Klavis - CalTrans
Re: Klavis - CalTrans
There's something I'm not clear about regarding presets. It may be obvious to some but I can 't quite see where it's stated. Here' the query - suppose I have 8 VCOs and I set up and calibrate 4 and all is fine, and I save that to preset 1. Later I want to use the other 4 in combination - I calibrate those and save to preset 2. Now (I'm assuming) depending which group of 4 VCOs I want to use I simply select preset 1 or 2. Is this right?
This is the bit in the manual that leads me to that thinking ....'Each preset stores the transposition, portamento and glissando for all four channels.
Each preset also stores the input scaling for all four channels. This way, each preset can handle a different voltage source if needed'
BUT later - '8. Note that CalTrans automatically can store a single V/Octave Calibration setting for each of its four channels. However, the same setting will be applied to all four presets. The setting for any channel can be updated at any time using the procedure here, but only one setting is stored at a time.'
I'm confused - and I'm not clear what the bold statements above mean? Any help appreciated.
Pitch calibration is not per preset
- Zentek
- Wiggling with Experience
- Contact:
This relates to the Caltrans inputs calibration.
In case you want to use the CT with various (CV melodic) sources that require a different V/Oct calibration.
This is the case when the V/Oct setting cannot be adjusted on these generators.
Therefore, you could use presets to recall a V/Oct setting according to a source.
If all your CV melodic sources are OK regarding V/Oct, you will not need different settings/presets for that use.
This one is for the CalTrans outputs. This is the relation between the CT and each of the VCOs attached.Riggar wrote: ↑Thu Aug 13, 2020 4:10 amBUT later - '8. Note that CalTrans automatically can store a single V/Octave Calibration setting for each of its four channels. However, the same setting will be applied to all four presets. The setting for any channel can be updated at any time using the procedure here, but only one setting is stored at a time.'
For each channel, the same V/Oct setting applies regardless of the presets.
I hope it is clearer now
Klavis
Fine Modular Designs
Just wondering.. can the CalTrans be used just as a 4 channel quantizer? Can I send an LFO into the input and get quantised voltage at the output?
- Zentek
- Contact:
Yes. You can use any number of channels in Neutral calibration in order to only use their musical features (quantizer, transposition, portamento and glissando)
Klavis
Yes that's great - got it now thanks - one on order!
Hello. Hopefully somebody can help me out. Calibrating the Zero-Coast and the Dixie2+ works very well. And it works with all my Sequencers ( Generators ). Thats why I really want/need to calibrate Plaits and the BIA but it won't work. Any advises?
Thank you
Thank you
You need to setup Plaits and BIA so that you get a clean, simple waveform out of them. And they need to drone, of course.. so nothing plugged into the trig input on Plaits.
You go too high too early, man. I remixed a pop song using my piano, an 808 and a Minilogue.
Thank you. Hm, at least with the plaits I did it with a clean signal. Anybody else had problems with calibrating plaits?
What kind of error do you get?
Took me a while. I went through all the modes before realizing that plaits itself needed a calibration doing.
After doing the mutable calibration process it worked first time on green algorithm no 1.
i turned down Timbre, morph and harmonics and used the main output. I also found that restricting the v/oct range helped when doing the calibration.
Rings however . . . i dont think its possible!
I don’t get an error message. Only the upper 2 yellow leds light up. If I play it then with my keyboard the Oktave „loops“.
I guess the calibration from plaits itself is good. If I play it directly with my keyboard it is very stable.
The reason why I want it to use with CalTrans, is because I use different „generators“ and that works good for me ( zero coast, Dixie )
Perfekt, this was the key for calibrating plaits:
"i turned down Timbre, morph and harmonics and used the main output. I also found that restricting the v/oct range helped when doing the calibration."
But still no chance with the BIA.
Nice that you managed to solve it with Plaits. What are you doing to get BIA to drone?
I droned it with an lfo ( Pulse Audio Rate )recently and then it worked. Maybe not perfekt, but good enough.
Thank you
Thank you
I hate tuning oscillators and this looks perfect, have any better alternatives come out since this was released or is this the best option?
- Learning to Wiggle
I seem to have a bit of a tuning issue when using CalTrans. The oscillators calibrate fine, including Plaits, but when I play C1 of my keyboard it is playing a -40 cents flattened C# through CalTrans. If I then plug the CV directly into the oscillator it plays a C. With Plaits I can access C0. After calibrating with CalTrans the lowest I can get is C1. This is not an issue but the sharpened C1 is.
I've checked the cv voltage with a multimeter and it is showing the correct voltages. Is there a reset that will recalibrate the input voltage for C1?
- black_label
- Common Wiggler
What is the scaling tolerance for Caltrans? After calibrating a few different oscillators, I seem to be drifting about 8-10 cents per octave. Without Caltrans, those same oscillators tend to drift about 5-6 cents.
- soon_come
- Contact:
Can someone please confirm what the base note output of their default, neutral-calibrated CalTrans output is with no input? In other words, with just the CV output connected to your oscillator and no transposition at all, with your oscillator tuned to C1, what note gets played? For me it's F1, and I'm confused as to why its output isn't 0V at the neutral position. Maybe I've missed something obvious.
https://soonco.me
(dub and dancehall gone modular)
FS (US / NYC): 5V USB -> 12V step up power converters, MIDI interface, more...
- Zentek
- Contact:
The input range of the CalTrans is zero to 7V.lturner241 wrote: ↑Tue Aug 25, 2020 6:51 amI seem to have a bit of a tuning issue when using CalTrans. The oscillators calibrate fine, including Plaits, but when I play C1 of my keyboard it is playing a -40 cents flattened C# through CalTrans. If I then plug the CV directly into the oscillator it plays a C. With Plaits I can access C0. After calibrating with CalTrans the lowest I can get is C1. This is not an issue but the sharpened C1 is.
However, the voltages very close to both ends are not handled (tens of mV). This is why the lowest note is altered.
Keep in mind that there are no rules/standard about absolute notes in modular; V/Oct only defines relative pitch spacing.
Klavis
- soon_come
- Contact:
Zentek,
Can you please describe what the output of a neutrally calibrated / untransposed output should be with no voltage at the input?
https://soonco.me
- Zentek
- Contact:
Around 40mV.
It relates to the input whose lowest usable voltage is a bit above zero.
Klavis
- soon_come
- Contact:
Thanks for the quick response. So why would my CalTrans be outputting what is essentially an F note (a fourth above) at neutral settings when my oscillator is tuned to a C? Clearly I’m missing something. I’ve done the neutral calibration for each channel as the manual suggests.
https://soonco.me
You’ve probably already done this, but just to ask: Have you reset transposition by simultaneously pressing both push encoders?soon_come wrote: ↑Fri Aug 28, 2020 8:24 amThanks for the quick response. So why would my CalTrans be outputting what is essentially an F note (a fourth above) at neutral settings when my oscillator is tuned to a C? Clearly I’m missing something. I’ve done the neutral calibration for each channel as the manual suggests.
- soon_come
- Contact:
Sure have. All settings as neutral as possible.mvdirty wrote: ↑Sat Aug 29, 2020 10:58 amYou’ve probably already done this, but just to ask: Have you reset transposition by simultaneously pressing both push encoders?soon_come wrote: ↑Fri Aug 28, 2020 8:24 amThanks for the quick response. So why would my CalTrans be outputting what is essentially an F note (a fourth above) at neutral settings when my oscillator is tuned to a C? Clearly I’m missing something. I’ve done the neutral calibration for each channel as the manual suggests.
https://soonco.me
