Expert Sleepers ES-9 USB Audio Interface
Ys521wow
Re: Expert Sleepers ES-9 USB Audio Interface
Post by Ys521wow » Sat Feb 15, 2020 12:54 am
Bachelard wrote:
Tue Feb 11, 2020 6:39 pm
Ys521wow wrote:
Sat Jan 04, 2020 12:14 am
Got my Es 9 yesterday and tried it to connected to Ableton CV tool. And I didn’t get the audio signal from my Oscillator out into the input 1 of Es9, also I tried to set the CV instrument pitch to the Ext. out 4 and it didn’t connected to es9. I set channel configuration 1-6 input mono and stereo and 1-6 output mono and stereo in Ableton. I don’t know what parts I’m missing here, I’m appreciate it if someone could help me out.
Ys521wow - I was setting this up last week for a client, and noticed in the manual that the ES-9 analog (3.5mm) outputs are actually 9-16. So if you're trying to send gate and cv from the cv tool, try assigning output 9 to the Gate and 10 to pitch. I tried that and saw the output jack light up with the MIDI clip playing in Ableton.
From the manual:
Channel numbering
The default channel numbering in your DAW will appear as follows, though this can be
reconfigured as required.
Main outputs: 1/2
Headphone output: mix of 1/2 & 3/4
S/PDIF output: 5/6
ES-5 output: 7/8
3.5mm outputs: 9-16
Thank you! Also I noticed my MacBook settings wasn’t right. Now I’m happy w my Es9.
trinitymartyrdom
Post by trinitymartyrdom » Mon Feb 17, 2020 8:14 am
Good news!
My order from november was sent today from Thomann, so there is hope for all of us :party:
thsc0036
Post by thsc0036 » Mon Feb 17, 2020 9:40 am
My order at Musicstore from 4th of December just got postponed until 7th of April...it’s the third time the delivery got delayed :(
100000bps
Post by 100000bps » Thu Feb 20, 2020 6:30 pm
Can you plug guitar post pedals straight into es-9 using some 1/4 to 1/8 cable adapters ?
os
Post by os » Fri Feb 21, 2020 3:41 am
You can, though the signal will be a little low coming into the DAW.
trinitymartyrdom
Post by trinitymartyrdom » Fri Feb 21, 2020 11:27 am
Hello again,
I just received my es-9 from Thomann and it sounds really good!
I have a dumb question that I didn't exactly found an answer to :
Is it possible to have my apollo and the es-9 running and have all the ins and outs of both machines appear on Ableton?
I went for the es-9 instead of es-3&6 for the many inputs and outputs.
Thanx!
os
Post by os » Fri Feb 21, 2020 11:41 am
Yes, if you're on mac. With difficulty, if Windows.
trinitymartyrdom
Post by trinitymartyrdom » Fri Feb 21, 2020 11:52 am
Hey Os, thank you for answering. Great, I'm on Mac! Can you tell me how to do it?
os
Post by os » Fri Feb 21, 2020 12:02 pm
Use the Audio MIDI Setup utility to create an Aggregate.
trinitymartyrdom
Post by trinitymartyrdom » Fri Feb 21, 2020 2:45 pm
Thank you Os, I just did and it works perfectly!
:hyper:
Jtalton
Post by Jtalton » Sat Feb 22, 2020 10:50 am
:hyper:
How is the sync. I am about to pickup a es9 and work with that as a cv interface and have my apollo16 as the audio interface but i am worried about sync issues with ableton.
dip_registered
Post by dip_registered » Sat Feb 22, 2020 5:29 pm
Has anyone tried the ES-9 with an audio interface plugged into it? So it acts as an input (let’s say you have an audio interface with phantom powered mics plugged in)?
I haven’t found a video or examples of this working and just wondered if someone had experience. Cheers!
os
Post by os » Sun Feb 23, 2020 4:20 am
Not sure what you mean. How would you connect the other audio interface to the ES-9?
lobrix
Post by lobrix » Sun Feb 23, 2020 8:39 pm
Hi guys,
I received the ES-9 two days ago and am super happy about it. Many thanks to Os for sharing those great tools and information with us!!!
As a begginer in the modular world, I am struggeling with some basics and search for your help. I had to face the same problem as described above. I was struggeling with the CV Tools calibration of the oscillator "Z3000".
By sending a signal from the oscillator singwave into...
>ES-9/input 1
>CV tools
>CV instruments has no incomming signal
>Audio from -> Ext.in -> input 1
CV pitch is sending from...
>CV instruments
>Ext. out.
>ES-9 out. 9 (ES-9 output 1) to "Z3000" - 1V/Oct.
CV gate is sending from
>CV instruments
>Ext. out.
>ES-9 out.10 (ES-9 output 2) to "Z3000" SYNC
At the preverences all mono inputs are activated. Stereo inputs only 1/2. Activated mono outputs 1/2-15/16 and stereo 1/2-3/4.
Midi preverences inputs and outputs of ES-9:
track_on
sync_on
remote_on
By starting the calibration pitch and gate signals are lightig up for 2-3 seconds, then the calibrations stops, showing
"error! non or insufficient control voltage. check connection between audio interface and oscillator increase master volume of your audio interface."
Where am I doing wrong?
os
Post by os » Mon Feb 24, 2020 3:32 am
Are you on mac? If so, have you enabled the DAW to access audio input ('access the microphone') in the macOS security settings?
trinitymartyrdom
Post by trinitymartyrdom » Mon Feb 24, 2020 8:01 am
[/quote]
[/quote]
Hey, so far the sync is really good, I didn't have to set any type of delay for it to be on time. I haven't worked on big Ableton sessions but I will let you know if any sync problem comes up.
Jtalton
Post by Jtalton » Mon Feb 24, 2020 10:04 am
[/quote]
[/quote]
thanks for the reply. i am so excited to have this much IO with audio and cv. Still waiting from my ES9 to come to Japan but i can wait. :sarcasm: :bang:
trinitymartyrdom
Post by trinitymartyrdom » Mon Feb 24, 2020 2:55 pm
Well I think you are going to be very satisfied!
In my opinion, the other great feature on this machine is the quality of the sound I got by NOT going through my mixer, then into my soundcard.
Instead of many conversions, I know only have one, and it's so much better that way! :party:
lobrix
Post by lobrix » Mon Feb 24, 2020 11:04 pm
Yes, that's it! Now its running perfect! Many Thanks for your quick support Os! I really enjoy my decision of buying an expert sleepers tool and am happy to buy another one (ES-5) on friday.
os
Post by os » Tue Feb 25, 2020 3:40 am
Not one but *two* ES-9/VCV videos published yesterday:
