FX AID - multi audio effect module
Granny
Re: FX AID - multi audio effect module
Post by Granny » Thu Apr 01, 2021 6:33 pm
would it be possible to recreate the two algos of the Aeverb?
https://www.modulargrid.net/e/audio-dam ... aeverb-mk2
igorrr
Post by igorrr » Sun Apr 04, 2021 6:10 am
Added two new reverbs, which are inspired by Earthquaker Devices – “Transmisser” pedal, named “Reverb Transmitter” and “Reverb Transmitter Warp”.
bemushroomed
Post by bemushroomed » Sun Apr 04, 2021 6:52 am
Wow, awesome :)
xcc
Post by xcc » Sun Apr 04, 2021 6:56 am
Cool!
starthief
Post by starthief » Sun Apr 04, 2021 7:00 am
That's a must-have.
Lux A Turner
Post by Lux A Turner » Sun Apr 04, 2021 7:03 am
You spoil us, igorrr, you really do.
Now take a day off and have a Happy Easter.
It may stop, but it never ends.
My Rack - v1.0
pelang
Post by pelang » Sun Apr 04, 2021 7:17 am
wow, that's nice. THANKS
Dedal
Post by Dedal » Sun Apr 04, 2021 7:39 am
its gorgeous!!! Thank you so much!! :hail: :hail: :hail:
PARATEK - aesthetics of the Soviet cyberpunk!
Grid: http://www.modulargrid.net/e/vendors/view/749
insta: http://www.instagram.com/paratekorg/
Kosmikos
Post by Kosmikos » Sun Apr 04, 2021 8:04 am
:wow: nice!
Tonefloat01
Post by Tonefloat01 » Sun Apr 04, 2021 6:52 pm
These are fantastic, thank you SO much!
Happy Easter! :sb:
The space you occupy determines the time you live in.
maudibe
Post by maudibe » Mon Apr 05, 2021 5:44 am
Fantastic. Thank you Igorr.
Logarhythm
Post by Logarhythm » Mon Apr 05, 2021 1:55 pm
This thing just sounds fantastic. I had a lot of fun modulating the sample rate and wet/dry on the BlackHole algo, putting its stereo out through uBurst(clouds) in tape loop mode for additional warble.
orbita
Post by orbita » Tue Apr 06, 2021 5:18 pm
Is it possible to replace the knobs with thinner ones - and does anyone have recommendations for replacements?
i'm finding it hard to move them quickly
Also is it possible to select an fx type more quickly than left and right ? eg hold one for bank and then press another for preset in that bank?
xcc
Post by xcc » Tue Apr 06, 2021 5:42 pm
The small Rogan knobs are a great fit and easy to turn. The top three are round shaft and the bottom is a D.
pieter
Post by pieter » Tue Apr 06, 2021 5:43 pm
Yep, and in the UK as well: https://www.thonk.co.uk/shop/micro-knobs/
Logarhythm
Post by Logarhythm » Tue Apr 06, 2021 5:57 pm
The D-shaft Intellijel Silfam knobs are my favorites. The "small skirted" version here tapers to about 9-10mm at the very top instead of the stock Davies' 12mm. https://www.thonk.co.uk/shop/intellijel-black-knobs/
I've tried using the small Befaco covers in places, but I *really* wish they had some kind of grip on them so they didn't require quite as much of a deathgrip to hold on to.
Somebody above in this thread recommended small, sandblasted aluminum ones but the site doesn't have any for sale at the moment.
SOPiiAC
Post by SOPiiAC » Wed Apr 07, 2021 8:56 am
I replaced mine with the smallest Rogans, Three d-shaft and one 18T. There are skirted and unskirted versions.
https://synthcube.com/cart/synth-diy/pa ... es-p-knobs
Logarhythm
Post by Logarhythm » Wed Apr 07, 2021 9:36 am
Ah, interesting; my XL has four D-Shafts. So check yours before you order! (Mine has plastic balls for spacing so watch out for them rolling out.)
SOPiiAC
Post by SOPiiAC » Wed Apr 07, 2021 10:42 am
Yeah, I'm pretty sure the early ones are all d-shaft and later ones have a mix.
igorrr
Post by igorrr » Wed Apr 07, 2021 11:34 am
No, in precovid times all were T18, now upper three are D-shaft and D/W is T18.
Jay
Post by Jay » Wed Apr 07, 2021 1:33 pm
This module is just brilliant. No issues only gorgeous verbs and delays.
Igor, do you think a Vocoder would be doable? One input Modulator, one input carrier?
Logarhythm
Post by Logarhythm » Wed Apr 07, 2021 2:16 pm
:doh: Sure enough, I only lifted the bottom knob up enough to peek and thought I was seeing a D-shaft but it is in fact T18. My bad!
Thanks for a wonderful module btw!
orbita
Post by orbita » Wed Apr 07, 2021 3:04 pm
Thank you for the links Logarhythm, pieter, SOPiiAC, xcc!
igorrr
Post by igorrr » Thu Apr 08, 2021 7:29 am
Tuner effect generates three fixed frequencies: 220 Hz, 440 Hz, 880 Hz. Left output - sawtooth wave, right output – triangle wave.
4hp FX AID version should have its CV input routed to the Sample Rate and kept unconnected for proper frequencies.
Some warm up time around 10 minutes is required for correct operation.
Jay
Post by Jay » Thu Apr 08, 2021 8:17 am
:hail:
Really great idea!
