FX AID - multi audio effect module
Squallaz
Re: FX AID - multi audio effect module
Post by Squallaz » Thu Oct 08, 2020 8:08 am
Igor, 3 parameter knobs = TS9 (overdrive) please hahaha
igorrr
Post by igorrr » Thu Oct 08, 2020 11:04 am
Actually we do not need to spend the valuable 3rd parameter just on the “Level” knob.
All these overdrive/distortion effects can have much sound variations if we implement before and after overdrive “Tone” controls. So the first pre overdrive Tone defines which frequencies will be mostly affected by the overdrive, and the second after overdrive Tone makes the result brighter/darker. This approach is implemented in Bit and Frequency Reducer effects, and will be followed in overdrive/fuzz effects.
Those guitar distortion pedals have countless variations in tones even for the same model: some years have different hipass frequencies (different capacitor values) suitable for different instruments/styles. So it is better to have variable Tone control.
Iridite
Post by Iridite » Thu Oct 08, 2020 12:12 pm
FX Aid XL back in stock at Signal Sounds again.
Dave Peck
Post by Dave Peck » Thu Oct 08, 2020 2:05 pm
Hey Igor! Any chance we can convince you to do a run of an MU format version? I have an MU Super Sawtor and MU FM Aid and I would love to add one of these to the rig.......
From the pictures I have seen, it looks like all of the front panel controls are located on their own separate PCBA, which should help make it much easier to offer alternate panel formats.
julien
Post by julien » Thu Oct 08, 2020 2:31 pm
Granny wrote:
Tue Oct 06, 2020 10:21 am
i would dig a dedicated looper and a stereo filter if thats possible
Stereo filter please :love:
igorrr
Post by igorrr » Thu Oct 08, 2020 2:31 pm
Yes, will do once time permits (MU version and filters).
zenith
Post by zenith » Thu Oct 08, 2020 2:34 pm
My FX AID XL arrives today and I can't be more stoked.
Granny
Post by Granny » Thu Oct 08, 2020 4:14 pm
thanks man…this thing was already excellent with the effects it came with
Dave Peck
Post by Dave Peck » Thu Oct 08, 2020 6:24 pm
:clap: :clap: :clap: I'm reserving the last space of my 88-space MU rig - prime real estate!
Granny
Post by Granny » Fri Oct 09, 2020 6:47 am
:pbear: A stereo EQ would be great, too
DirkB
Post by DirkB » Sat Oct 10, 2020 3:41 am
chronoblob?
autopoiesis
Post by autopoiesis » Sat Oct 10, 2020 5:29 am
my head hurts a little from that question. what aspects of Chronoblob do you want covered by FX Aid? they have completely different layouts (look at the jacks, dedicated buttons, and switch on Chronoblob vs. what FX Aid is working with), and FX Aid already has delay algorithms that do the things that Chronoblob can (open feedback loop, clock sync, dual delays, ping pong delays, tape-like delay time changes), but not all of them simultaneously. besides that, Chronoblob is just a clean delay that's defined by its functions rather than its 'character'.
DirkB
Post by DirkB » Sat Oct 10, 2020 6:23 am
ok, I understand, sorry for the headache ;) my experience with the chronoblob is limited to hearing it through different patches (I don't own one), so I simply thought : why not? thanks for clearing this out
Biff
Post by Biff » Sat Oct 10, 2020 12:50 pm
Loving this module, glad I got the XL. Really enjoying using the mod strip CV of my Keystep to adjust the sample rate on things like the cloud reverb.
If there is a shortage of good suggestions (there isn’t), I would humbly request a lo-fi junky delay that gives that neglected tape echo sound. Otherwise I’ll have to buy two FX aids to run a delay signal into the lo-fi junky ;)
autopoiesis
Post by autopoiesis » Sat Oct 10, 2020 1:02 pm
that's a great thing to want, but how would it fit into 3 control knobs? maybe Delay Time, Feedback, and Tone, where Tone is a dry/wet over some lofi-junky preset. but that's not very exciting! in my opinion.
dooj88
Post by dooj88 » Sat Oct 10, 2020 2:25 pm
anyone notice a high pitched whine when using lofi junky? its related to the algo because when i switch its gone. gain staging issue? i was going into a vca first, and lowering the signal took it away, but had to turn up the channel i was monitoring higher than usual.
Kattefjaes
Post by Kattefjaes » Sat Oct 10, 2020 2:30 pm
It'd be awesome if the editor let you search on strings in the description as well as the title- and also filter by stereo/mono in etc..
xcc
Post by xcc » Sat Oct 10, 2020 4:27 pm
Haven’t had that on any of mine.
igorrr
Post by igorrr » Sat Oct 10, 2020 4:41 pm
Lo-Fi Junky has a compressor with big gain, so any noise applied to the input will be amplified. The effects itself should not have this “whine” with inputs unplugged or fed from a relatively clean source. But if the source is not so clean – the gain will amplify this noise.
Granny
Post by Granny » Sat Oct 10, 2020 5:48 pm
For some reason I can't change the navigation. The led starts blinking but it never arrives at the option mode. And I press it for at least 10 seconds. I updated the FXAID with some new Algos just a few days ago, so it should work. My FXAID is from the first batch, could that be a reason?
dooj88
Post by dooj88 » Sat Oct 10, 2020 6:56 pm
thanks! i'll take a closer look at the input content and unplugged jacks.
Granny
Post by Granny » Sun Oct 11, 2020 5:21 pm
I made an update through the browser and it works now :)
I had problems with the browser before and I though it was because I couldn't get my Adblocker to pause. I tried different browsers, but had no luck. I later found out, that the problem was the .json bank file that I loaded from the standalone app. I had to make a new bank file in the browser and was able to download it.
Funky40
Post by Funky40 » Sun Oct 11, 2020 5:32 pm
that lo-fi junky FX, what is it exactly ? (the function it does)
MikeLeeBirds
Post by MikeLeeBirds » Sun Oct 11, 2020 6:12 pm
https://www.zvex.com/guitar-pedals/ins ... ects-pedal
There’s a Eurorack version, too.
scragz
Post by scragz » Sun Oct 11, 2020 6:39 pm
It's basically a smashed compressor with a tape warble.
