Expert Sleepers ES-9 USB Audio Interface
shize312
Re: Expert Sleepers ES-9 USB Audio Interface
Post by shize312 » Thu Sep 17, 2020 9:55 am
Possible stupid question ahead: is anybody else using the ES-9 upside down? and why?
k.rosakruz
Post by k.rosakruz » Thu Sep 17, 2020 10:13 am
os, I’m eager to purchase one of these. Do you know when US retailers will have some in stock?
tonefloat
Post by tonefloat » Thu Sep 17, 2020 2:27 pm
yes
escargot
Post by escargot » Thu Sep 17, 2020 3:03 pm
Me too, ended up that way for cable management. Not a big deal to read numbers upside down!
MvK
Post by MvK » Thu Sep 17, 2020 4:56 pm
virtualpt wrote:
Tue Sep 15, 2020 6:17 pm
MvK wrote:
Tue Sep 15, 2020 2:32 pm
hi,
I'm a very happy customer of the es-9.
But now I've got a problem which isn't necessarily a fault of the interface, but I'm not sure.
I got a 12 Channel setup in reaper on windows 10. When I "record arm" all the channels for input level metering everything works as it should (tested many hours). But when I record after maximum 2 minutes the device is closed as it is shown by the software and recording stops. Then the audiodevice toggles between ready and not ready. I've tried 2 different USB cables.
16gb RAM
intel sandy bridge i7 CPU
I'm using 96 kHz maximum sampling rate and "safe mode"
The fact that the metering works uninterrupted makes me think that the problem isn#t caused by the es-9 because I guess it makes no difference to the interface if recording is enabled or not. But my understanding of these things is limited.
It would be a great help if some wigglers could give me hints on what could go wrong and what I could try to get rid of the problem.
is a more expensive usb cable worth it?
thanks in advance
I think this may be a problem with Windows turning off the USB ports to save power. There are numerous reports & solutions for this, try a search for Windows turning off USB ports & try the solutions.
sadly that wasn't the problem. I deactivated the power saving on USB ports in the device manager but that didn't solve the problem. Damn, I've looked everywhere an I'm kind of desperate because I really need my recordings going.
It seems that there is a display lag while recording. Sometimes the graphic of the whole program (reaper) doesn't update for 10-20 seconds. In some cases it reverts back to normal and the recording seems to go on. However when I play back the tracks there is an audioglitch at the position where the display-dropout happened, which is strange because the waveforms are there and look as they should. In other cases the recording completely stops and the audiodevice is gone.
any further suggestions?
fruitsnake
Post by fruitsnake » Thu Sep 17, 2020 5:14 pm
In Reaper's audio device settings, do you have "audio system" set to ASIO and "ASIO driver" set to Expert Sleepers USB? Also you'll have to set the available inputs and outputs to 1-16 in the drop-down menus. That's the only way I was able to get it to work right with Reaper.
MvK
Post by MvK » Fri Sep 18, 2020 5:53 am
Yes, The ASIO driver is working but only for max. 2 minutes after recording starts.
MvK
Post by MvK » Sat Sep 19, 2020 1:09 pm
turns out it works in bitwig.
thanks for the suggestions
Pictus
Post by Pictus » Sun Sep 20, 2020 2:45 pm
MvK wrote:
Tue Sep 15, 2020 6:39 pm
thanks! But is that also the case in desktop PCs? I thought these power saving things are only present in laptops?
For Intel
For AMD you have to first install the chipset drivers.
