Endorphines 6HP
psienide
Re: Endorphines 6HP
Post by psienide » Fri Feb 07, 2020 12:52 pm
ALTERNATIVE SOLUTION: Crank those trimpots almost all the way up until you get the really dope overdrive effect, then attenuate the output aLOT.
This is actually what I ended up going with, and it sounds really good if that's your sort of thing.
This is what I did to tame the noise floor, but then it becomes more like an active filter. It was cool for a while but imparted too much color on signals I didn't want it to.
Now my SQWK DIRTY has a different problem - it is shaping everything with an exponential decay. Now a simple square wave looks like an exp decay saw.
fruitsnake
Re: Endorphines 6HP
Post by fruitsnake » Fri Feb 07, 2020 6:20 pm
tvparcable wrote:
Fri Feb 07, 2020 3:42 am
fruitsnake wrote:
Thu Feb 06, 2020 7:16 pm
I suspect something to do with power supply compatibility only because the tones that I hear in the above examples sound like the background tones that you get when you run 90's Digitech pedals with a PSU that they don't like - even when the specs are identical to the original - they're just extra special like that. I never really understood what's going on there, but maybe it's similar to the MW problem.
I think you might be onto something. The first time I tried mine was on my uZeus power. I couldn't hear any noise unless I cranked the volume extremely high with no signal going through the MW (or with the volume at 0 on the MW). After I moved it to my 2x104 case with a different PSU, the noise started to be the same as what you hear on people's reports. None of the other modules became noisy on the new case.
Bingo! I was wondering if someone would be able to perform such a test. Anyone else out there wanna report on what power module they're using with their Milky Way and whether or not the noise is present?
indigogogo
Re: Endorphines 6HP
Post by indigogogo » Fri Feb 07, 2020 9:02 pm
Yeah at this point I think the filter should be tagged as a distortion on modular grid. As it turns out I was actually looking for A 6hp stereo Distortion and couldn't find one So this is weirdly perfect for me, But if you're looking for a clean stereo filter, you might want to check out the happy nerding stereo MMF.
indigogogo
Re: Endorphines 6HP
Post by indigogogo » Fri Feb 07, 2020 10:28 pm
OK wow check this out. Squawk causes audio bleed without the output? This is driving me crazy. Just connecting an oscillator in leads to bleed through noise.
psienide
Re: Endorphines 6HP
Post by psienide » Fri Feb 07, 2020 11:09 pm
This is a square wave directly into the output mixer
Raw Sq output
This is that same wave through SQWK Dirty in the first mode, cutoff fully open, no res, no highpass, and gain fully CCW.
Same thru SQWK
southberry
Re: Endorphines 6HP
Post by southberry » Sat Feb 08, 2020 4:39 am
I had the MW noise problem using an Eowave Source d'Energie and a Volgen brick (the one recommended by Make Noise to avoid problem with Rene / Pressure Points) never have a problem with any modules (analog or digital ...)
Inju
Re: Endorphines 6HP
Post by Inju » Sat Feb 08, 2020 8:42 am
I'm so sorry to coming this late. I would have let you all know the FX is noisy. I have the same issue on my Blacknoir. The individual outs on the Blacknoir are perfect, however if you use the effects the noise is not good unless you adjust the gain stage. Make sure to increase the volumn going into the input as high as possible without clipping then reduce the output in your mixer. I bought a attenuator just for this. This has made it usuable for me. Have they put out a noise firmware for the Blacknoir? In terms of the noise levels by reviewers I always was under the belief they use noise filters in their DAW.
plainjanefrancis
Re: Endorphines 6HP
Post by plainjanefrancis » Sat Feb 08, 2020 9:17 am
I don't think as many people have complained about the blck noir, though the problem is very pronounced on the mix out of that module. If there was an update to fix the blck noir noise problem I'd buy it again in a heartbeat!
Wubz
Re: Endorphines 6HP
Post by Wubz » Sun Feb 09, 2020 8:14 pm
I don't get much noise on mine. Zeus Studio Bus power.
chriscarter
Re: Endorphines 6HP
Post by chriscarter » Wed Feb 12, 2020 6:36 am
I just installed the 'NOISE FIX' firmware upgrade for my Milky Way and now Channel 2 is not working, completely mute. I've tried different power supplies (Intellijel, TipTop, Doepfer), different cables, signals etc. but no joy. Was working fine before... although noisy.
Anyone else come across this issue?
klick
Re: Endorphines 6HP
Post by klick » Wed Feb 12, 2020 8:48 am
May you try to reset preferences ? (long press both right and left buttons for more than 5 seconds, then release).
Then, try to set the stereo mix :
long press the left button, to switch to stereo mix (purple led), then turn fully the cabin pressure and cabin fever twice), and set them in the center.
You should see left and right panned ;)
great when controlled by cv by the way ;)
chriscarter
Re: Endorphines 6HP
Post by chriscarter » Wed Feb 12, 2020 12:05 pm
Thanks so much for the tips - I wasn't aware of those.
That fixed the issue and all is working as expected now.
rank30
Re: Endorphines 6HP
Post by rank30 » Fri Feb 14, 2020 7:44 am
I’m keeping an eye on this thread as I really wanted the Milky Way. Looked to be a lot of bang in such a small HP.
I don’t mean to take it away from the sqwark and MW issues but has anyone tried the airstreamer? Any good?
:eek:
klick
Re: Endorphines 6HP
Post by klick » Fri Feb 14, 2020 6:18 pm
disclaimer :
biased opinion about airstreamer, don't trust me, at least this is an extract of some of the design goals :
- great envelope, easy to use, well designed (looping mode, attack/release, attack/sustain release), very good shaping and easy to control.
The story could stop here, it was the initial intent, anyone can use it without thinking about how to use it.
under it's apparently simplicity and ease of use, it's a bag of trick :
digging into it, allow it to be used in a "serge" way, patch programming style, some examples below :
- great audio tracking to be used as an oscillator, with the 1/v oct input, shape pots then become a waveshaper, from triangle to saw
- vca, this is really a great added value ! (bipolar vca,ring modulation like, react very well at audio rate too)
- slew ! portamento like. quite interesting at audio rate for glitchy sounds, designed to be followed by a nice reverb like milky way :)
- normalization between attack/decay speed (can be broken with a dummy cable), to allow simple cv control over duration
- very good when self patched (unipolar output into ring mod, etc) for not that predictible results, you can really patch any input into any output, a lot of sweetspots can be found.
- sample and hold
- track and hold if I can remember well
due to all functionality they could cover, having a pair in a small case, prove to be a great added value, one being set with end of attack trigger, the other one with end of decay.
I hope it's a good introduction to what the module can do ;)
again, don't trust me, try it, my opinion is biased.
rank30
Re: Endorphines 6HP
Post by rank30 » Sun Feb 16, 2020 8:36 am
disclaimer :
- sample and hold
Top stuff, thanks Klick!
:eek:
dangayle
Re: Endorphines 6HP
Post by dangayle » Sun Feb 16, 2020 2:27 pm
Has anyone tried using a power cable with a conditioner on it, like the Trogotronic? https://trogotronic.com/product/m05/
