Instruo arbhar granular processor
Moderators: lisa, Kent, Joe.
onthelees
Re: Instruo arbhar granular processor
Post by onthelees » Sun Jan 26, 2020 2:05 am
landmax wrote:
Fri Jan 24, 2020 8:05 am
stujay18 wrote:
Wed Jan 22, 2020 5:46 pm
Hello! Any sense of when places like Perfect Circuit and Detroit Modular might be restocked w/ Arbhars? Thank you!
I would like to know for the UK as well.
I am hearing "Early February" for the next batch...
Dob
Post by Dob » Sun Jan 26, 2020 5:33 am
Does anyone know whether the knob that belongs to a function that you start to modulate with CV will start to behave as an offset to that CV (i.e. knob position is added to CV), or as a attenuator (i.e. knob determines amount of CV) for it?
Bartelby
Post by Bartelby » Sun Jan 26, 2020 9:13 am
It’s more offset. Knob and CV are summed.
Whatisvalis
Post by Whatisvalis » Mon Jan 27, 2020 1:03 pm
Is that for the first US pre-order stock or did anyone get one from a US shop this last week?
matttech
Post by matttech » Mon Jan 27, 2020 1:08 pm
I've got a VERY small batch coming tomorrow - one left that you can preorder on the site now if you're quick!
2 Lubadhs up for grabs too :sb:
Bob Charlotte
Post by Bob Charlotte » Mon Jan 27, 2020 4:54 pm
StateAzure wrote:
Sat Jan 25, 2020 6:33 pm
Here's a recent live stream I did using both Lubadh and Arbhar together, with some improvisation with Peak. Peak is directly connected to the Lubadh. Arbhar has a bunch of different sounds on each layer that I pre-recorded earlier from some soft synths.
Gorgeous StateAzure, as usual. :yay:
MikeLeeBirds
Post by MikeLeeBirds » Tue Jan 28, 2020 9:46 am
My Arbhar sometimes has clicks even with long grains and „soft“ envelope.
Is that to be expected?
gran_syth
Post by gran_syth » Tue Jan 28, 2020 4:53 pm
Just found this comparison
Could be quite useful if you need to decide between one of them, I think.
guigui
Post by guigui » Tue Jan 28, 2020 5:03 pm
If you need to decide between one of them, that video won't help you. You will desperately want both after watching it :goo: :moneyburn: :goo:
gran_syth
Post by gran_syth » Tue Jan 28, 2020 5:13 pm
Absolutely true. :love:
I thought it showed quite clearly there is a difference in approach rather than just a similarity in the feature list.
guigui
Post by guigui » Tue Jan 28, 2020 5:30 pm
That was the most clarifying video I've seen about those modules.
3hands
Post by 3hands » Tue Jan 28, 2020 5:59 pm
The more I see the Instruo stuff, the more I want a rack specifically for their modules.... not only are they fantastically designed from a function vs control point of view, they also look stunning.
Gum is fun, but not on a cat.
My minds an art gallery.
bemushroomed
Post by bemushroomed » Tue Jan 28, 2020 9:34 pm
elevator music galore...
corbetta
Post by corbetta » Tue Jan 28, 2020 11:52 pm
dunno if folks have seen this but it's a nice demo of the follow/time stretch mode
bennyp
Post by bennyp » Wed Jan 29, 2020 7:46 am
Hi there. Is anyone attempting synced rhythmical stuff with Arbhar? I've tried a few different approaches with follow & normal mode, using onset and the capture input (seems to require a gate for on/off?) but I'm struggling to get usable results in this domain. Loving it on drone/ambient stuff but it seems to be suited to this style than bpm-synced stuff generally? I'm sure further experimentation will help tho :) Thanks!
closedLoop
Post by closedLoop » Wed Jan 29, 2020 9:17 am
What methods have you tried to sync up playback?
I don't have my Arbhar yet, but when I've done similar things with Nebulae (granted Nebulae is a similar, but a different design entirely, and nowhere near as complicated as Arbhar), it took quite a bit of experimentation to get the playback to sync up with the rest of what I had going on.
gran_syth
Post by gran_syth » Wed Jan 29, 2020 9:33 am
Are you triggering the grains through the strike cv input? My understanding is that you can use the trigger out to get things aligned to the grains set by the intensity. But using the strike to sync them to other clock/trigger sources?
LunaticSound
Post by LunaticSound » Wed Jan 29, 2020 10:07 am
Arbhar comes with a a mono input? Shock.
buyingitwontmakeucool
Post by buyingitwontmakeucool » Wed Jan 29, 2020 10:33 am
So don’t buy it. Supply is already short
behndy
Post by behndy » Wed Jan 29, 2020 12:30 pm
yep. having Intensity at zero then sending gates to Strike lets one do rhythmic/pattern sync'd play. this is my first patch with Arbhar, recorded 4 notes from TS-L, each a measure long, into different layers. then a gate from Metron whilst randomly shifting through layers. more syncopated near the end. boop?
music, noise, in progress silliness - http://www.youtube.com/c/behndy
LunaticSound
Post by LunaticSound » Wed Jan 29, 2020 2:54 pm
Wait, that is an option? :eek:
xxeyes
Post by xxeyes » Wed Jan 29, 2020 3:40 pm
I understand from other users that I should be able to play field recordings from my phone directly into Arbhar. However, I'm confused as to why Jason runs his guitar through a preamp in the instructional video. If the built-in gain controls can handle line level, should they not also be sufficient for instruments? I want to make sure I won't need a separate preamp module before I purchase Arbhar, as space is very tight.
Whatever the answer is to my question above, this is probably taking it a bit far, but can the built-in preamp bring a contact microphone up to modular level?
cranleigh
Post by cranleigh » Wed Jan 29, 2020 4:15 pm
A guitar gives a much lower-level signal than a line level device like a synth so it makes sense that he'd need a pre for it.
FS: Yamaha CS60, Studio Electronics Oscillation, some other Euro bits.
xxeyes
Post by xxeyes » Wed Jan 29, 2020 4:25 pm
Thanks, that makes sense. However, I didn't convey my confusion properly in my first post. I would presume the built-in microphone is mic level, which is the lowest-level signal, so the gain controls should be able to handle anything, no?
Hovercraft
Post by Hovercraft » Wed Jan 29, 2020 4:32 pm
Guitars and microphones don't output line level, so both would require a preamp. My Arbhar needed a quick trip back to Glasgow--must have been homesick, so I can't test it with phone output, but I do have the Lubadh, and I think it has the same input stage (minus the onset detection). I'll test my iPhone with it and report back. "Line level" can also vary a lot.
