Instruo Lúbadh stereo looper
Johnnyfive
Re: Instruo Lúbadh stereo looper
Post by Johnnyfive » Tue Mar 17, 2020 1:04 pm
Instruo just put up a 2hr long video on Lubadh:
https://www.youtube.com/watch?v=rvj_MdCecaw
I haven't watched yet but should be useful!
Wubz
Post by Wubz » Tue Mar 17, 2020 5:18 pm
Some good news in the sea of doom
cackland
Post by cackland » Tue Mar 17, 2020 5:29 pm
Thanks. Been waiting for this.
Innerself2007
Post by Innerself2007 » Thu Mar 19, 2020 8:04 am
pelang wrote:
Tue Mar 17, 2020 9:49 am
Innerself2007 wrote:
Mon Feb 17, 2020 8:05 am
Just to update everyone on the issue I was having with the Aux output, concerning noise and bleed. Jason reached out to me from Instruo with a fix just in case anyone runs into this.
There is a Bias trimmer on the back of the module that defines the cross points of the aux fader. I adjusted this trimmer and all my issues were resolved.
Again, excellent customer support. Jason is very responsive with quick answers to any questions you might have.
Really loving this module. I'm surprised this thread is as dead as it is. I also find that this is a great companion to the Arbar as well. Totally experimental city!
Hi,
I have the same issue. Could you point me to which trimmer and how it needs to be adjusted?
Im not at the module at the moment but on the back there is a trimmer that is labeled "Bias", look for that and turn a bit with a screw driver.
I had power to the module and turned the trimmer a bit, tested and then repeated until everything sounded right. You will need a small screwdriver to adjust the trimmer. Hope this helps.
On another note, I did the latest firmware update last night and tested. Any small issues I had in the past are now gone, no more pops and clicks when changing start position. Great update! Everything is smooth as butter now.
cyclyk
Post by cyclyk » Thu Mar 19, 2020 9:15 am
Hi,
Same here, super update and the shift/speed trick is excellent!! Back to the great video
pelang
Post by pelang » Thu Mar 19, 2020 9:17 am
Thanks, I will wait till Instruo comes back to me but I found the trimmer.
I had a bit of a rough start with Lubadh but after getting used to the architecture, the signal path, and the two tapes, it is a brilliant module!
Moving audio back and forth between the tapes is :hail: The sound quality as well the decay function sounds excellent.
And Lubadh and Arbhar doing very well together.
Innerself2007
Post by Innerself2007 » Thu Mar 19, 2020 9:32 am
Hi,
Agreed, shift/speed trick is very useful. Still only halfway through the video. Curious what else I am missing
pelang
Post by pelang » Thu Mar 19, 2020 5:01 pm
Hi,
No, the bias trimmer didn't work. The noise is still there (near the left side on both crossfaders and in the center) As well there is bleed-through and distortion of the signal when using the crossfader input/output. Using the same signal on the channels is fine. It feels like a heavy gain stage before the crossfade section, boosting and clipping the signal.
Can you run a test? sinus into the crossfader input (delete both loops), all input and output trimmers on zero and listen to the output crossfader, with both in the faders in the center?
Innerself2007
Post by Innerself2007 » Fri Mar 20, 2020 9:30 am
Hi,
Hmm that's strange, did you try adjusting the trimmer while its powered on and testing in real time? That's what I did and eventually found the sweet spot with no noise or bleed. I'm not sure if I will get to my modular in the next few days but when I do I can try your test. Did Instruo ever get back to you?
pelang
Post by pelang » Fri Mar 20, 2020 10:07 am
Yes, I adjusted with a sinus, oscilloscope and external CV. The bias is perfect but the input is distorted when the crossfade is in the center and the noise/clicks are still present with fader and CV.
Not a big deal but maybe interesting is that I need only +/-1V for external CV to reach the max left/right side.
Still waiting to hear back from instruo.
Innerself2007
Post by Innerself2007 » Fri Mar 20, 2020 1:06 pm
Ohh shoot OK, Instruo might have to chime in with that one, I was hoping the bias would help you since I was getting the noise issue as well. Have you updated the firmware? Curious if that helps.
pelang
Post by pelang » Fri Mar 20, 2020 1:20 pm
Jason came back to me and it looks like a hardware problem in my unit....I already miss this Lubadh !
Wubz
Post by Wubz » Fri Mar 20, 2020 6:13 pm
I've got bleed to, from right deck when crossfader is all the way left. Bias trimmer didn't work. Emailed Jason.
pelang
Post by pelang » Sat Mar 21, 2020 3:24 am
If you just got the bleed it's easy to fix. The "bias" trimmer on the back is a multiturn trimmer. You need to turn it 3-7 times till you start to notice the shift.
But you may want to wait what Jason suggests.
fjoesz
Post by fjoesz » Sat Mar 21, 2020 1:33 pm
ooooh firmware update :sb: :sb: :sb:
so no more clickyness? nice. Jason is a hero!
I use arbhars mic as input for lubadh a lot. I reaaaallly like lubadh's sound btw
stujay18
Post by stujay18 » Sat Mar 21, 2020 7:15 pm
Anyone know how to get balenaEtcher to recognize the SD card so I can update the firmware? My Mac sees the boot SD card no sweat. balenaEtcher does not. Yes I turned it all off and on again, etc. etc.
Also, what's the Instruo-labeled flash drive for on the back of the module? Thanks!
stujay18
Post by stujay18 » Sat Mar 21, 2020 7:25 pm
Figured out the SD/Balena issue, but still wondering what that flash drive is all about! I maaaaaaaay have initially put the new firmware on there. Feel free to mock me, it's ok.
pelang
Post by pelang » Sun Mar 22, 2020 6:53 am
just to besure: the SD card is the small microSD, not the large one on the back of the module
obakegaku
Post by obakegaku » Sun Mar 22, 2020 3:27 pm
I wondered why the function skip wasn't working on mine! Had no idea there was a micro SD on the unit! What a numpty I am.
Wubz
Post by Wubz » Sun Mar 22, 2020 5:07 pm
ummmm, I would never be so stupid as to do that.......yip, definetly not on the flash drive.....nope
stujay18
Post by stujay18 » Sun Mar 22, 2020 7:24 pm
We bow to your constant and unflagging genius!
I'll say that Jason's response was danged-near immediate, thorough, and helpful. For others having difficulty finding the SD card (it's rather well hidden!) and flashing onto the USB, note that there's no harm done. As Jason explained it, the flash drive is for future functionality. Simply re-format it to FAT32 or similar, and pop it right back in there. Instruo -- killing it on all levels.
Wubz
Post by Wubz » Mon Mar 23, 2020 5:54 pm
Don't tell anyne but, I did do that. ssshhhhh
midigods
Post by midigods » Fri Apr 17, 2020 3:43 pm
Do any Lubadh owners have demo videos they can share? I haven't found many good demos on youtube yet. Thanks.
akavalve
Post by akavalve » Fri Apr 17, 2020 4:55 pm
I just got mine...are you looking for 'how to' or 'this is what I did'?
hawkfuzz
Post by hawkfuzz » Fri Apr 17, 2020 5:44 pm
There's a two hour demo on YT....
THUMPR BC SC
