Instruo arbhar granular processor
Moderators: lisa, Kent, Joe.
xxeyes
Re: Instruo arbhar granular processor
Post by xxeyes » Wed Jan 29, 2020 4:37 pm
Hovercraft wrote:
Wed Jan 29, 2020 4:32 pm
xxeyes wrote:
Wed Jan 29, 2020 3:40 pm
I understand from other users that I should be able to play field recordings from my phone directly into Arbhar. However, I'm confused as to why Jason runs his guitar through a preamp in the instructional video. If the built-in gain controls can handle line level, should they not also be sufficient for instruments? I want to make sure I won't need a separate preamp module before I purchase Arbhar, as space is very tight.
Whatever the answer is to my question above, this is probably taking it a bit far, but can the built-in preamp bring a contact microphone up to modular level?
Guitars and microphones don't output line level, so both would require a preamp. My Arbhar needed a quick trip back to Glasgow--must have been homesick, so I can't test it with phone output, but I do have the Lubadh, and I think it has the same input stage (minus the onset detection). I'll test my iPhone with it and report back. "Line level" can also vary a lot.
Thanks, that's kind of you. I would appreciate it!
corbetta
Post by corbetta » Wed Jan 29, 2020 4:51 pm
xxeyes wrote:
Wed Jan 29, 2020 4:25 pm
cranleigh wrote:
Wed Jan 29, 2020 4:15 pm
A guitar gives a much lower-level signal than a line level device like a synth so it makes sense that he'd need a pre for it.
Thanks, that makes sense. However, I didn't convey my confusion properly in my first post. I would presume the built-in microphone is mic level, which is the lowest-level signal, so the gain controls should be able to handle anything, no?
I don't know how the actual signal path of the input stages is designed and executed, but I wouldn't be surprised if the onboard microphone had its own fixed-gain preamplifier stage "upstream" from the onset analysis and recording inputs, to avoid issues with coloration, fidelity, and overall gain-staging with different types of inputs (considering the pretty wide signal level discrepancy between "line" and Synth level).
So the internal microphone is bumped up to line level internally, but the onset/external inputs don't go through the same amplification circuit, meaning that instrument sources require external preamplification. That also would allow you to switch sources without dealing with issues with gain level (i.e. if you had to crank the gain up for the electret microphone, then switched to a synth source, the signal would probably clip)
xxeyes
Post by xxeyes » Wed Jan 29, 2020 4:58 pm
Ah, I see; that's logical. Thanks for the explanation.
nmramchandani
Post by nmramchandani » Wed Jan 29, 2020 6:44 pm
In the case of summing stereo recordings from a phone directly into the Arbhar's mono input, would you all advise using a simple stereo to mono cable like the Hosa CMP-103, or is there a better solution?
Hovercraft
Post by Hovercraft » Wed Jan 29, 2020 7:20 pm
Just tested out my iPhone directly into Lubadh, and with the iPhone volume and Lubadh input gain cranked up, the output was plenty hot. I used the Apple lightning to 1/8" adapter with a normal patch cable between the iPhone and the Lubadh input. If I was using the iPhone as a source, I don't think it's necessary to have an intermediate preamplifier.
xxeyes
Post by xxeyes » Wed Jan 29, 2020 7:47 pm
Great news! Thank you very much, hovercraft!
nmramchandani
Post by nmramchandani » Thu Jan 30, 2020 1:53 pm
Aren’t you losing the entire right side of a stereo track if you just use a regular patch cable from your iPhone?
corbetta
Post by corbetta » Thu Jan 30, 2020 2:44 pm
you can switch your phone audio playback to mono through the accessibility settings (same for laptops, btw)
Sync
Post by Sync » Thu Jan 30, 2020 9:24 pm
Wow-- AWESOME demo... I'll be drooling over it until mine arrives...
corbetta wrote:
Tue Jan 28, 2020 11:52 pm
dunno if folks have seen this but it's a nice demo of the follow/time stretch mode
Sync
gran_syth
Post by gran_syth » Fri Jan 31, 2020 6:23 am
Thought this might be of interest to some here. :yay:
I love the idea of a miniature case!
