Expert Sleepers ES-9 USB Audio Interface
Wubz
Re: Expert Sleepers ES-9 USB Audio Interface
Post by Wubz » Wed Jan 29, 2020 10:22 am
transferpoint wrote:
Sat Jan 25, 2020 1:15 pm
Jaypee wrote:
Sat Jan 25, 2020 11:40 am
Wow can you describe a bit more?
Maybe I'll post a recording today. If I start with no channels active I get no hiss obviously. But each channel I active adds more and more hiss.
Picture it like adding 14 layers of vinyl hiss over one another.
I use Cubase 10 on a 2016 MacBook Pro fwiw.
I have hiss on channels 5 and 10. Mac mini 2018. Any solutions for this?
Wubz
Post by Wubz » Wed Jan 29, 2020 10:33 am
Actully, If I set it to 44khz in Ableton preferences, hiss goes away
StrangeAttraction
Post by StrangeAttraction » Wed Jan 29, 2020 10:53 am
Hi,
In a standalone mixer configuration, is it possible to route the 8 input to be for example: 2 mono (IN1, IN2) + 3 stereo (IN3-4, 5-6, 7-8) -> Main L/R out signal path? Just wondering if I can forgo mixer & output module if I'm after a simple task of mixing source to a line-level stereo out. Thanks
transferpoint
butt-hole
Post by transferpoint » Wed Jan 29, 2020 11:52 am
I'll mess with my settings a bit and report back. But my hiss is noticeable on all channels and compounds if all channels are activated.
plainjanefrancis
Post by plainjanefrancis » Wed Jan 29, 2020 5:55 pm
Nothing would make me happier, than if the volume knob on this module controlled both the headphones as well as the LR outs, or if you could configure which output was controlled by the knob. Is this possible?
calum3000
Post by calum3000 » Wed Jan 29, 2020 11:24 pm
Hey guys noob here, I've just bought my first couple of modules including the es-9, haven't plugged anything in yet just been watching a couple of videos and I've seen 'floating ring' cables mentioned, just checking because I'm not very knowledgeable on the technical side, I don't need to use these with the es-9 do I? I can just use regular eurorack cables right?
Wubz
Post by Wubz » Fri Jan 31, 2020 9:44 am
Any luck? I'd love a response from Os on our issues.
ForAiur
Re:
Post by ForAiur » Fri Jan 31, 2020 10:29 am
os wrote:
Wed Dec 18, 2019 2:59 am
For example, is there a way to just tell the module that all inputs should be output in Mono on output 1? Then I could use my system with this as a mixer even with no iPad around (ES-8 output into Intellijel 1U Audio Out module).
Yes you can do that.
How? I'm in the Expert Sleepers Control panel for my ES-8 but I find no way of pre-connecting inputs to outputs so I can use it without a PC or iPad?
Post by os » Fri Jan 31, 2020 11:26 am
Hi. The forum gave up notifying me about this thread, so this is my first visit since I posted last above.
What are the currently outstanding issues?
MvK
Post by MvK » Fri Jan 31, 2020 4:44 pm
not available at schneiders :-)
Wubz
Post by Wubz » Fri Jan 31, 2020 5:30 pm
That was me who emailed you today. Nick
transferpoint
butt-hole
Post by transferpoint » Fri Jan 31, 2020 8:15 pm
Work has been crazy this week. I've only been able to turn on the modular once so far. I'll post an update when I have a chance.
Jaypee
Post by Jaypee » Sat Feb 01, 2020 6:04 am
here is my problem in images:
input one an two have this weird thing
Capture d’écran 2020-02-01 à 11.25.04.png (673.62 KiB) Viewed 514 times
3&4, and all others input don't have this problem
Capture d’écran 2020-02-01 à 11.25.14.png (666.57 KiB) Viewed 514 times
Anyone can check if you have the same problem?
os?
"Those aren't your daddy's waveforms " Cynthia Webster
Post by os » Sat Feb 01, 2020 6:27 am
I was worried for a moment there until I noticed that the signal is peaking at -90dB. I think this is within spec. Inputs 1/2 are expected to be slightly noisier than inputs 3-14.
That said I don't ever recall noticing such a strong peak in the noise floor. Could you try moving the ES-9 around in your case, or moving some other modules - maybe it's picking something up from elsewhere?
Jaypee
Post by Jaypee » Sat Feb 01, 2020 6:55 am
Yes it s very low. But still audible from 1&2 inputs.
No pb for other inputs.
I use a mantis case Btw.
Thanks for the quick answer. Will report after moving the module.
Jaypee
Post by Jaypee » Sat Feb 01, 2020 6:56 am
And regarding the difference between inputs 1&2 it's that 1.5khz noisy sweep that annoyes me.
Fallingman
Post by Fallingman » Thu Feb 06, 2020 5:15 pm
Anybody else gotten their ES-9? I’m still waiting on my preorder from mid december.
Polyterative
Post by Polyterative » Mon Feb 10, 2020 6:24 am
Ordered 2 weeks ago, still waiting (Italy)
Rack / Music / Instagram / Module demos
► Show Spoiler
trinitymartyrdom
Post by trinitymartyrdom » Mon Feb 10, 2020 10:12 am
Hey Everyone,
Did anyone order a module from Thomann?
Still waiting on my order from october...
:hail:
Post by os » Mon Feb 10, 2020 10:28 am
I'm told a decent number shipped to Thomann this week.
trinitymartyrdom
Post by trinitymartyrdom » Mon Feb 10, 2020 11:39 am
Hey, thank you for your feedback but I wrote them an e-mail and they hadn't heard anything about that shipment...
Audiobender
Post by Audiobender » Tue Feb 11, 2020 3:46 am
When will the unit be available again?
Scanning the EU shops for two months now.
Thomann has removed the product from their shop and music store says May?!
Post by os » Tue Feb 11, 2020 3:49 am
Stock here: https://cymrubeats.com/product/expert-s ... interface/
Units en route to Thomann and Schneiders right now.
Bachelard
Post by Bachelard » Tue Feb 11, 2020 6:39 pm
Ys521wow wrote:
Sat Jan 04, 2020 12:14 am
Got my Es 9 yesterday and tried it to connected to Ableton CV tool. And I didn’t get the audio signal from my Oscillator out into the input 1 of Es9, also I tried to set the CV instrument pitch to the Ext. out 4 and it didn’t connected to es9. I set channel configuration 1-6 input mono and stereo and 1-6 output mono and stereo in Ableton. I don’t know what parts I’m missing here, I’m appreciate it if someone could help me out.
Ys521wow - I was setting this up last week for a client, and noticed in the manual that the ES-9 analog (3.5mm) outputs are actually 9-16. So if you're trying to send gate and cv from the cv tool, try assigning output 9 to the Gate and 10 to pitch. I tried that and saw the output jack light up with the MIDI clip playing in Ableton.
From the manual:
Channel numbering
The default channel numbering in your DAW will appear as follows, though this can be
reconfigured as required.
Main outputs: 1/2
Headphone output: mix of 1/2 & 3/4
S/PDIF output: 5/6
ES-5 output: 7/8
3.5mm outputs: 9-16
Audiobender
Post by Audiobender » Wed Feb 12, 2020 7:13 am
Thank you Os.
Unfortunately, too late again :doh:
Hopefully another chance at Thomann or Schneiders.
