Expert Sleepers ES-9 USB Audio Interface
Post by os » Wed Dec 18, 2019 2:59 am
For example, is there a way to just tell the module that all inputs should be output in Mono on output 1? Then I could use my system with this as a mixer even with no iPad around (ES-8 output into Intellijel 1U Audio Out module).
Yes you can do that.
if i want to expand the ES9 inputs and outputs i just use the ES5 and configure which are inputs and which are outputs?
The ES-5 is outputs only.
Jtalton
Post by Jtalton » Wed Dec 18, 2019 4:45 am
The ES-5 is outputs only.[/quote]
Can you expand the inputs of the es9?
Post by os » Wed Dec 18, 2019 5:55 am
Only via the SPDIF input.
versipellis
Re: Expert Sleepers ES-9 USB Audio Interface
Post by versipellis » Thu Jan 02, 2020 7:38 pm
Hey os - any idea when the next batch of restocks will be? Looks like PCA, DM, and ctrl-mod are all out of stock/showing as "preorder".
tunes: https://www.soundcloud.com/dycedot
in boston? I run nights: https://www.facebook.com/4OTFEvents/
selling [Moog Sub Phatty, KMI K-Mix w/ MIDI expander, Erica Synths Bassline]: viewtopic.php?p=3142686
transferpoint
butt-hole
Post by transferpoint » Thu Jan 02, 2020 8:00 pm
Perfect Circuit sent an email out saying the ES-9's were in stock, but I never received a shipping update. So, either the email was sent in error or maybe I was too far back in line to make the cut this round. I ordered on November 1st.
versipellis
Post by versipellis » Fri Jan 03, 2020 2:50 am
Wow, that's backlogged.
Just ordered one, praying it'll arrive in time for when I need it.
AbundantChoice
Post by AbundantChoice » Fri Jan 03, 2020 9:27 am
I ordered back on Oct 1st and didn't get anything out of this shipment either (assuming there was a shipment and it wasn't a glitch)
versipellis
Post by versipellis » Fri Jan 03, 2020 3:40 pm
PCA got back to me that they've no update. Ctrl-mod just told me that they're getting stock next week though, and there's enough stock in that shipment if you pre-order it now, but they're flying like hotcakes.
transferpoint
butt-hole
Post by transferpoint » Fri Jan 03, 2020 5:00 pm
Perfect Circuit just told me that their shipment contained 7 of the 90 units they ordered, so yeah, we didn't make that cut haha. woof
versipellis
Post by versipellis » Fri Jan 03, 2020 9:28 pm
yikes.
Ys521wow
Post by Ys521wow » Sat Jan 04, 2020 12:14 am
Got my Es 9 yesterday and tried it to connected to Ableton CV tool. And I didn’t get the audio signal from my Oscillator out into the input 1 of Es9, also I tried to set the CV instrument pitch to the Ext. out 4 and it didn’t connected to es9. I set channel configuration 1-6 input mono and stereo and 1-6 output mono and stereo in Ableton. I don’t know what parts I’m missing here, I’m appreciate it if someone could help me out.
Fallingman
Post by Fallingman » Sat Jan 04, 2020 12:17 am
Sadness, I hope we don’t have to wait forever. I ordered mid December from Perfect Circuit.
GGeb
Post by GGeb » Fri Jan 24, 2020 10:59 am
Hello guys!
I am having a bit of an hard time with my ES-9.
I am using it to multitrack in ableton, but most of my modules are peaking. Does anyone know how can I control the input levels? I tried to use the ES-9 software but I can't control individual levels of the 14 inputs.
mmontazeri
Post by mmontazeri » Fri Jan 24, 2020 11:46 am
If you're on a Mac you might need to allow microphone in security. System Preferences => Security & Privacy => Microphone
Jaypee
Post by Jaypee » Sat Jan 25, 2020 4:45 am
I have very low but audible high frequencies noise from input 1&2. No pb at all, dead quiet on the others.
I haven't noticed it till recently in studio recording situation.
Will do a screenshot next week.
Meanwhile, can you check if you guys have similar problem?
"Those aren't your daddy's waveforms " Cynthia Webster
MvK
Post by MvK » Sat Jan 25, 2020 10:21 am
Any info on a batch for schneidersladen?
We are the Borg. Resistance is equal to voltage divided by current.
https://soundcloud.com/logic_not
current 9U: https://www.modulargrid.net/e/racks/view/428567
Skiff: https://www.modulargrid.net/e/racks/view/818039
transferpoint
butt-hole
Post by transferpoint » Sat Jan 25, 2020 10:51 am
Every one of my channels hiss. :/
Jaypee
Post by Jaypee » Sat Jan 25, 2020 11:40 am
Wow can you describe a bit more?
Non related questions to this problem :
Anyone tried es-9 with 4ms pod? Any problems?
I tried to use my tip-top audio uzeus power supply. Didn't work.
transferpoint
butt-hole
Post by transferpoint » Sat Jan 25, 2020 1:15 pm
Maybe I'll post a recording today. If I start with no channels active I get no hiss obviously. But each channel I active adds more and more hiss.
Picture it like adding 14 layers of vinyl hiss over one another.
I use Cubase 10 on a 2016 MacBook Pro fwiw.
ForAiur
Post by ForAiur » Tue Jan 28, 2020 9:40 am
Since Os is also reading here and I don't want to stress him out on Facebook:
How does the ES-9s power requirement scale? I want to use it in an external 4MS case to bring to synth meetups.
If I use it like this https://www.modulargrid.net/e/racks/view/1104276#top It would need more power than a good power bank would deliver (2,4 A), so I would have to connect it to a usb power supply (3A).
With only the Microcell and the ES-9 it gets very close (2,34 A, the battery provides 2,4, I guess this is too close without any headroom, but have to wait for the ES-9) https://www.modulargrid.net/e/racks/view/1114338
What makes the ES-9 use more power? Because it says up to? If I only use 1-4 inputs and 1 output, does that make it use a lot less power than the max value that is posted on modulargrid?
Wubz
Post by Wubz » Wed Jan 29, 2020 10:22 am
I have hiss on channels 5 and 10. Mac mini 2018. Any solutions for this?
Wubz
Post by Wubz » Wed Jan 29, 2020 10:33 am
Actully, If I set it to 44khz in Ableton preferences, hiss goes away
StrangeAttraction
Post by StrangeAttraction » Wed Jan 29, 2020 10:53 am
Hi,
In a standalone mixer configuration, is it possible to route the 8 input to be for example: 2 mono (IN1, IN2) + 3 stereo (IN3-4, 5-6, 7-8) -> Main L/R out signal path? Just wondering if I can forgo mixer & output module if I'm after a simple task of mixing source to a line-level stereo out. Thanks
transferpoint
butt-hole
Post by transferpoint » Wed Jan 29, 2020 11:52 am
I'll mess with my settings a bit and report back. But my hiss is noticeable on all channels and compounds if all channels are activated.
plainjanefrancis
Post by plainjanefrancis » Wed Jan 29, 2020 5:55 pm
Nothing would make me happier, than if the volume knob on this module controlled both the headphones as well as the LR outs, or if you could configure which output was controlled by the knob. Is this possible?
