Expert Sleepers ES-9 USB Audio Interface
Jaypee
Re: Expert Sleepers ES-9 USB Audio Interface
Post by Jaypee » Sat Mar 21, 2020 8:58 am
Anyone has latency problems?
I have to experiment a bit more but my setup was very tight using es-3/6 and minidsp as my interface. With es-9 connected through USB port, not so much. Will try to use minidsp interface and connect es-9 to it...and report.
"Those aren't your daddy's waveforms " Cynthia Webster
igneonsystem
Post by igneonsystem » Sun Mar 22, 2020 2:48 pm
Im experimenting with this soundcard for 2 weeks.
What i notice now is that when i select my Daw (ableton) and i put the expert sleepers soundcard. I keeps on playing in Mono.
If i wide my stereo field on a synth (virtual) The volume just gets louder. My output in ableton is set on channel 15/16
Do i miss something? Or what do i need to do in the mixer interface?
note!
Post by note! » Thu Mar 26, 2020 12:15 pm
Any updates on new units to the US? All seem to be out :( Really wish they had come in stock again before The Virus.
jones
Post by jones » Fri Mar 27, 2020 7:00 am
Hi OS - quick one - just got my ES-9 today (replacing a MOTU ultra lite MK4) at 0db in Ableton Live on the master with nothing plugged into the ES-9 i'm getting a lot of white noise. Am I doing anything wrong? Updated to the latest Firmware. Input DC Blocking turned on for all channels. Main outs L and R are at 0db in the config tool. On an iMac.
Post by os » Fri Mar 27, 2020 7:16 am
Do you maybe need to turn your speakers down? Have you sent actual audio out of the ES-9 to get an idea of how loud it is?
jones
Post by jones » Fri Mar 27, 2020 7:27 am
That sorted it - signal much hotter than the motu - cheers, this going to be so good!
jones
Post by jones » Fri Mar 27, 2020 9:15 am
With regard to the ES-5 - will I need to use that specific Silent Way software with the ES-9 in order to get triggers out of it (how it was with the ES3) - if/when it's connected to the ES-9?
Post by os » Fri Mar 27, 2020 9:16 am
Yes, it's the same. Silent Way or max/msp externals or VCV Rack plug-in.
MvK
Post by MvK » Sun Mar 29, 2020 10:05 am
is there any word on when and if the next batch hits schneidersladen? they said I'm second in line but it has been like this for many weeks now (since the last batch which I missed by one slot :-| Otherwise I'd consider ordering from signal sounds but that seems not ideal atm because of corona. I really can't wait :-)
We are the Borg. Resistance is equal to voltage divided by current.
https://soundcloud.com/logic_not
current 9U: https://www.modulargrid.net/e/racks/view/428567
Skiff: https://www.modulargrid.net/e/racks/view/818039
Velazquez
Post by Velazquez » Mon Mar 30, 2020 11:56 am
I would like to ask about the difference between es-8 and es-9. Do they differ in sound quality? Is the basic difference the number of inputs and additional options in the es-9 like a mixer or headphone output? I need a module for eurorack and vcv communication. Four inputs are enough for me at this moment. The Es-9 has 16 hp and is very expensive. I would rather buy es-8 as long as it doesn't differ in quality. I don't care about the additional functionality of es-9. Will I lose something important in communication with vcv by choosing es-8?
Post by os » Mon Mar 30, 2020 1:23 pm
The sound quality is pretty much the same. The ES-9 has (many) more inputs, and has the 1/4" sockets.
Make sure you also consider the ES-3/6, if those are an option for you.
versipellis
Post by versipellis » Tue Mar 31, 2020 2:38 am
Anyone know if the ES-9 is multi-client ASIO?
dip_registered
Post by dip_registered » Sat Apr 04, 2020 2:06 pm
The two modes (hosted and standalone) in the nest firmware are ace! Thanks! :hail:
