Synth Tech e520 Hyperion Stereo Audio Processor
Re: Synth Tech e520 Hyperion Stereo Audio Processor
Loving the "Moses" feature. And some other algorithms.
FS/T: Malekko Manther Growl, Make Noise Echophon, Livewire AFG, Bastl Knit Rider, ARC Artificial Neural Network, PAiA Gnome, Sequential Circuits MultiTrak.
FT: EMS Synthi AKS (1972, without KS), any 4ms modules.
WTB/T: Dewanatron Swarmatron, Bastl SoftPop, LZX modules, Wavemakers modular, EML 300, 301, 400.
- Common Wiggler
Might that be 4 individual v/o inputs for roll your own chords?
Sounds great. I assume there will be an unquantized mode, too? That said, would also love if you could somehow implement a slew on one of the CVs for v/oct (ie. knob at 9 oclock is a fast slew, slow at 3 oclock), especially for chord mode. Maybe possible to calculate separate slew rates for different intervals so they all arrive on the chord at the same time? Though it might sound nice for notes that are spread further apart to reach their pitch destination later, too.
Keep the teasers coming!
ok, sorry for long post ! ( and from a non native english speaking one)
edit: (please don´t read if bored, thanks )
my main wish for the E520 beside "spectral" stuff that i can´t frame or phrase out, since i´m coming from a VST which is way more complex than what E520 ever could handle with its UI is:
a special delay that is mainly tailored for Resonating sounds !
which incorporates granularisation inclouding a grain seed, but not tailored towards that the user could control the seed with triggers or so.
NOT mainly tailored towrads cloudy atmospheres, but towards bloominh feedbacks and to act there within as the special sauce.
just: ad a grainsize parameter, a grain-quantity parameter, tailor the delay times at least in its lowest range towards resonating sounds that can go up to something like 250ms in the upper part of the pots stroke.
tailor the whole granualar thing to work with kranked feedback.
put L-R feedback on one knob, same for Mix, to free up these controls.
in fact, do i refer here to a special patch .....and more so a special type of sound......that can be had allready with the MI Clouds "parasites" Granular mode.
These sounds i refer to are not possible with the original Clouds FW, btw. .
the point of that FX is:
to get resonatings going,
to combine pitchshifting with it,
to control that blooming (and other aspects) further by adjusting the grain-size parameter,
to create a special form of sound smearing, and then: all togeteher in one.
Its a FX that IS dependent on dynamic manual wiggling or cV controls.
i heard btw. exactly that type of sounds in several Hollywood Films . "Wow" sounds, you can bet.
.....not shure where you could go with Kyma, but i´ve not seen anything other than clouds which could do those sounds.
But: clouds was not tailored to do resonating stuff, it has the FB and Mix parameter hidden and only one at a time available,
and finally, the pitchshifting does not sound exactly good.
i know, what some folks might want answer here,..............
have you ever told Paul he should NOT release the E440 Filter, since there are allready other filters available
But you would tell me, i know..........go patch with Clouds ! ( oh well, thats what i´m allready doing, and i´m entirely pro on that
fun fact: it took me months to be able to replicate that sound that i do with clouds with the microcell ! and i even just get halfways there,
ITs NOT the same !
and i´m quite convinced that i could NOT do it with the "monsoon" variant.
at least aslong we speak about using onboard controls.
i also never heard that sound in any Clouds demo with two half exeptions:
one guy had a wild jam, where that type of sound sometimes emerged, ....so halfways,
And i saw a long talk YT Vid with Ben ( Divkid) where he used a patch which is based on exactly that to "monster-morph" his voice.
a slight different patch respectivly use than what i patch, but based on the same principles.
would be great if you´d be willing to bring that *very special* sound aspect that Clouds "can" deliver, into the E520.
the trick with that type of FX is btw. to totally understand the whole interdependency of the parameters, especially the blooing effect of the feedback and its interdependencys,
since the trick is totally to get it just to bloom for a moment.
there is afaik right now now other hardware, module, or software that could make that type of blooming-resonating sound with that gloriousity and magic than clouds has. its entirely magic !
Now, one of the tricks and fun things with that type of FX respectivly patch is what happens when the grain-size is shifted !
thats the part that counts, on top of what i worded out above.
I don´t know what happens inside in the realm of numbers in the dsp, but there must happen some permanent glitching,
.........kind of glitching thru the recordet buffer.
the blooming is one, that type of glitching the other, and then: combine it !
its a dynamic thing , a FX that come only to live if you wiggle/play it by plan !
but that type of FX has finally many many faces to had. you can leave pitchshift and granularisation alone set to default values, then you have a delay ( which *really* should be tailored here to the "resonating" range......plus up to 250ms in its last third of the pots stroke /
........funnily, the needed delay part is finally coming from the grain seed and sgrain size )
hope its clear what i mean, hope i can trigger you
in regards to spectral FX:
all the given ones in the E520 have 512 bands, right ?
in the spectral FX´es that i use are 128 or 256 bands also often a superinteresting option, and sometimes the better choice.