xxeyes
Post by xxeyes » Fri Jan 31, 2020 10:16 am
I'm planning out my first modular system and I have an Arbhar on order. Can someone advise what I need to control the HOLD parameter on the expander? I presume I could just use one of the four outputs of Maths (with no input required), correct? However, it would be a shame to waste part of Maths on this, so I'm trying to figure out what else I could add to my system to do this and serve other needed functions. Could I use any bi-polar VCA output, with no input signal or CV - just plug the VCA output into the HOLD jack and adjust the parameter with the attenuverter on the VCA? The VCA I plan to use is the Happy Nerding 3x VCA:
https://www.modulargrid.net/e/happy-nerding-3x-vca
Thanks in advance!
r05c03
Post by r05c03 » Fri Jan 31, 2020 1:17 pm
What is the "keyboard" do-dad that is being used there?
Gear List: Elektron Octatrack, Elektron A4,Microbrute, Bass Station, Rings Braids, Pitts Ring Mod, Pitts Osc, Echophon, Intillegel uFold / uMIDI, PNW2, Doepfer 138-c, 119, Tiptop Z4000, Maleko Fade / 8NU8R
VanEck
Post by VanEck » Fri Jan 31, 2020 1:48 pm
How/where are people getting their Arbhar's? I've had mine on pre-order at Perfect Circuit for nearly 3 months now, without so much as an update concerning an ETA. Has any hit the USA yet at all?
DISHEVELED -- PROMETHEUS BURNING -- FOUR PI MOVEMENT
SysEx Dumpster podcast - modular, gear, and other garbage
mdoudoroff
Post by mdoudoroff » Fri Jan 31, 2020 1:54 pm
https://sensel.com/pages/the-sensel-morph
Alas, no direct CV out, so you need some sort of MIDI-to-CV converter.
Innerself2007
Post by Innerself2007 » Fri Jan 31, 2020 2:00 pm
That sucks, I preordered from Control in Brooklyn and received mine a few weeks ago. So they are in the U.S.
bc3
Post by bc3 » Fri Jan 31, 2020 3:02 pm
just my personal experience but pre-ordering anything from PC has always been the longest wait...
drxcm
Post by drxcm » Fri Jan 31, 2020 8:31 pm
Perfect Circuit shipped mine today :omg:
VanEck
Post by VanEck » Sat Feb 01, 2020 12:50 am
Yeah oddly enough, a couple hours after I posted about this, I got a shipping notification. Weird timing lol.
Dob
Post by Dob » Sat Feb 01, 2020 1:32 pm
Love my Arbhar... Very straight forward, inspiring and musical. The led strip is genius, and I keep on discovering new ways to use the module.
Anyone experienced any troubles with CV control? Today it seemed like a quarter of the time it was not registering the CV change from a sequencer for length and start position.
I'm pretty sure the cable and connections were alright.
As if it had too much to do to keep on registering CVs?Jumps to new static values were not always recognised. I like to sequence to specific starting points.
If I started to provide a moving CV, that was registered more easily. Maybe add some slew to overcome!?
Dob
Post by Dob » Sun Feb 02, 2020 4:20 am
In the meantime I started sequencing the layers, which was more stable. Ended up with this recording, Arbhar taking care of the chord-like, breathing, granularry backdrop, with which the track starts
https://soundcloud.com/dob/dobular-1
anton414
Post by anton414 » Tue Feb 04, 2020 2:15 am
There is a gain knob on the back of the module for the microphone preamp level, it's very small but u can turn it with a small screwdriver!
anton414
Post by anton414 » Tue Feb 04, 2020 2:47 am
Btw does anyone know if it's possible to clock the intensity parameter?
Dob
Post by Dob » Wed Feb 05, 2020 2:58 am
You can turn intensity down and clock the "strike" (is it called that?) input. Next to "capture".
From the top of my head, your can trigger 20 extra grains like that, next to the grains that stem from intensity.
Also, you can mix these.
I use this a lot, to have grains play in sync with the rest.
anton414
Post by anton414 » Wed Feb 05, 2020 3:17 am
Yeah I do that too, control the strike with my Marbles, would be cool to be able to make the intensity sync and burst to the clock tho!
anton414
Post by anton414 » Wed Feb 05, 2020 3:19 am
I mean it's easy with the Marbles, I guess I'm just wondering if I'm missing something.
