a sine wave. (Definitely watch the videos!)
Joranalogue Audio Design
21st Century Analogue Synthesis—Made in Belgium
https://joranalogue.com/
Dragonaut
Post by Dragonaut » Mon May 20, 2019 3:59 pm
Once the bugs are smoothed out on this thing it’s gonna be a beast. Already sounds good except for a few rough spots.
https://soundcloud.com/acaciabridge (IDM, Ambient, Bass, Downtempo)
www.instagram.com/dr_science_phd (synths, hikes, and views.)
cackland
Post by cackland » Mon May 20, 2019 5:20 pm
Dragonaut wrote:Once the bugs are smoothed out on this thing it’s gonna be a beast. Already sounds good except for a few rough spots.
Which spots?
Dragonaut
Post by Dragonaut » Mon May 20, 2019 8:48 pm
Watch the sonic state video? There’s a fair amount of noise as he wiggles the knobs that I’m pretty sure isn’t how the final product is imagined to sound.
Dragonaut
Post by Dragonaut » Mon May 20, 2019 9:11 pm
joranalogue wrote:
Of course there will be some small improvements, mostly in the phase modulator which in these prototypes still has some audible glitches/'clicks' in certain settings.
oudplayer
Post by oudplayer » Mon May 20, 2019 9:25 pm
Dragonaut wrote:
From the demo I got from Joran at SB and in the demo Joran did in the cinema space, it was only in the phase modulator knob that there were any clicks (and not always). No probs with the exp. FM and thru-zero FM, and the various outputs of the osc. We modulated everything with everything and it sounded amazing-- really amazing.
cackland
Post by cackland » Mon May 20, 2019 10:14 pm
Dragonaut wrote:
:tu:
fjoesz
Post by fjoesz » Thu Aug 08, 2019 3:23 pm
I WANT ONE...
no...
I NEED ONE VERY SOON
joranalogue
Post by joranalogue » Thu Aug 08, 2019 4:59 pm
fjoesz wrote:I WANT ONE...
no...
Too bad it's going to take a bit more time than anticipated. Simply put, demand for my modules has increased to the point where production is taking up the majority of my time. And getting a design from 99 to 100 % always takes longer than you expect...
I'm putting everything in place to release the module in November latest. I know this is still a long way off, but you'd be amazed how long in advance you need to plan production for a design like this (especially if you want to do everything the right way).
It's definitely on its way though, no vapourware here if I can help it...
cg_funk
Post by cg_funk » Thu Aug 08, 2019 5:35 pm
joranalogue wrote: I'm putting everything in place to release the module in November latest.
Joran, your modules are a work of art and totally worth the wait. Thanks for the update! It's gonna be a fun winter once this arrives :-)
Modulargrid: https://www.modulargrid.net/e/racks/view/1069607
The last session I recorded in the USA before relocating to Denmark:
https://soundcloud.com/mod_gene/zone-overture
cackland
Post by cackland » Thu Aug 08, 2019 5:51 pm
Joran, are you still a one man band or have you got some help?
If not, I’ll book the next flight over
joranalogue
Post by joranalogue » Thu Aug 08, 2019 6:01 pm
cackland wrote:Joran, are you still a one man band or have you got some help?
Luckily, I started working with a local assembly house from the start. Much better to gradually get all production processes on point, than doing everything yourself and then scrambling to go factory-built once it becomes absolutely necessary. Testing and packing is still on me though, as that's the final QA stage. Add component sourcing, general administrative stuff, the occasional modular event and you've got well over a fulltime job.
You're welcome to book that flight though, could use someone to sweep the lab floor. :hihi:
cackland
Post by cackland » Thu Aug 08, 2019 6:25 pm
Done, hopefully I'll quickly move up the ranks to coffee boy!!
joranalogue
Post by joranalogue » Thu Sep 12, 2019 9:49 am
Using a VCO to create white noise? No problem with Generate 3 and some feedback patching!
While G3 is primarily designed to create clean and reliable waveforms, you can push the circuit beyond its limits using feedback patching. In this patch, the even output signal is used to modulate the phase parameter. At maximum frequency, the result is a pristine white noise signal from the fundamental output. Adjusting the frequency allows the noise to be 'tuned'.
luchog
Crazy Pony
Post by luchog » Thu Sep 12, 2019 3:52 pm
That sounds really amazing. Been looking at demos of some of the other modules as well. Can see a what appears to be a strong Serge inspiration in some of them, taken in really interesting directions. If I was going to consider building a single-manufacturer eurorack rig, Joranalogue would definitely be the top contender. Won't happen, tho, can't give up my Metasonix. :hihi:
joranalogue
Post by joranalogue » Tue Oct 22, 2019 7:20 am
Today's listening material: a soothing piece of modular music by Nordlys, created using his Generate 3 prototype.
Dragonaut
Post by Dragonaut » Tue Oct 22, 2019 8:13 am
Has a price range been discussed yet? I’d love to set this little beastie next to another certain large thu-zero oscillator of mine and just never leave the house again.
joranalogue
Post by joranalogue » Tue Oct 22, 2019 8:23 am
Dragonaut wrote:Has a price range been discussed yet? I’d love to set this little beastie next to another certain large thu-zero oscillator of mine and just never leave the house again.
It'll be around the €350/$350 mark.
Dragonaut
Post by Dragonaut » Tue Oct 22, 2019 8:43 am
Not bad at all!
SavageMessiah
Post by SavageMessiah » Sun Oct 27, 2019 12:42 pm
Is it still looking like November for the release?
joranalogue
Post by joranalogue » Mon Oct 28, 2019 3:19 am
SavageMessiah wrote:Is it still looking like November for the release?
Yep, in about 4 weeks.
Soall
Post by Soall » Fri Nov 08, 2019 4:41 am
Great Design :deadbanana:
Reminds me a lot of schippmann omega-phi
Only doubt I have is wether I should go for 3 or 4 of this beasts :sb:
joranalogue
Post by joranalogue » Tue Nov 26, 2019 3:23 pm
Although there's been a slight delay in production, Generate 3 is now wel underway and pre-orders are opening at dealers as we speak! Reserve yours now and you can expect to have it in your hands in about 2 weeks: https://joranalogue.com/dealers
In addition, the product page has been updated with the user manual and many new demo sounds. Enjoy! :goo: https://joranalogue.com/generate-3
Precarious
Post by Precarious » Tue Nov 26, 2019 3:31 pm
Woo-hoo! Not showing anywhere yet but I will keep an eye out for pre-order.
Love Joranalogue modules! Just added Filter 8 yesterday to Compare 2, Contour 1, and Select 2.