( GRM Tools, and unfiltered audios "SpecOps" )
personally, i have a superhard time to justifie the Rackspace that the E520 is taking.
i really hope to see some progress in direction of creative uses.
one of the E520 big strengts is definitly its pitchshifting quality !
please build some up on that.
please think way more open that you seem to do......
ITs NOT the same !
any other forums for "experimental electronic music making" or eurorack to consider ?
beside "lines" which was allready suggested
Each of the 4 resonators has it's own CV input, so you can "roll your own chords" when the quantizer is set to OFF
- Common Wiggler
another request would be a kind of "enveloped (percussion) Delay", which would renquire percussive material to be sent in i guess.
Extract from each audio hit that comes in a trigger, ......trigger something like a AHD envelope,.....aplly that envelope to the related audio snippet,
DON´T even think about adding a dedicated lenght control per trigger/audio snippet, .......just add one general "Lenght" control,
aplly it to the single "audio snippets/taps" with something like a S&H.
a full controllability of the audio Echoes lenght would not be given,
but a funny way to lively up the things with just one CV for Lenght,
which is absolutely how we think and patch in eurorack-land.
I imagine it would be real fun and useful for "undense" percussions or Drums to lively things up
edit: if feedback could also be apllyed in that S&H way as above, now that would be fun, ....more thinking wowards to let the snippets resonate
***E520 Hyperion Stereo Effect Processor LAST TIME PREORDERS AVAILABLE***
I have been keeping track of order cancellations and inventory and there will be a limited number of E520s available before moving to dealer-only sales.
Please read the following carefully if you are interested in buying these.
a) I will enable the cart at 1PM Texas Time on Friday the 25th
b) there are 20 black and 10 silver, no PODx combos as in the KS
c) I use UPS and DHL (overseas), shipping is expensive and USPS is a train wreck
d) these will ship the 2nd half of Nov.
e) the cost is $659 plus shipping which will be calculated in the cart. This shipping covers insurance but not VAT.
If the pre-orders do not sell out before I start shipping to dealers, which is also the middle of Nov, I will close the pre-orders. Read carefully: I said sell out, not begin shipping. So, I suggest ordering before Nov 10th.
Info/demos/PDF of the algorithms here:
www.synthtech.com/eurorack/E520
New E520 Hyperion "Headspace" demo! Extensive description on the SoundCloud page. Demo by Robert Rich, algorithm development by Eric Brombaugh.
Headphones will give a more 'intense' effect (more "motion")
This uses 4 different manipulations (Haas effect, mid-side processor, phase, and comb filters) to create wide-image stereo from mono sources. Unlike a simple L/R panner (which is based on volume), Headspace uses 4 chained DSP algorithms to create a more 'natural' stereo field, with full voltage control over placement, 'distance', and 'room ambience'.
that sounds like a really cool new way to put something in the stereo field. cant wait to get mine and try it out, although i think im likely one of the very last ones to ship
@paults do you have an update on shipping? I’m kickstarter backer #138 and it was my understanding you were getting near my number a week or so ago.
*received the shipping notification - thank you paults
Here's a preliminary demo of the final new algo for the next firmware release. Dirt is a toolkit for adding grit, grunge and distortion.
One of the four new effects in the upcoming V1.1 firmware release is an augmented version of the original Spectral Drone algorithm that has 4x more resolution than the original. Here's a demo of that with a simple test sequence. Then starting at about 16 seconds I add a 2nd E520 unit running the Shimmer Reverb for an even fuller sound.
Looking forward to the update. Headspace is really interesting, at times sounding like a fun reverb (for instance, about 1:06-1:10). Is this just a product of the sound "moving" around in the stereo image? Curious if this would do anything interesting with 2 waveforms that are very closely tuned (and beating) or 2 waves FMing each other. Hopefully nothing causing brains to totally melt in skulls
Wasn't expecting much from Dirt but sounds like there's some fun stuff going on! I'm sure the tape-style effects will get a lot of use. This one's begging to be put in the feedback path of a long delay.
Backer 187, wondering if there's any update on how the queue is progressing - the last update estimated they'd all be done by 24 October.
Not too fussed if the schedule has slipped a bit, just wondering where we're up to as things been quiet for a few weeks now...?
Quiet? They are never quiet. You should follow them on Facebook:butter wrote: ↑Sat Oct 17, 2020 9:09 pmBacker 187, wondering if there's any update on how the queue is progressing - the last update estimated they'd all be done by 24 October.
"18Oct Sunday PM update
a) tomorrow is last day for pre-ordering E520 Hyperions
b) E520s will start shipping again on Wednesday. I will be working extended hours to ship out all the modules left in the KickStarter this month. I might slip into the first week of Nov.
c) Still on schedule for E520 V1.1 firmware released on Nov. 17th
d) I received my powered breadboard for use in the $10 level Patreon tutorials. So will have 2 new videos ($10/$25 level) at the end of October."
Thanks for the update Tekbrain. I had about the same question as butter but didn't want to pile on plus I'm not that impatient that I can't wait a month or so longer (not implying that butter is impatient mind!).
Not all of us are on Facebook though. I personally avoid it like the plague. It would be helpful if Paul would copy those updates on kickstarter but well, I rather he makes great modules than be the perfect news updater. ;-)
- zengomi
- Wiggling with Experience
- Contact:
Early elements that led the way: Synthesis Technology E520 treating Furthrrr Generator and Verbos Harmonic Oscillator, joined at the hip in XAOC Praga. E370 (sometimes FM’d by Just Friends) and Batumi send LFOs to Verbos HO. Tempo manually rendered via Pamela. Fundamental tonality manually rendered via Frap Tools 321 offset sent to mixer and distributed.
USTA primitivo
By the end of this week, I should be shipped out to Backer #194 in KickStarter. I am running low on black E520 panels, more are on order and should arrive later this week. If I do run out, then all silver modules within the KS my be shipped before the black ones. Will have to wait and see.
Beta testing on the updated E520 firmware continues, and once all the KS modules ship, I will release it. Looking like around Nov 10th or so.
Dealers are asking for their non-E520 modules, as the "holiday purchasing season" arrives. Once the E520 KS modules are done, I will spend a full week building/shipping to dealers.
There are 83 E520s to ship after the KS modules. I do not think I will finish them until around Dec. 8th - 12th. I will of course try to finish ASAP.
I will be off on Christmas break from Dec 18 - Feb 15th. By 'off' I mean not shipping, as by then I fully expect the US to be in full lock-down. I have several non-synth projects to pass the dark winter days (like MAYBE actually finishing Fallout 4).
For Patreons: I am going to start shooting the $25 level Alesis MidiVerb first video. I have all but 1 thing I need for the $10 tutorial on "What is Voltage and Ground?" but it's due on Wednesday and I can start on that as well.
I have a 110% full schedule running until I just come to a dead stop on Dec 18th. I'll go as fast as I can.
Got the module yesterday. Just want to say that it's fantastic. Got some wonderful sounds out of it just testing the different algo's. The UI is particulary nice. Well worth the wait!
I have 33 more units to ship and the KickStarter backlog will be completed.
However, I CANNOT SHIP your unit if you have not:
a) paid the added UPS/DHL shipping (unless you have told me that USPS is OK). There are 7 of you currently that have not. Please check your email/spam folders for a message sent via the KickStarter app.
b) have ambiguous shipping address/issues. There are 3 of you that have this, again: I have sent 1 or more messages to your email.
c) you have never completed the "Survey", which how you tell me your valid name/address/phone #. Backer #157 "Renars" , this is you. No survey, no shipping. That's not MY rule, that is a KickStarter legal requirement.
Unless there is some unpredicted issue, I will have shipped all I CAN by Monday 9Nov. I am not asking/pleading again. Rather, I will move on to the 83 units remaining in the post-KS pile, and IF I do hear back after 9Nov, you get to be the VERY LAST person shipped.
The last shipping day for me is 18Dec. Period. At this time, I do not see any reason why I cannot ship EVERY E520 out before then. Unless the post-KS folks also do not get back to me (see next section).
People that ordered post-KS (Dec 16th to last week): ~ 1 week before you are due to ship, I will email you with what I have on file for address and panel color, and if there is a PODX included. Foreign orders MUST have a phone #.
I will see if the postage collected at the time you placed the order is sufficient for UPS or DHL. If not, in the email, I will request additional funds ($12 for UPS and $40 for DHL). If you are in the USA, and want to use USPS (VERY HIGHLY NOT RECOMMENDED) just indicate on the response and no additional $12 is needed. If you are overseas, I WILL NOT, REPEAT WILL NOT ship anything but DHL. DHL has been flawless, over 120 packages delivered and most within 36hrs of shipping.
If you want to swap panel colors, you may indicate this in your response, There is no added charge for swapping panel colors.
Mainly, just verify the names/address/phone. People move all the time. This is why I do this. Some people used a work address, and now are working from home.
I will start shipping the post-KS orders beginning Wed 11Nov. So PLEASE check your emails/spam folders EVERY DAY beginning on Tuesday PM when I will start emailing them out. Remember, all I have is your address you used for PayPal. This may not me your 'primary' account, but it's ALL I HAVE. It may not even be "your" account, but's it's ALL I HAVE.
Paul, I just wanted to chime in here and say that I really appreciate how you are constantly communicating with all of us. I sincerely appreciate you taking time to keep us up to date.
Quick Update:
I'll be finished with shipping all the KickStarter modules by Tuesday of next week.
I will then start, in batches of 15, sending emails out to the people that ordered post-KS to confirm address, etc.
It will take me until somewhere around Dec 8th to 100% ship every preorder E520. They then become a "standard dealer item".
I thought I'd do a little test with two items from Texas to UK. One with DHL, one with USPS.
DHL arrived today and took 2 days… USPS hasn't even left the state yet.
Paul, that was one well packed module!
